LG C4 recently no higher than 4k/60?
hey all, anyone out there using an LG OLED at 4k/120 hz?
i was, but as of yesterday’s system update i’ve lost the option to set to 4k/120. AND, the problem is also there on LTS.
i used to be able to do 4k@120 with FreeSync and HDR, at 4:2:0 subsampling, but now that option no longer exists.
i’m on KDE+Wayland.
xrandr isn’t reporting any other refresh than 60.
i’ve tried LTS kernel, turning off: 4:4:4 passthrough, VRR, HDR, but no change.
GPU: Radeon 7900 XTX
driver: mesa
HDMI 2.1
no other monitors.
any thoughts are appreciated. thanks!
I have a LG OLED C1, also a 7900XTX and I am also using KDE Plasma on Wayland.
I have no issues currently, everything is working fine. I am not using HDR tho.
I am using a DisplayPort to HDMI adapter to get full 4k120 RGB / 4:4:4 without subsampling. It is a DisplayPort 1.4 adapter so display stream compression is active of course. But it works fine and Freesync / VRR works too.
It is this adapter:
I am using this firmware:
https://kb.cablematters.com/index.php?View=entry&EntryID=160
There seems to be a newer firmware but it looks like it’s specific to macOS and I haven’t tried it since I have no issues with the older firmware:
https://kb.cablematters.com/index.php?View=entry&EntryID=147
You will need Windows to update the firmware tho.
neat, thanks! yeah, i dunno where the issue is. if it’s plasma, mesa, wayland. no clue why it changed and i can’t get it back.
i’ll take a look at this adapter. i have a VM for such firmware things.
would you mind enabling HDR in plasma display settings just to test for me? let me know if anything changes before i buy this device?
thanks!
Turned on the TV → enabled it in the Plasma display settings → turned on HDR in the Plasma display setting → the TV detect HDR content and automatically switched to a HDR mode and it reports the input signal as 4k120 RGB 10b HDR10.
Also checked the newer firmware package. I’d stick with https://kb.cablematters.com/index.php?View=entry&EntryID=160
The newer one looks like it’s meant for macOS / Mac Books and the normal version included has a lower version number than the one from 2023 (for some reason)
perfect! thank you i’ll give it a go!
