D_el
February 11, 2022, 1:29am
1
Hi, this happens when trying to run a .iso on lutris with the pcsx2 emulator runner. I installed pcsx2 itself and it wont start, instead, on terminal says: instruction illegal (core dumped).
I tried paru libgtk-x11-2.0.so.0but couldn’t find nothing; then i reinstalled the whole gtk2, but nothing changed. How to fix ?
dalto
February 11, 2022, 1:32am
2
Try installing lib32-gtk2
D_el
February 11, 2022, 2:02am
3
I did, now the error message doesnt shows up, but i still cant run pcsx2 neither in lutis or pcsx2 itself ( pcsx2 still gives the “cored dumped” thing, what does it mean ?)
dalto
February 11, 2022, 2:14am
4
Core dump means it crashed.
D_el
February 11, 2022, 2:55pm
5
Well, kinda figured out the problem. I went to pcsx2 documentation (https://wiki.pcsx2.net/PCSX2_Documentation/Compiling_on_Linux ), got all the missing libs from this list:
lib32-alsa-lib lib32-bzip2 lib32-libjpeg lib32-glew lib32-nvidia-cg-toolkit lib32-portaudio lib32-sdl lib32-libaio lib32-wxgtk3 lib32-soundtouch lib32-libpcap lib32-zlib lib32-libsamplerate sparsehash fmt
and after all that, tried to compile pcsx2-git on terminal and some steps further it gave me this: error PCSX2 requires compiling for at least SSE 4.1
Which, from my brief research, it means that my system dont support SSE 4.1 (or something like that, i’m no expert, but heres my specs from inxi -FAZ --no-host | eos-sendlog anyways).
Kernel: 5.16.8-arch1-1 x86_64 bits: 64 Desktop: KDE Plasma 5.24.0
Distro: EndeavourOS
Type: Desktop Mobo: ASUSTeK model: M5A88-M v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 1101
date: 03/16/2012
Info: quad core model: AMD Phenom II X4 850 bits: 64 type: MCP cache:
L2: 2 MiB
Speed (MHz): avg: 1100 min/max: 800/3300 cores: 1: 800 2: 2000 3: 800
4: 800
Device-1: NVIDIA GP108 [GeForce GT 1030] driver: nvidia v: 510.47.03
Device-2: Generalplus GENERAL WEBCAM type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org 1.21.1.3 driver: loaded: nvidia
unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03
Device-1: AMD SBx00 Azalia driver: snd_hda_intel
Device-2: NVIDIA GP108 High Definition Audio driver: snd_hda_intel
Device-3: Generalplus GENERAL WEBCAM type: USB
Sound Server-1: ALSA v: k5.16.8-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL8192EE PCIe Wireless Network Adapter driver: rtl8192ee
IF: wlan0 state: down mac: 16:77:b7:d5:91:0c
driver: r8169
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: 10:bf:48:75:7b:6b
Bluetooth:
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 1.03 TiB used: 70.84 GiB (6.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10EARS-00Y5B1
ID-2: /dev/sdb vendor: Colorful model: SL300 120GB size: 111.79 GiB
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk
ID-1: / size: 111.79 GiB used: 70.84 GiB (63.4%) fs: btrfs dev: /dev/sdb1
ID-2: /home size: 111.79 GiB used: 70.84 GiB (63.4%) fs: btrfs
dev: /dev/sdb1
ID-3: /var/log size: 111.79 GiB used: 70.84 GiB (63.4%) fs: btrfs
dev: /dev/sdb1
System Temperatures: cpu: 35.0 C mobo: 34.0 C
Fan Speeds (RPM): cpu: 0 case-1: 2445
Processes: 200 Uptime: 39m Memory: 7.76 GiB used: 1.72 GiB (22.2%)
Shell: Bash inxi: 3.3.12
dalto
February 11, 2022, 3:00pm
6
Unfortunately, the Phenom II does not support SSE 4.1
Have you looked into if it can be built with a lower version of SSE?
D_el
February 11, 2022, 3:11pm
7
Well, it seems that if i use older versions of pcsx2, i should be able to workaround of this situation
