Recently installed endeavourOS on my laptop, and since today, after updating I think, every time I try to shut down my system it just reboots instead… I took a look at journalctl and dmesg but nothing jumps out at me (except a few concerning zenbleed messages but we ignore those)
I think it could have something to do with dracut, checked my configs and rebuilt dracut, still reboots, I also of course tried shutdown -hP 0, etc…
here is the result of journalctl -b -p 4
any help or suggestions would be greatly appreciated
mar 08 22:08:36 ether-laptop kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
mar 08 22:08:36 ether-laptop kernel: pci 0000:00:00.2: PCI INT A: not connected
mar 08 22:08:36 ether-laptop kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_PR_.P000 (20230628/dspkginit-438)
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
mar 08 22:08:36 ether-laptop kernel: blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
mar 08 22:08:36 ether-laptop systemd-escape[313]: Input 'luks-a8f9bae4-0501-4677-b313-20c8d13a126d' is not an absolute file system path, escaping is likely not going to be reversible.
mar 08 22:08:37 ether-laptop kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
mar 08 22:08:37 ether-laptop systemd-cryptsetup[476]: Failed to activate, key file '/crypto_keyfile.bin' missing.
mar 08 22:08:38 ether-laptop kernel: clocksource: timekeeping watchdog on CPU3: Marking clocksource 'tsc' as unstable because the skew is too large:
mar 08 22:08:38 ether-laptop kernel: clocksource: 'hpet' wd_nsec: 504206679 wd_now: 1ba88f4 wd_last: 14c607a mask: ffffffff
mar 08 22:08:38 ether-laptop kernel: clocksource: 'tsc' cs_nsec: 503362950 cs_now: 3d7a1566c cs_last: 398a31afd mask: ffffffffffffffff
mar 08 22:08:38 ether-laptop kernel: clocksource: Clocksource 'tsc' skewed -843729 ns (0 ms) over watchdog 'hpet' interval of 504206679 ns (504 ms)
mar 08 22:08:38 ether-laptop kernel: clocksource: 'tsc' is current clocksource.
mar 08 22:08:38 ether-laptop kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
mar 08 22:08:38 ether-laptop kernel: clocksource: Checking clocksource tsc synchronization from CPU 3 to CPUs 0,2,8,11.
mar 08 22:08:50 ether-laptop kernel: platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
mar 08 22:08:50 ether-laptop (udev-worker)[768]: controlC1: Process '/usr/bin/alsactl restore /dev/snd/controlC1' failed with exit code 99.
mar 08 22:08:52 ether-laptop systemd-logind[940]: /efi/loader/loader.conf:5: Unknown line 'reboot-for-bitlocker', ignoring.
mar 08 22:08:53 ether-laptop kernel: [drm] psp gfx command LOAD_TA(0x1) failed and response status is (0x7)
mar 08 22:08:53 ether-laptop kernel: [drm] psp gfx command INVOKE_CMD(0x3) failed and response status is (0x4)
mar 08 22:08:53 ether-laptop kernel: amdgpu 0000:04:00.0: amdgpu: Secure display: Generic Failure.
mar 08 22:08:53 ether-laptop kernel: amdgpu 0000:04:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
mar 08 22:08:54 ether-laptop dbus-broker-launch[931]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "Date: 2024-03-08 CET\n[22:08:54.717] weston 13.0.0\n https://wayland.freedesktop.org\n Bug reports to: https://gitlab.freedesktop.org/wayland/weston/issues/\n Build: 13.0.0\n[22:08:54.717] Command line: /usr/bin/weston --shell=kiosk\n[22:08:54.717] OS: Linux, 6.7.9-arch1-1, #1 SMP PREEMPT_DYNAMIC Fri, 08 Mar 2024 01:59:01 +0000, x86_64\n[22:08:54.717] Flight recorder: enabled\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.717] Starting with no config file.\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.718] Output repaint window is 7 ms maximum.\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.719] Loading module '/usr/lib/libweston-13/drm-backend.so'\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.723] initializing drm backend\n[22:08:54.723] Trying libseat launcher...\n[22:08:54.723] [libseat/backend/seatd.c:64] Could not connect to socket /run/seatd.sock: No such file or directory\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.724] [libseat/libseat.c:76] Backend 'seatd' failed to open seat, skipping\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.746] [libseat/libseat.c:73] Seat opened with backend 'logind'\n[22:08:54.746] libseat: session control granted\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.747] using /dev/dri/card1\n[22:08:54.747] DRM: supports atomic modesetting\n[22:08:54.747] DRM: supports GBM modifiers\n"
mar 08 22:08:54 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:54.747] DRM: does not support async page flipping\n[22:08:54.747] DRM: supports picture aspect ratio\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.041] Loading module '/usr/lib/libweston-13/gl-renderer.so'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.048] Using rendering device: /dev/dri/renderD128\n[22:08:55.048] EGL version: 1.5\n[22:08:55.048] EGL vendor: Mesa Project\n[22:08:55.048] EGL client APIs: OpenGL OpenGL_ES \n[22:08:55.048] EGL features:\n EGL Wayland extension: yes\n context priority: yes\n buffer age: yes\n partial update: no\n swap buffers with damage: no\n configless context: yes\n surfaceless context: yes\n dmabuf support: modifiers\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.050] GL version: OpenGL ES 3.2 Mesa 24.0.2-arch1.2\n[22:08:55.050] GLSL version: OpenGL ES GLSL ES 3.20\n[22:08:55.050] GL vendor: AMD\n[22:08:55.050] GL renderer: AMD Radeon Graphics (radeonsi, renoir, LLVM 17.0.6, DRM 3.57, 6.7.9-arch1-1)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.059] GL ES 3.2 - renderer features:\n read-back format: ARGB8888\n glReadPixels supports y-flip: yes\n wl_shm 10 bpc formats: yes\n wl_shm 16 bpc formats: yes\n wl_shm half-float formats: yes\n internal R and RG formats: yes\n OES_EGL_image_external: yes\n[22:08:55.059] Using GL renderer\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.076] event4 - Video Bus: is tagged by udev as: Keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.076] event4 - Video Bus: device is a keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.077] event0 - Power Button: is tagged by udev as: Keyboard\n[22:08:55.077] event0 - Power Button: device is a keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.079] event1 - Lid Switch: is tagged by udev as: Switch\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.079] event1 - Lid Switch: device is a switch device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.081] event17 - HD-Audio Generic HDMI/DP,pcm=3: is tagged by udev as: Switch\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.081] event17 - not using input device '/dev/input/event17'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.140] event13 - Logitech USB Receiver: is tagged by udev as: Mouse\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.140] event13 - Logitech USB Receiver: device is a pointer\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.144] event14 - Logitech USB Receiver Keyboard: is tagged by udev as: Keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.144] event14 - Logitech USB Receiver Keyboard: device is a keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.147] event18 - HD-Audio Generic Mic: is tagged by udev as: Switch\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.147] event18 - not using input device '/dev/input/event18'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.149] event19 - HD-Audio Generic Headphone: is tagged by udev as: Switch\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.149] event19 - not using input device '/dev/input/event19'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.152] event6 - ELAN2514:00 04F3:2D07: is tagged by udev as: Touchscreen\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.152] event6 - ELAN2514:00 04F3:2D07: device is a touch device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.154] event7 - ELAN2514:00 04F3:2D07 UNKNOWN: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.155] event7 - not using input device '/dev/input/event7'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.157] event8 - ELAN2514:00 04F3:2D07 UNKNOWN: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.157] event8 - not using input device '/dev/input/event8'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.158] event9 - ELAN2514:00 04F3:2D07 Stylus: is tagged by udev as: Tablet\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.190] event9 - ELAN2514:00 04F3:2D07 Stylus: tablet 'ELAN2514:00 04F3:2D07 Stylus' unknown to libwacom\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.190] event9 - ELAN2514:00 04F3:2D07 Stylus: device is a tablet\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.192] event10 - ELAN2514:00 04F3:2D07 UNKNOWN: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.192] event10 - not using input device '/dev/input/event10'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.194] event11 - ELAN2514:00 04F3:2D07 UNKNOWN: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.194] event11 - not using input device '/dev/input/event11'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.195] event12 - ELAN2514:00 04F3:2D07 UNKNOWN: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.196] event12 - not using input device '/dev/input/event12'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.197] event2 - SYNA32B3:01 06CB:CE7D Mouse: is tagged by udev as: Mouse Pointingstick\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.197] event2 - SYNA32B3:01 06CB:CE7D Mouse: device is a pointer\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.200] event3 - SYNA32B3:01 06CB:CE7D Touchpad: is tagged by udev as: Touchpad\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.201] event3 - SYNA32B3:01 06CB:CE7D Touchpad: device is a touchpad\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.203] event5 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.203] event5 - AT Translated Set 2 keyboard: device is a keyboard\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.205] event15 - PC Speaker: not tagged as supported input device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.205] event15 - not using input device '/dev/input/event15'\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.206] event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.206] event16 - HP WMI hotkeys: device is a keyboard\n[22:08:55.206] event16 - HP WMI hotkeys: device is a switch device\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.213] libinput: configuring device \"Video Bus\".\n[22:08:55.213] libinput: configuring device \"Power Button\".\n[22:08:55.213] libinput: configuring device \"Lid Switch\".\n[22:08:55.213] libinput: configuring device \"Logitech USB Receiver\".\n[22:08:55.213] libinput: configuring device \"Logitech USB Receiver Keyboard\".\n[22:08:55.213] Touchscreen - ELAN2514:00 04F3:2D07 - /sys/devices/platform/AMDI0010:02/i2c-0/i2c-ELAN2514:00/0018:04F3:2D07.0004/input/input16/event6\n[22:08:55.213] libinput: configuring device \"ELAN2514:00 04F3:2D07\".\n[22:08:55.213] input device event6 has no enabled output associated (none named), skipping calibration for now.\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.213] libinput: configuring device \"ELAN2514:00 04F3:2D07 Stylus\".\n[22:08:55.213] input device event9 has no enabled output associated (none named), skipping calibration for now.\n[22:08:55.213] libinput: configuring device \"SYNA32B3:01 06CB:CE7D Mouse\".\n[22:08:55.213] libinput: configuring device \"SYNA32B3:01 06CB:CE7D Touchpad\".\n[22:08:55.213] libinput: configuring device \"AT Translated Set 2 keyboard\".\n[22:08:55.213] libinput: configuring device \"HP WMI hotkeys\".\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] DRM: head 'eDP-1' found, connector 87 is connected, EDID make 'LGD', model 'unknown', serial ''\n Supported EOTF modes: SDR\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] DRM: head 'HDMI-A-1' found, connector 95 is disconnected.\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] DRM: head 'DP-1' found, connector 101 is disconnected.\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] Registered plugin API 'weston_drm_output_api_v1' of size 40\n[22:08:55.216] Registered plugin API 'weston_drm_virtual_output_api_v2' of size 48\n[22:08:55.216] Color manager: no-op\n[22:08:55.216] Output 'eDP-1' attempts EOTF mode: SDR\n[22:08:55.216] Output 'eDP-1' using color profile: stock sRGB color profile\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] Chosen EGL config details: id: 49 rgba: 8 8 8 0 buf: 24 dep: 0 stcl: 0 int: 1-1 type: win vis_id: XRGB8888 (0x34325258)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] Output eDP-1 (crtc 73) video modes:\n 1920x1080@60.0, preferred, current, 138.7 MHz\n 1920x1080@40.0, 92.5 MHz\n 1680x1050@60.0, 138.7 MHz\n 1280x1024@60.0, 138.7 MHz\n 1440x900@60.0, 138.7 MHz\n 1280x800@60.0, 138.7 MHz\n 1280x720@60.0, 138.7 MHz\n 1024x768@60.0, 138.7 MHz\n 800x600@60.0, 138.7 MHz\n 640x480@60.0, 138.7 MHz\n[22:08:55.216] associating input device event4 with output eDP-1 (none by udev)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] associating input device event0 with output eDP-1 (none by udev)\n[22:08:55.216] associating input device event1 with output eDP-1 (none by udev)\n[22:08:55.216] associating input device event13 with output eDP-1 (none by udev)\n[22:08:55.216] associating input device event14 with output eDP-1 (none by udev)\n[22:08:55.216] associating input device event6 with output eDP-1 (none by udev)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.216] associating input device event9 with output eDP-1 (none by udev)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.217] associating input device event2 with output eDP-1 (none by udev)\n[22:08:55.217] associating input device event3 with output eDP-1 (none by udev)\n[22:08:55.217] associating input device event5 with output eDP-1 (none by udev)\n[22:08:55.217] associating input device event16 with output eDP-1 (none by udev)\n"
mar 08 22:08:55 ether-laptop sddm-helper-start-wayland[1084]: "[22:08:55.217] Output 'eDP-1' enabled with head(s) eDP-1\n[22:08:55.217] Compositor capabilities:\n arbitrary surface rotation: yes\n screen capture uses y-flip: yes\n cursor planes: yes\n arbitrary resolutions: no\n view mask clipping: yes\n explicit sync: yes\n color operations: yes\n presentation clock: CLOCK_MONOTONIC, id 1\n presentation clock resolution: 0.000000001 s\n[22:08:55.217] Loading module '/usr/lib/weston/kiosk-shell.so'\n"
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Service file '/usr/share/dbus-1/services/fr.emersion.mako.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service'
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 08 22:08:55 ether-laptop dbus-broker-launch[1110]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service'
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: file:///usr/share/sddm/themes/sugar-candy/Components/VirtualKeyboard.qml:26:1: module "QtQuick.VirtualKeyboard" is not installed
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: file:///usr/share/sddm/themes/sugar-candy/Components/Input.qml:561:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: file:///usr/share/sddm/themes/sugar-candy/Components/SystemButtons.qml:70:13: Unable to assign [undefined] to QQuickItem*
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: file:///usr/share/sddm/themes/sugar-candy/Components/SessionButton.qml:38:5: Unable to assign ComboBox_QMLTYPE_15 to Control_QMLTYPE_6
mar 08 22:08:55 ether-laptop sddm-greeter[1106]: Wayland does not support QWindow::requestActivate()
mar 08 22:08:57 ether-laptop dbus-broker-launch[931]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
mar 08 22:09:00 ether-laptop sddm-helper[1150]: [PAM] authenticate: Authentication failure
mar 08 22:09:00 ether-laptop sddm[1027]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
mar 08 22:09:00 ether-laptop sddm-helper[1150]: [PAM] Asked to close the session but it wasn't previously open
mar 08 22:09:00 ether-laptop sddm[1027]: Auth: sddm-helper exited with 1
mar 08 22:09:07 ether-laptop sddm-helper[1155]: [PAM] authenticate: Authentication failure
mar 08 22:09:07 ether-laptop sddm[1027]: Authentication error: SDDM::Auth::ERROR_AUTHENTICATION "Authentication failure"
mar 08 22:09:07 ether-laptop sddm-helper[1155]: [PAM] Asked to close the session but it wasn't previously open
mar 08 22:09:07 ether-laptop sddm[1027]: Auth: sddm-helper exited with 1
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.071] caught signal 15\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.071] event4 - Video Bus: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.071] event0 - Power Button: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.071] event1 - Lid Switch: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.072] event13 - Logitech USB Receiver: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.072] event14 - Logitech USB Receiver Keyboard: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.072] event6 - ELAN2514:00 04F3:2D07: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.072] event9 - ELAN2514:00 04F3:2D07 Stylus: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.072] event2 - SYNA32B3:01 06CB:CE7D Mouse: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.073] event3 - SYNA32B3:01 06CB:CE7D Touchpad: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.073] event5 - AT Translated Set 2 keyboard: device removed\n"
mar 08 22:09:17 ether-laptop sddm-helper-start-wayland[1084]: "[22:09:17.073] event16 - HP WMI hotkeys: device removed\n"
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Service file '/usr/share/dbus-1/services/fr.emersion.mako.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share/dbus-1/services/org.kde.dolphin.FileManager1.service'
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Service file '/usr/share/dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
mar 08 22:09:17 ether-laptop dbus-broker-launch[1229]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share/dbus-1/services/org.kde.plasma.Notifications.service'
mar 08 22:09:18 ether-laptop xdg-desktop-por[1277]: No skeleton to export
mar 08 22:09:18 ether-laptop wireplumber[1312]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
mar 08 22:09:18 ether-laptop wireplumber[1312]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner
mar 08 22:09:18 ether-laptop wireplumber[1312]: Failed to create 'api.alsa.acp.device' device
mar 08 22:09:18 ether-laptop wireplumber[1312]: <WpPortalPermissionStorePlugin:0x614976470d90> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
mar 08 22:11:00 ether-laptop systemd-logind[940]: /efi/loader/loader.conf:5: Unknown line 'reboot-for-bitlocker', ignoring.
