Lexmark MS 510 dn USB printer error
Hello to everyone
Iv just connected the above usb printer which is recognized and added by the system.
When im trying to print a document , printer returns me this error
‘’ ERROR
configurationerror
OFFENDING COMMAND
SETPAGE DEVICE
stack
–nostringval–
false
792
612
0
0
792
612
–nostrinval–
5’’
does it seem to be a printer drivers issue? i havent installed any drivers for this printer,
where can i find one?
Thanks
This might help
thank you for your reply
i followed all these steps before posting but problem insists
it seems ridiculous but problem solved by installing a …pdf viewer and then print the document from inside the viewer
Problem started when i used Firefox browser to open pdf files and then print
As you mentioned that you haven’t installed any driver, I assumed you might not have followed the wiki.
Good that things worked out for you but why would firefox cause this error?
Its the firefox build that is shipped with the iso.
I have no reason for that, it seems wired to me as well
You might need the driver from Lexmark Support (Driver files for CUPS-based systems (Linux Universal Print Driver)).
Type your model ms510dn in the search field.
