Hi there,
i am new to EndeavourOS and used Fedora before. After installation the dark theme in Endeavour OS does not work completely so i fixed it with
sudo pacman -S xdg-desktop-portal-gnome xdg-desktop-portal.
But now the light theme is broken like the settings menu in the top right corner stays dark even if i active the default theme.
Is there a way to install the light theme by myself ?
And sorry if i did not see the solution in the forum. I did not find what i think i need.
Thanks a lot for the help and best regards from Germany. ![]()
