Laptop HDMI external monitor connecting but not displaying
Like it says in the title. xrandr detects the monitor and I can “display” to the monitor (as in there’s a virtual monitor and I can move windows/cursor there) but it always shows up as “input signal not found” on the monitor itself. I just got this laptop second hand, it’s an hp probook 650 g4 and it has an integrated gpu so that might be the problem.
I tried connecting to the monitor from the EOS live usb but that had the same result. I know the monitor and the cable are fine, they work as expected with an RPi. I would try other types of connections but I don’t have a usb-c adapter and the VGA is backwards from every cable I could find.
I also read through here but it seems like a different problem
Here’s some system info:
$ inxi -Gaz
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:3e9b class-ID: 0300
  Device-2: Quanta HP HD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:5371
    class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.21 compositor: Picom v: 13 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
    s-diag: 581mm (22.86")
  Monitor-1: eDP-1 model: BOE Display 0x0795 built: 2017 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 26.0.1-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) device-ID: 8086:3e9b memory: 22.7 GiB unified: yes
  Info: Tools: api: eglinfo,glxinfo gpu: gputop, intel_gpu_top, lsgpu
    x11: xdpyinfo, xprop, xrandr
$ xrandr --verbose # with monitor connected and "displaying"
Screen 0: minimum 320 x 200, current 1920 x 2160, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+1080 (0x47) normal (normal left inverted right x axis y axis) 344mm x 193mm
	Identifier: 0x41
	Timestamp:  5988844
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:
	CRTC:       0
	CRTCs:      0 1 2
	Transform:  1.000000 0.000000 0.000000
	            0.000000 1.000000 0.000000
	            0.000000 0.000000 1.000000
	           filter:
	EDID:
		00ffffffffffff0009e5950700000000
		011b0104952213780224109759548e27
		1e505400000001010101010101010101
		010101010101203780b4703828403020
		360058c11000001ac02480b470382840
		6464440558c11000001a000000000000
		00000000000000000000000000000002
		000c47f90a3c6e16122270000000007c
	Colorspace: Default
		supported: Default, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, RGB_WIDE_FIXED, RGB_WIDE_FLOAT, BT601_YCC
	max bpc: 12
		range: (6, 12)
	Broadcast RGB: Automatic
		supported: Automatic, Full, Limited 16:235
	panel orientation: Normal
		supported: Normal, Upside Down, Left Side Up, Right Side Up
	scaling mode: Full aspect
		supported: Full, Center, Full aspect
	link-status: Good
		supported: Good, Bad
	CTM: 	1.000000 0.000000 0.000000
	CONNECTOR_ID: 106
		supported: 106
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x47) 141.120MHz +HSync -VSync *current +preferred
        h: width  1920 start 1968 end 2000 total 2100 skew    0 clock  67.20KHz
        v: height 1080 start 1083 end 1089 total 1120           clock  60.00Hz
  1920x1080 (0x48) 266.500MHz +HSync -VSync DoubleScan
        h: width  1920 start 1944 end 1960 total 2000 skew    0 clock 133.25KHz
        v: height 1080 start 1081 end 1084 total 1111           clock  59.97Hz
  1920x1080 (0x49) 173.000MHz -HSync +VSync
        h: width  1920 start 2048 end 2248 total 2576 skew    0 clock  67.16KHz
        v: height 1080 start 1083 end 1088 total 1120           clock  59.96Hz
  1920x1080 (0x4a) 138.500MHz +HSync -VSync
        h: width  1920 start 1968 end 2000 total 2080 skew    0 clock  66.59KHz
        v: height 1080 start 1083 end 1088 total 1111           clock  59.93Hz
  1920x1080 (0x4b) 94.080MHz +HSync -VSync
        h: width  1920 start 2020 end 2100 total 2100 skew    0 clock  44.80KHz
        v: height 1080 start 1100 end 1120 total 1120           clock  40.00Hz
  1680x1050 (0x4c) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1680x1050 (0x4d) 119.000MHz +HSync -VSync
        h: width  1680 start 1728 end 1760 total 1840 skew    0 clock  64.67KHz
        v: height 1050 start 1053 end 1059 total 1080           clock  59.88Hz
  1400x1050 (0x4e) 122.000MHz +HSync +VSync
        h: width  1400 start 1488 end 1640 total 1880 skew    0 clock  64.89KHz
        v: height 1050 start 1052 end 1064 total 1082           clock  59.98Hz
  1600x900 (0x4f) 246.000MHz -HSync +VSync DoubleScan
        h: width  1600 start 1728 end 1900 total 2200 skew    0 clock 111.82KHz
        v: height  900 start  901 end  904 total  932           clock  59.99Hz
  1600x900 (0x50) 186.500MHz +HSync -VSync DoubleScan
        h: width  1600 start 1624 end 1640 total 1680 skew    0 clock 111.01KHz
        v: height  900 start  901 end  904 total  926           clock  59.94Hz
  1600x900 (0x51) 118.250MHz -HSync +VSync
        h: width  1600 start 1696 end 1856 total 2112 skew    0 clock  55.99KHz
        v: height  900 start  903 end  908 total  934           clock  59.95Hz
  1600x900 (0x52) 97.500MHz +HSync -VSync
        h: width  1600 start 1648 end 1680 total 1760 skew    0 clock  55.40KHz
        v: height  900 start  903 end  908 total  926           clock  59.82Hz
  1280x1024 (0x53) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1400x900 (0x54) 103.500MHz -HSync +VSync
        h: width  1400 start 1480 end 1624 total 1848 skew    0 clock  56.01KHz
        v: height  900 start  903 end  913 total  934           clock  59.96Hz
  1400x900 (0x55) 86.500MHz +HSync -VSync
        h: width  1400 start 1448 end 1480 total 1560 skew    0 clock  55.45KHz
        v: height  900 start  903 end  913 total  926           clock  59.88Hz
  1280x960 (0x56) 108.000MHz +HSync +VSync
        h: width  1280 start 1376 end 1488 total 1800 skew    0 clock  60.00KHz
        v: height  960 start  961 end  964 total 1000           clock  60.00Hz
  1440x810 (0x57) 198.125MHz -HSync +VSync DoubleScan
        h: width  1440 start 1548 end 1704 total 1968 skew    0 clock 100.67KHz
        v: height  810 start  811 end  814 total  839           clock  60.00Hz
  1440x810 (0x58) 151.875MHz +HSync -VSync DoubleScan
        h: width  1440 start 1464 end 1480 total 1520 skew    0 clock  99.92KHz
        v: height  810 start  811 end  814 total  833           clock  59.97Hz
  1368x768 (0x59) 85.250MHz -HSync +VSync
        h: width  1368 start 1440 end 1576 total 1784 skew    0 clock  47.79KHz
        v: height  768 start  771 end  781 total  798           clock  59.88Hz
  1368x768 (0x5a) 72.250MHz +HSync -VSync
        h: width  1368 start 1416 end 1448 total 1528 skew    0 clock  47.28KHz
        v: height  768 start  771 end  781 total  790           clock  59.85Hz
  1280x800 (0x5b) 174.250MHz -HSync +VSync DoubleScan
        h: width  1280 start 1380 end 1516 total 1752 skew    0 clock  99.46KHz
        v: height  800 start  801 end  804 total  829           clock  59.99Hz
  1280x800 (0x5c) 134.250MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  98.71KHz
        v: height  800 start  801 end  804 total  823           clock  59.97Hz
  1280x800 (0x5d) 83.500MHz -HSync +VSync
        h: width  1280 start 1352 end 1480 total 1680 skew    0 clock  49.70KHz
        v: height  800 start  803 end  809 total  831           clock  59.81Hz
  1280x800 (0x5e) 71.000MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.31KHz
        v: height  800 start  803 end  809 total  823           clock  59.91Hz
  1280x720 (0x5f) 156.125MHz -HSync +VSync DoubleScan
        h: width  1280 start 1376 end 1512 total 1744 skew    0 clock  89.52KHz
        v: height  720 start  721 end  724 total  746           clock  60.00Hz
  1280x720 (0x60) 120.750MHz +HSync -VSync DoubleScan
        h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  88.79KHz
        v: height  720 start  721 end  724 total  740           clock  59.99Hz
  1280x720 (0x61) 74.500MHz -HSync +VSync
        h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
        v: height  720 start  723 end  728 total  748           clock  59.86Hz
  1280x720 (0x62) 63.750MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  44.27KHz
        v: height  720 start  723 end  728 total  741           clock  59.74Hz
  1024x768 (0x63) 133.475MHz -HSync +VSync DoubleScan
        h: width  1024 start 1100 end 1212 total 1400 skew    0 clock  95.34KHz
        v: height  768 start  768 end  770 total  794           clock  60.04Hz
  1024x768 (0x64) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  960x720 (0x65) 117.000MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1128 total 1300 skew    0 clock  90.00KHz
        v: height  720 start  720 end  722 total  750           clock  60.00Hz
  928x696 (0x66) 109.150MHz -HSync +VSync DoubleScan
        h: width   928 start  976 end 1088 total 1264 skew    0 clock  86.35KHz
        v: height  696 start  696 end  698 total  719           clock  60.05Hz
  896x672 (0x67) 102.400MHz -HSync +VSync DoubleScan
        h: width   896 start  960 end 1060 total 1224 skew    0 clock  83.66KHz
        v: height  672 start  672 end  674 total  697           clock  60.01Hz
  1024x576 (0x68) 98.500MHz -HSync +VSync DoubleScan
        h: width  1024 start 1092 end 1200 total 1376 skew    0 clock  71.58KHz
        v: height  576 start  577 end  580 total  597           clock  59.95Hz
  1024x576 (0x69) 78.375MHz +HSync -VSync DoubleScan
        h: width  1024 start 1048 end 1064 total 1104 skew    0 clock  70.99KHz
        v: height  576 start  577 end  580 total  592           clock  59.96Hz
  1024x576 (0x6a) 46.500MHz -HSync +VSync
        h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
        v: height  576 start  579 end  584 total  599           clock  59.90Hz
  1024x576 (0x6b) 42.000MHz +HSync -VSync
        h: width  1024 start 1072 end 1104 total 1184 skew    0 clock  35.47KHz
        v: height  576 start  579 end  584 total  593           clock  59.82Hz
  960x600 (0x6c) 96.625MHz -HSync +VSync DoubleScan
        h: width   960 start 1028 end 1128 total 1296 skew    0 clock  74.56KHz
        v: height  600 start  601 end  604 total  622           clock  59.93Hz
  960x600 (0x6d) 77.000MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  74.04KHz
        v: height  600 start  601 end  604 total  617           clock  60.00Hz
  960x540 (0x6e) 86.500MHz -HSync +VSync DoubleScan
        h: width   960 start 1024 end 1124 total 1288 skew    0 clock  67.16KHz
        v: height  540 start  541 end  544 total  560           clock  59.96Hz
  960x540 (0x6f) 69.250MHz +HSync -VSync DoubleScan
        h: width   960 start  984 end 1000 total 1040 skew    0 clock  66.59KHz
        v: height  540 start  541 end  544 total  555           clock  59.99Hz
  960x540 (0x70) 40.750MHz -HSync +VSync
        h: width   960 start  992 end 1088 total 1216 skew    0 clock  33.51KHz
        v: height  540 start  543 end  548 total  562           clock  59.63Hz
  960x540 (0x71) 37.250MHz +HSync -VSync
        h: width   960 start 1008 end 1040 total 1120 skew    0 clock  33.26KHz
        v: height  540 start  543 end  548 total  556           clock  59.82Hz
  800x600 (0x72) 81.000MHz +HSync +VSync DoubleScan
        h: width   800 start  832 end  928 total 1080 skew    0 clock  75.00KHz
        v: height  600 start  600 end  602 total  625           clock  60.00Hz
  800x600 (0x73) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x74) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  840x525 (0x75) 73.125MHz -HSync +VSync DoubleScan
        h: width   840 start  892 end  980 total 1120 skew    0 clock  65.29KHz
        v: height  525 start  526 end  529 total  544           clock  60.01Hz
  840x525 (0x76) 59.500MHz +HSync -VSync DoubleScan
        h: width   840 start  864 end  880 total  920 skew    0 clock  64.67KHz
        v: height  525 start  526 end  529 total  540           clock  59.88Hz
  864x486 (0x77) 32.500MHz -HSync +VSync
        h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
        v: height  486 start  489 end  494 total  506           clock  59.92Hz
  864x486 (0x78) 30.500MHz +HSync -VSync
        h: width   864 start  912 end  944 total 1024 skew    0 clock  29.79KHz
        v: height  486 start  489 end  494 total  500           clock  59.57Hz
  700x525 (0x79) 61.000MHz +HSync +VSync DoubleScan
        h: width   700 start  744 end  820 total  940 skew    0 clock  64.89KHz
        v: height  525 start  526 end  532 total  541           clock  59.98Hz
  800x450 (0x7a) 59.125MHz -HSync +VSync DoubleScan
        h: width   800 start  848 end  928 total 1056 skew    0 clock  55.99KHz
        v: height  450 start  451 end  454 total  467           clock  59.95Hz
  800x450 (0x7b) 48.750MHz +HSync -VSync DoubleScan
        h: width   800 start  824 end  840 total  880 skew    0 clock  55.40KHz
        v: height  450 start  451 end  454 total  463           clock  59.82Hz
  640x512 (0x7c) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  664 end  720 total  844 skew    0 clock  63.98KHz
        v: height  512 start  512 end  514 total  533           clock  60.02Hz
  700x450 (0x7d) 51.750MHz -HSync +VSync DoubleScan
        h: width   700 start  740 end  812 total  924 skew    0 clock  56.01KHz
        v: height  450 start  451 end  456 total  467           clock  59.96Hz
  700x450 (0x7e) 43.250MHz +HSync -VSync DoubleScan
        h: width   700 start  724 end  740 total  780 skew    0 clock  55.45KHz
        v: height  450 start  451 end  456 total  463           clock  59.88Hz
  640x480 (0x7f) 54.000MHz +HSync +VSync DoubleScan
        h: width   640 start  688 end  744 total  900 skew    0 clock  60.00KHz
        v: height  480 start  480 end  482 total  500           clock  60.00Hz
  640x480 (0x80) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  720x405 (0x81) 22.500MHz -HSync +VSync
        h: width   720 start  744 end  808 total  896 skew    0 clock  25.11KHz
        v: height  405 start  408 end  413 total  422           clock  59.51Hz
  720x405 (0x82) 21.750MHz +HSync -VSync
        h: width   720 start  768 end  800 total  880 skew    0 clock  24.72KHz
        v: height  405 start  408 end  413 total  419           clock  58.99Hz
  684x384 (0x83) 42.625MHz -HSync +VSync DoubleScan
        h: width   684 start  720 end  788 total  892 skew    0 clock  47.79KHz
        v: height  384 start  385 end  390 total  399           clock  59.88Hz
  684x384 (0x84) 36.125MHz +HSync -VSync DoubleScan
        h: width   684 start  708 end  724 total  764 skew    0 clock  47.28KHz
        v: height  384 start  385 end  390 total  395           clock  59.85Hz
  640x400 (0x85) 41.750MHz -HSync +VSync DoubleScan
        h: width   640 start  676 end  740 total  840 skew    0 clock  49.70KHz
        v: height  400 start  401 end  404 total  415           clock  59.88Hz
  640x400 (0x86) 35.500MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  49.31KHz
        v: height  400 start  401 end  404 total  411           clock  59.98Hz
  640x360 (0x87) 37.250MHz -HSync +VSync DoubleScan
        h: width   640 start  672 end  736 total  832 skew    0 clock  44.77KHz
        v: height  360 start  361 end  364 total  374           clock  59.86Hz
  640x360 (0x88) 31.875MHz +HSync -VSync DoubleScan
        h: width   640 start  664 end  680 total  720 skew    0 clock  44.27KHz
        v: height  360 start  361 end  364 total  370           clock  59.83Hz
  640x360 (0x89) 18.000MHz -HSync +VSync
        h: width   640 start  664 end  720 total  800 skew    0 clock  22.50KHz
        v: height  360 start  363 end  368 total  376           clock  59.84Hz
  640x360 (0x8a) 17.750MHz +HSync -VSync
        h: width   640 start  688 end  720 total  800 skew    0 clock  22.19KHz
        v: height  360 start  363 end  368 total  374           clock  59.32Hz
  512x384 (0x8b) 32.500MHz -HSync -VSync DoubleScan
        h: width   512 start  524 end  592 total  672 skew    0 clock  48.36KHz
        v: height  384 start  385 end  388 total  403           clock  60.00Hz
  512x288 (0x8c) 23.250MHz -HSync +VSync DoubleScan
        h: width   512 start  532 end  580 total  648 skew    0 clock  35.88KHz
        v: height  288 start  289 end  292 total  299           clock  60.00Hz
  512x288 (0x8d) 21.000MHz +HSync -VSync DoubleScan
        h: width   512 start  536 end  552 total  592 skew    0 clock  35.47KHz
        v: height  288 start  289 end  292 total  296           clock  59.92Hz
  480x270 (0x8e) 20.375MHz -HSync +VSync DoubleScan
        h: width   480 start  496 end  544 total  608 skew    0 clock  33.51KHz
        v: height  270 start  271 end  274 total  281           clock  59.63Hz
  480x270 (0x8f) 18.625MHz +HSync -VSync DoubleScan
        h: width   480 start  504 end  520 total  560 skew    0 clock  33.26KHz
        v: height  270 start  271 end  274 total  278           clock  59.82Hz
  400x300 (0x90) 20.000MHz +HSync +VSync DoubleScan
        h: width   400 start  420 end  484 total  528 skew    0 clock  37.88KHz
        v: height  300 start  300 end  302 total  314           clock  60.32Hz
  400x300 (0x91) 18.000MHz +HSync +VSync DoubleScan
        h: width   400 start  412 end  448 total  512 skew    0 clock  35.16KHz
        v: height  300 start  300 end  301 total  312           clock  56.34Hz
  432x243 (0x92) 16.250MHz -HSync +VSync DoubleScan
        h: width   432 start  444 end  484 total  536 skew    0 clock  30.32KHz
        v: height  243 start  244 end  247 total  253           clock  59.92Hz
  432x243 (0x93) 15.250MHz +HSync -VSync DoubleScan
        h: width   432 start  456 end  472 total  512 skew    0 clock  29.79KHz
        v: height  243 start  244 end  247 total  250           clock  59.57Hz
  320x240 (0x94) 12.587MHz -HSync -VSync DoubleScan
        h: width   320 start  328 end  376 total  400 skew    0 clock  31.47KHz
        v: height  240 start  245 end  246 total  262           clock  60.05Hz
  360x202 (0x95) 11.250MHz -HSync +VSync DoubleScan
        h: width   360 start  372 end  404 total  448 skew    0 clock  25.11KHz
        v: height  202 start  204 end  206 total  211           clock  59.51Hz
  360x202 (0x96) 10.875MHz +HSync -VSync DoubleScan
        h: width   360 start  384 end  400 total  440 skew    0 clock  24.72KHz
        v: height  202 start  204 end  206 total  209           clock  59.13Hz
  320x180 (0x97)  9.000MHz -HSync +VSync DoubleScan
        h: width   320 start  332 end  360 total  400 skew    0 clock  22.50KHz
        v: height  180 start  181 end  184 total  188           clock  59.84Hz
  320x180 (0x98)  8.875MHz +HSync -VSync DoubleScan
        h: width   320 start  344 end  360 total  400 skew    0 clock  22.19KHz
        v: height  180 start  181 end  184 total  187           clock  59.32Hz
DP-1 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x42
	Timestamp:  5988844
	Subpixel:   unknown
	Clones:     HDMI-1
	CRTCs:      0 1 2
	           filter:
	HDCP Content Type: HDCP Type0
		supported: HDCP Type0, HDCP Type1
	Content Protection: Undesired
		supported: Undesired, Desired, Enabled
	Colorspace: Default
	max bpc: 12
		range: (6, 12)
	audio: auto
		supported: force-dvi, off, auto, on
	subconnector: Unknown
		supported: Unknown, VGA, DVI-D, HDMI, DP, Wireless, Native
	link-status: Good
	CONNECTOR_ID: 114
		supported: 114
	non-desktop: 0
		range: (0, 1)
HDMI-1 connected 1920x1080+0+0 (0x54c) normal (normal left inverted right x axis y axis) 476mm x 268mm
	Identifier: 0x43
	Timestamp:  5988844
	Subpixel:   unknown
	Gamma:      1.0:1.0:1.0
	Brightness: 1.0
	Clones:     DP-1
	CRTC:       1
	CRTCs:      0 1 2
	           filter:
	EDID:
		00ffffffffffff00220e5c3401010101
		081d010380301b782ae0f5a55552a027
		0c5054a10800d1c081c0a9c0b3009500
		810081800101023a801871382d40582c
		4500dc0c1100001e000000fd00323c1e
		5011000a202020202020000000fc0048
		5020453232330a2020202020000000ff
		00434e43393038304e534a0a202001d2
		020319b149901f041303021211016703
		0c0010000022e2002b023a801871382d
		40582c4500dc0c1100001e011d007251
		d01e206e285500dc0c1100001e8c0ad0
		8a20e02d10103e9600dc0c1100001800
		00000000000000000000000000000000
		00000000000000000000000000000067
	max bpc: 12
		range: (8, 12)
	content type: No Data
		supported: No Data, Graphics, Photo, Cinema, Game
	Colorspace: Default
		supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
	aspect ratio: Automatic
		supported: Automatic, 4:3, 16:9
	audio: auto
	link-status: Good
	CONNECTOR_ID: 124
		supported: 124
	non-desktop: 0
		range: (0, 1)
  1920x1080 (0x54c) 148.500MHz +HSync +VSync *current +preferred
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.50KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  60.00Hz
  1920x1080 (0x54d) 148.500MHz +HSync +VSync
        h: width  1920 start 2448 end 2492 total 2640 skew    0 clock  56.25KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  50.00Hz
  1920x1080 (0x54e) 148.352MHz +HSync +VSync
        h: width  1920 start 2008 end 2052 total 2200 skew    0 clock  67.43KHz
        v: height 1080 start 1084 end 1089 total 1125           clock  59.94Hz
  1600x900 (0x54f) 108.000MHz +HSync +VSync
        h: width  1600 start 1624 end 1704 total 1800 skew    0 clock  60.00KHz
        v: height  900 start  901 end  904 total 1000           clock  60.00Hz
  1440x900 (0x550) 88.750MHz +HSync -VSync
        h: width  1440 start 1488 end 1520 total 1600 skew    0 clock  55.47KHz
        v: height  900 start  903 end  909 total  926           clock  59.90Hz
  1280x720 (0x551) 74.250MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  45.00KHz
        v: height  720 start  725 end  730 total  750           clock  60.00Hz
  1280x720 (0x552) 74.250MHz +HSync +VSync
        h: width  1280 start 1720 end 1760 total 1980 skew    0 clock  37.50KHz
        v: height  720 start  725 end  730 total  750           clock  50.00Hz
  1280x720 (0x553) 74.176MHz +HSync +VSync
        h: width  1280 start 1390 end 1430 total 1650 skew    0 clock  44.96KHz
        v: height  720 start  725 end  730 total  750           clock  59.94Hz
  720x576 (0x554) 27.000MHz -HSync -VSync
        h: width   720 start  732 end  796 total  864 skew    0 clock  31.25KHz
        v: height  576 start  581 end  586 total  625           clock  50.00Hz
  720x480 (0x555) 27.027MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.50KHz
        v: height  480 start  489 end  495 total  525           clock  60.00Hz
  720x480 (0x556) 27.000MHz -HSync -VSync
        h: width   720 start  736 end  798 total  858 skew    0 clock  31.47KHz
        v: height  480 start  489 end  495 total  525           clock  59.94Hz
  640x480 (0x557) 25.200MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.50KHz
        v: height  480 start  490 end  492 total  525           clock  60.00Hz
  720x400 (0x558) 28.320MHz -HSync +VSync
        h: width   720 start  738 end  846 total  900 skew    0 clock  31.47KHz
        v: height  400 start  412 end  414 total  449           clock  70.08Hz
DP-2 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x44
	Timestamp:  5988844
	Subpixel:   unknown
	Clones:
	CRTCs:      0 1 2
	           filter:
	Colorspace: Default
	max bpc: 12
		range: (6, 12)
	audio: auto
	link-status: Good
	CONNECTOR_ID: 130
		supported: 130
	non-desktop: 0
		range: (0, 1)
DP-3 disconnected (normal left inverted right x axis y axis)
	Identifier: 0x45
	Timestamp:  5988844
	Subpixel:   unknown
	Clones:
	CRTCs:      0 1 2
	           filter:
	Colorspace: Default
	max bpc: 12
		range: (6, 12)
	audio: auto
	link-status: Good
	CONNECTOR_ID: 137
		supported: 137
	non-desktop: 0
		range: (0, 1)
Any ideas on how to fix this? I’d love to have a second monitor again, it’s just not the same working without it.
Thanks in advance!
Given the laptop is second hand, it would be good to try and confirm the HDMI port is working. One way to do this is to test it under different conditions and confirm if you get the same result. Using Windows (for testing), for example.
If the issue persists under Windows, then you can probably rule out software/OS being the cause.
What desktop environment are you using? Do you have the option to try a Wayland session instead? If not, you might try booting from the EndeavourOS Live ISO and testing there.
You might also double check the BIOS/UEFI just to confirm there isn’t anything in there that has disabled the HDMI port.
I’m using i3wm with X11 and trying to keep it fairly minimal as it is an older laptop.
I can try with some other ISO but I’d rather not switch to Wayland if possible, I’ve heard of a lot more issues than fixes. At least for the kind of things I’m doing.
I did try the live iso and it was the same problem, creates the virtual screen but no signal actually getting through.
I looked through and I didn’t see anything that seemed related but I don’t really know what I’m looking for so maybe I missed something. What kind of options should I be looking out for?
I’ll try that as soon as I can figure out live iso windows.
