As of today when I try to print in landscape mode from LibreOffice it only outputs in Portrait mode. I’ve been using this app for years and never had this problem. Maybe it’s from a recent update? For the record, I’m using libreoffice-fresh.
Does anyone else have this problem recently? I’ve looked at the github and found nothing.
I should have tried this first, but I output a LibreOffice writer file to PDF and printed it from Okular and it still is printing incorrectly. Just like from LibreOffice it appears on screen as a landscape document, but prints incorrectly.
FWIW, when I try to print a Test Page from the printer I get this error message in the Print Queue:
Status: Stopped, cfFilterChain: pdftopdf (PID 1859) stopped with status 1
So maybe this is a printer problem? I’m not sure how to diagnose this, any ideas?
Also, same printer, same computer, different OS (W11) = no problem
I had the same problem yesterday on EndeavourOS.
LibreOffice and Okular wouldn’t print in landscape mode.
I then switched to Debian and printed the PDF there, and there were no problems at all.
Why? I have no idea.
That doesn’t really help you right now, but at least you know that the problem
Thanks, downgrading libscupfilers solved everything. I’m sure there will be an update soon that will allow me to run the newest version. Thanks for helping!
