I’m not sure how to resolve this issue. I was wondering if anyone else has had this issue and if so how do i fix it?
Hello and welcome,
Maybe we could start with system info;
inxi -Farz
Thank you for the reply!
inxi -Farz
Kernel: 6.12.51-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: acpi_pm
parameters: initrd=\0a203173aaf44e72b40d96767846abd8\6.12.51-1-lts\initrd
nvme_load=YES nowatchdog rw
root=UUID=
systemd.machine_id=
Desktop: KDE Plasma v: 6.4.5 tk: Qt v: N/A info: frameworks v: 6.18.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-fd0xxx v: N/A
serial: Chassis: type: 10 serial:
Mobo: HP model: 8B36 v: 62.51 serial:
part-nu: 7L2C7UA#ABA uuid: UEFI: AMI v: F.18
date: 04/25/2025
Battery:
ID-1: BAT0 charge: 37.6 Wh (100%) condition: 37.6/41 Wh (91.7%) volts: 12.66
min: 11.25 model: HP Primary type: Li-ion serial: charging:
status: full cycles: 83
Info: model: Intel N200 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x1D
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 smt: cache:
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 868 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 868 2: 868 3: 868 4: 868 bogomips: 7988
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: indirect_target_selection status: Not affected
Type: reg_file_data_sampling mitigation: Clear Register File
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Type: tsa status: Not affected
Type: vmscape mitigation: IBPB before exit to userspace
Device-1: Intel Alder Lake-N [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46d0 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP True Vision HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-3:3 chip-ID: 05c8:0b08 class-ID: fe01 serial:
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1541 built: 2021 res:
mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris wayland:
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL-N)
device-ID: 8086:46d0 memory: 7.25 GiB unified: yes display-ID: :1.0
de: kscreen-console,kscreen-doctor gpu: nvidia-smi
wl: nwg-displays,wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-N PCH High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:54c8 class-ID: 0401
API: ALSA v: k6.12.51-1-lts status: kernel-api
Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network [1T1R]
vendor: Hewlett-Packard driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b85b
class-ID: 0280
IF: wlan0 state: up mac:
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 0bda:b85d
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: bt-v: 5.2 lmp-v: 11
status: discoverable: no pairing: no
Local Storage: total: 119.2 GiB used: 45.56 GiB (38.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: KLUDG4UHGC-B0E1
size: 119.2 GiB block-size: physical: 4096 B logical: 4096 B tech: N/A
serial: N/A fw-rev: 1001 scheme: GPT
ID-1: / raw-size: 117.19 GiB size: 114.79 GiB (97.95%)
used: 44.47 GiB (38.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0Info:
Memory: total: 8 GiB note: est. available: 7.42 GiB used: 4.96 GiB (66.8%)
Processes: 210 Power: uptime: 3h 52m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 2.89 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
running-in: konsole inxi: 3.3.39
