Does anyone also have the problem that the spelling does not work in a new installed libreoffice-fresh?
Spelling: [none]
Spelling: [none]
Perhaps this:
For spell checking, please make sure hunspell is properly installed; this should be the case for both still and fresh LibreOffice versions. Then install a language dictionary for hunspell
simple yay search will find language you want /need
for me i use
aur/hunspell-th 1.0.0-1 (+5 1.01) (Installed)
extra/hunspell-en_gb 2020.12.07-4 (559.2 KiB 14.0 MiB) (Installed) ( real English )
pick flavour you need
Install to get spell checking working system wide (aka working in LibreOffice/Hexchat for example):
sudo pacman -S hunspell-en_us
In all the years of using Libreoffice, I have never had to install hunspell-de. It was always ‘all inclusive’.
But thanks for the tip!!
that’s weird, i also have german language settings, but only the hunspell package, which i didn’t install myself. the spelling works for me by default.
