Hello, I have an Asus ROG Strix G15 laptop with Ryzen 9 5980HX CPU & 6800M GPU.
I’m encountering freezing issues / reboots randomly, noticeably since the last week, and very often the last few days.
I’ve noticed that it usually occurs when I try to use Discord, and mostly never occurs when I’m gaming.
But it does crash randomly, and since fresh install while just collecting system info, it has already crashed thrice.
I mainly use Wayland, but it also freezed with X11. (I can try to get a log of this, if it helps to confirm)
I’ve come across a post (for Windows) where someone encountered random freezing for an Asus laptop, and they needed to set minimum fan speed to 2000:
I’m not sure how I can do this yet, but I’m curious if this is somehow related.
Temperatures usually seemed fine before the freeze, whenever I tried to keep tracking using the system monitor.
I’ve tried using debian 12 with KDE, but I encountered the same issue.
I’ve also tried using latest Linux Mint with XFCE, and that seemed to be okay for a long period, but it did crash when I stopped gaming & started using Discord.
I used Windows for a few hours & with Discord, it seemed okay. I’d need to check it further to be sure. Hopefully, I don’t have to permanently switch back.
I’ve already upgraded my system from 16GB to 64GB RAM, and added a 2TB SSD. I’ve done a memtest for the RAM, both the SSDs pass health check while using smartctl -a.
The 2TB SSD shows the following error info, but I believe it doesn’t matter:
Error Information (NVMe Log 0x01, 16 of 64 entries)
Num ErrCount SQId CmdId Status PELoc LBA NSID VS Message
0 2428 0 0x0000 0x4004 - 0 0 - Invalid Field in Command
I’ve collect some system info:
After crash 1:
inxi -Fxxc0z: https://0x0.st/XmVj.txt
journalctl -k -b -0: https://0x0.st/XmVe.txt
Xorg.0.log: https://0x0.st/XmVt.txt
Xorg.0.log.old: https://0x0.st/XmVv.txt
(More in comments)
lsblk -o name,type,size,PTTYPE,FSTYPE
NAME TYPE SIZE PTTYPE FSTYPE
sda disk 14.5G gpt
└─sda1 part 14.5G gpt vfat
nvme0n1 disk 476.9G gpt
├─nvme0n1p1 part 1G gpt vfat
├─nvme0n1p2 part 1G gpt swap
├─nvme0n1p3 part 452G gpt ext4
├─nvme0n1p4 part 750M gpt ntfs
├─nvme0n1p5 part 22G gpt ntfs
└─nvme0n1p6 part 200M gpt vfat
nvme1n1 disk 1.8T gpt
├─nvme1n1p1 part 1.5T gpt ext4
├─nvme1n1p2 part 16M gpt
└─nvme1n1p3 part 293G gpt ntfs
Please let me know what else I could collect, or how I could isolate where the issue is coming from.
I can also try removing the newly added components (RAM/SSD), but it’s been many months since I’ve had them, so I would think it’s unlikely.
Or maybe disconnect monitor, peripherals, etc.
