Hi!
First time working with Endeavour OS. Everything is perfect, but the audio is not working in any way (speakers or headphones). I tried activating and unmuting in alsamixer, browsing through KDE audio settings, but it didn’t help.
I also checked audio in some Live distros (Manjaro and Pop!_), I can’t here anything too. On the other side, sound system works fine in Windows 11, so it is not a hardware problem but a configuration problem.
Attaching base logs for system description.
inxi -Fxxc0z | eos-sendlog
Kernel: 6.2.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ZenBook Pro Duo UX582HS_UX582HS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX582HS v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: UX582HS.300 date: 09/15/2021
Battery:
ID-1: BAT0 charge: 26.7 Wh (29.8%) condition: 89.6/92.6 Wh (96.7%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery serial: N/A
status: charging
Device-1: hid-0018:04F3:2C23.0003-battery model: ELAN9009:00 04F3:2C23
serial: N/A charge: N/A status: N/A
Device-2: hid-0018:04F3:2C56.0002-battery model: ELAN9008:00 04F3:2C56
serial: N/A charge: N/A status: discharging
Info: 8-core model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 640 KiB L2: 10 MiB L3: 24 MiB
Speed (MHz): avg: 2500 min/max: 800/4900:4800 cores: 1: 2500 2: 2500
3: 2500 4: 2500 5: 2500 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500
12: 2500 13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79888
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-12.1 ports: active: eDP-1 off: DP-1
empty: DP-2,DP-3,HDMI-A-2 bus-ID: 0000:00:02.0 chip-ID: 8086:9a60
Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: ASUSTeK driver: nvidia v: 530.41.03 arch: Ampere ports: active: none
empty: HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:249c
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-9:2 chip-ID: 13d3:56eb
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96
Monitor-1: DP-1 note: disabled model: BOE Display 0x085f res: N/A dpi: 284
diag: 358mm (14.1")
Monitor-2: eDP-1 pos: primary model: Samsung 0x415f res: 3840x2160
dpi: 284 diag: 395mm (15.5")
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
API: ALSA v: k6.2.10-arch1-1 status: kernel-api
Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Bluetooth:
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-14:3 chip-ID: 8087:0026
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: disabled
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b
Local Storage: total: 953.87 GiB used: 22.43 GiB (2.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL21T0HCLR-00B00
size: 953.87 GiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 42.9 C
ID-1: / size: 319.13 GiB used: 22.15 GiB (6.9%) fs: ext4 dev: /dev/nvme0n1p9
ID-1: swap-1 type: partition size: 32 GiB used: 288 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8
Src: /sys System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 296 Uptime: 1h 23m Memory: 31.05 GiB used: 3.87 GiB (12.5%)
Init: systemd v: 253 default: graphical Compilers: gcc: 12.2.1 Packages:
pm: pacman pkgs: 1003 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
Could you help to localize the problem?
Sorry to say, your audio-hardware is not supported by Linux , as of yet. While the audio-chip as such is being “detected” it apparently still needs to be integrated into the LInux kernel in order to work properly.
xircon
April 13, 2023, 3:11pm
3
My solution to this “problem” was a cheap bluetooth speaker (off Amazon UK).
I’m not a specialist either but it seems to be set to 0 by default.
What happens if you set the kernel parameter
snd_intel_dspcfg.dsp_driver=1
as kernel parameter.
If that works that would be great but that can also have side effects like the microphone not working anymore. It’s just a woraround.
Which bootloader do you have installed?
Grub or Systemdboot?
Thank you for your attentition!
I was trying to use this kernel parameter (bootloader is systemdboot), but it had no result. There was a change in the name of the output device, but I still couldn’t here any sound from the system.
Attaching logs when booting with snd_intel_dspcfg.dsp_driver=1
modinfo snd_hda_intel
filename: /lib/modules/6.2.10-arch1-1/kernel/sound/pci/hda/snd-hda-intel.ko.zst
description: Intel HDA driver
license: GPL
srcversion: 8C2010D4371DBC0DD9C8981
alias: pci:v00001D17d00003288sv*sd*bc*sc*i*
alias: pci:v00001022d*sv*sd*bc04sc03i00*
alias: pci:v00001002d*sv*sd*bc04sc03i00*
alias: pci:v000015ADd00001977sv*sd*bc*sc*i*
alias: pci:v000017F3d00003010sv*sd*bc*sc*i*
alias: pci:v000013F6d00005011sv*sd*bc*sc*i*
alias: pci:v00001102d00000009sv*sd*bc*sc*i*
alias: pci:v00001102d00000012sv*sd*bc*sc*i*
alias: pci:v00001102d00000010sv*sd*bc*sc*i*
alias: pci:v00006549d00002200sv*sd*bc*sc*i*
alias: pci:v00006549d00001200sv*sd*bc*sc*i*
alias: pci:v000010DEd*sv*sd*bc04sc03i00*
alias: pci:v000010B9d00005461sv*sd*bc*sc*i*
alias: pci:v00001039d00007502sv*sd*bc*sc*i*
alias: pci:v00001106d00009140sv*sd*bc*sc*i*
alias: pci:v00001106d00009170sv*sd*bc*sc*i*
alias: pci:v00001106d00003288sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB38sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB30sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB28sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB20sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB18sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB10sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB08sv*sd*bc*sc*i*
alias: pci:v00001002d0000AB00sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAF8sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAF0sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAE8sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAE0sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAD8sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAC8sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAC0sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAB0sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAA8sv*sd*bc*sc*i*
alias: pci:v00001002d0000AAA0sv*sd*bc*sc*i*
alias: pci:v00001002d00009902sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA98sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA90sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA88sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA80sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA68sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA60sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA58sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA50sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA48sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA40sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA38sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA30sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA28sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA20sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA18sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA10sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA08sv*sd*bc*sc*i*
alias: pci:v00001002d0000AA00sv*sd*bc*sc*i*
alias: pci:v00001002d00009840sv*sd*bc*sc*i*
alias: pci:v00001002d0000970Fsv*sd*bc*sc*i*
alias: pci:v00001002d0000960Fsv*sd*bc*sc*i*
alias: pci:v00001002d00007919sv*sd*bc*sc*i*
alias: pci:v00001002d0000793Bsv*sd*bc*sc*i*
alias: pci:v00001002d000015B3sv*sd*bc*sc*i*
alias: pci:v00001002d0000157Asv*sd*bc*sc*i*
alias: pci:v00001002d00001308sv*sd*bc*sc*i*
alias: pci:v00001002d00000002sv*sd*bc*sc*i*
alias: pci:v00001022d000015E3sv*sd*bc*sc*i*
alias: pci:v00001022d0000157Asv*sd*bc*sc*i*
alias: pci:v00001022d00001487sv*sd*bc*sc*i*
alias: pci:v00001022d00001457sv*sd*bc*sc*i*
alias: pci:v00001022d0000780Dsv*sd*bc*sc*i*
alias: pci:v00001002d00004383sv*sd*bc*sc*i*
alias: pci:v00001002d0000437Bsv*sd*bc*sc*i*
alias: pci:v00008086d*sv*sd*bc04sc03i00*
alias: pci:v00008086d00003A6Esv*sd*bc*sc*i*
alias: pci:v00008086d00003A3Esv*sd*bc*sc*i*
alias: pci:v00008086d0000293Fsv*sd*bc*sc*i*
alias: pci:v00008086d0000293Esv*sd*bc*sc*i*
alias: pci:v00008086d0000284Bsv*sd*bc*sc*i*
alias: pci:v00008086d0000269Asv*sd*bc*sc*i*
alias: pci:v00008086d000027D8sv*sd*bc*sc*i*
alias: pci:v00008086d00002668sv*sd*bc*sc*i*
alias: pci:v00008086d00002284sv*sd*bc*sc*i*
alias: pci:v00008086d00000F04sv*sd*bc*sc*i*
alias: pci:v00008086d0000080Asv*sd*bc*sc*i*
alias: pci:v00008086d0000811Bsv*sd*bc*sc*i*
alias: pci:v00008086d00003B57sv*sd*bc*sc*i*
alias: pci:v00008086d00003B56sv*sd*bc*sc*i*
alias: pci:v00008086d0000160Csv*sd*bc*sc*i*
alias: pci:v00008086d00000D0Csv*sd*bc*sc*i*
alias: pci:v00008086d00000C0Csv*sd*bc*sc*i*
alias: pci:v00008086d00000A0Csv*sd*bc*sc*i*
alias: pci:v00008086d00003198sv*sd*bc*sc*i*
alias: pci:v00008086d00001A98sv*sd*bc*sc*i*
alias: pci:v00008086d00005A98sv*sd*bc*sc*i*
alias: pci:v00008086d00007E28sv*sd*bc*sc*i*
alias: pci:v00008086d000051CFsv*sd*bc*sc*i*
alias: pci:v00008086d000051CEsv*sd*bc*sc*i*
alias: pci:v00008086d000051CBsv*sd*bc*sc*i*
alias: pci:v00008086d000051CAsv*sd*bc*sc*i*
alias: pci:v00008086d00007A50sv*sd*bc*sc*i*
alias: pci:v00008086d00004B58sv*sd*bc*sc*i*
alias: pci:v00008086d00004B55sv*sd*bc*sc*i*
alias: pci:v00008086d000054C8sv*sd*bc*sc*i*
alias: pci:v00008086d000051CCsv*sd*bc*sc*i*
alias: pci:v00008086d000051CDsv*sd*bc*sc*i*
alias: pci:v00008086d000051C9sv*sd*bc*sc*i*
alias: pci:v00008086d000051C8sv*sd*bc*sc*i*
alias: pci:v00008086d00007AD0sv*sd*bc*sc*i*
alias: pci:v00008086d00004F92sv*sd*bc*sc*i*
alias: pci:v00008086d00004F91sv*sd*bc*sc*i*
alias: pci:v00008086d00004F90sv*sd*bc*sc*i*
alias: pci:v00008086d0000490Dsv*sd*bc*sc*i*
alias: pci:v00008086d000043C8sv*sd*bc*sc*i*
alias: pci:v00008086d0000A0C8sv*sd*bc*sc*i*
alias: pci:v00008086d00004DC8sv*sd*bc*sc*i*
alias: pci:v00008086d000038C8sv*sd*bc*sc*i*
alias: pci:v00008086d00003DC8sv*sd*bc*sc*i*
alias: pci:v00008086d000034C8sv*sd*bc*sc*i*
alias: pci:v00008086d0000F0C8sv*sd*bc*sc*i*
alias: pci:v00008086d0000A3F0sv*sd*bc*sc*i*
alias: pci:v00008086d0000F1C8sv*sd*bc*sc*i*
alias: pci:v00008086d000006C8sv*sd*bc*sc*i*
alias: pci:v00008086d000002C8sv*sd*bc*sc*i*
alias: pci:v00008086d00009DC8sv*sd*bc*sc*i*
alias: pci:v00008086d0000A348sv*sd*bc*sc*i*
alias: pci:v00008086d0000A2F0sv*sd*bc*sc*i*
alias: pci:v00008086d00009D71sv*sd*bc*sc*i*
alias: pci:v00008086d0000A171sv*sd*bc*sc*i*
alias: pci:v00008086d00009D70sv*sd*bc*sc*i*
alias: pci:v00008086d0000A170sv*sd*bc*sc*i*
alias: pci:v00008086d00009CA0sv*sd*bc*sc*i*
alias: pci:v00008086d00009C21sv*sd*bc*sc*i*
alias: pci:v00008086d00009C20sv*sd*bc*sc*i*
alias: pci:v00008086d0000A270sv*sd*bc*sc*i*
alias: pci:v00008086d0000A1F0sv*sd*bc*sc*i*
alias: pci:v00008086d00008D21sv*sd*bc*sc*i*
alias: pci:v00008086d00008D20sv*sd*bc*sc*i*
alias: pci:v00008086d00008CA0sv*sd*bc*sc*i*
alias: pci:v00008086d00008C20sv*sd*bc*sc*i*
alias: pci:v00008086d00001E20sv*sd*bc*sc*i*
alias: pci:v00008086d00001D20sv*sd*bc*sc*i*
alias: pci:v00008086d00001C20sv*sd*bc*sc*i*
depends: snd-hda-codec,snd-hda-core,snd,snd-pcm,snd-intel-dspcfg
retpoline: Y
intree: Y
vermagic: 6.2.10-arch1-1 SMP preempt mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 0A:22:1F:E6:B0:12:DD:EC:05:08:BA:27:E4:E9:98:7F:6D:CA:0C:1F
sig_hashalgo: sha512
signature: 30:65:02:31:00:88:0A:63:11:E2:F9:B2:4F:14:AB:5F:0A:E8:B3:82:
30:15:9A:5E:22:E9:BD:A7:F5:57:88:44:64:C0:7B:64:A6:6F:76:91:
96:7F:45:D3:61:CA:2A:77:C1:66:43:F4:61:02:30:0B:B5:F9:BC:B1:
E6:E8:E7:89:FB:36:55:AB:F4:7F:E3:68:3A:5B:09:BC:E3:07:44:42:
BD:20:31:6E:7D:55:C5:24:5F:EA:AA:E9:D9:A9:7E:B0:93:B8:26:A0:
D3:E0:58
parm: index:Index value for Intel HD audio interface. (array of int)
parm: id:ID string for Intel HD audio interface. (array of charp)
parm: enable:Enable Intel HD audio interface. (array of bool)
parm: model:Use the given board model. (array of charp)
parm: position_fix:DMA pointer read method.(-1 = system default, 0 = auto, 1 = LPIB, 2 = POSBUF, 3 = VIACOMBO, 4 = COMBO, 5 = SKL+, 6 = FIFO). (array of int)
parm: bdl_pos_adj:BDL position adjustment offset. (array of int)
parm: probe_mask:Bitmask to probe codecs (default = -1). (array of int)
parm: probe_only:Only probing and no codec initialization. (array of int)
parm: jackpoll_ms:Ms between polling for jack events (default = 0, using unsol events only) (array of int)
parm: single_cmd:Use single command to communicate with codecs (for debugging only). (bint)
parm: enable_msi:Enable Message Signaled Interrupt (MSI) (bint)
parm: patch:Patch file for Intel HD audio interface. (array of charp)
parm: beep_mode:Select HDA Beep registration mode (0=off, 1=on) (default=1). (array of bool)
parm: dmic_detect:Allow DSP driver selection (bypass this driver) (0=off, 1=on) (default=1); deprecated, use snd-intel-dspcfg.dsp_driver option instead (bool)
parm: ctl_dev_id:Use control device identifier (based on codec address). (bool)
parm: power_save:Automatic power-saving timeout (in second, 0 = disable). (xint)
parm: pm_blacklist:Enable power-management denylist (bool)
parm: power_save_controller:Reset controller in power save mode. (bool)
parm: align_buffer_size:Force buffer and period sizes to be multiple of 128 bytes. (bint)
parm: snoop:Enable/disable snooping (bint)
snd_intel_dspcfg
filename: /lib/modules/6.2.10-arch1-1/kernel/sound/hda/snd-intel-dspcfg.ko.zst
import_ns: SND_INTEL_SOUNDWIRE_ACPI
description: Intel DSP config driver
license: GPL v2
srcversion: EA519553470D2D5C060BBB5
depends: snd-intel-sdw-acpi
retpoline: Y
intree: Y
sig_id: PKCS#7
signature: 30:65:02:31:00:E2:83:8F:18:74:A4:FA:C9:77:09:DD:B5:01:8F:D1:
69:30:DF:C2:AC:2D:4F:33:A5:DC:CF:06:F3:79:22:19:8F:76:BC:2A:
64:76:7A:C0:27:24:D8:55:18:EA:0C:92:FA:02:30:25:CC:68:89:AA:
15:AE:B5:AC:31:65:71:D3:E4:4C:93:5A:04:EF:A1:08:96:8F:56:53:
86:0C:E0:85:F1:F1:5B:2D:25:BE:B6:A7:89:75:53:47:63:52:53:3E:
1A:41:D1
parm: dsp_driver:Force the DSP driver for Intel DSP (0=auto, 1=legacy, 2=SST, 3=SOF) (int)
inxi -aA
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
class-ID: 0403
API: ALSA v: k6.2.10-arch1-1 status: kernel-api tools: alsamixer,amixer
Just see the first two answers to your original post. It is all…
It was worth a try, wasn’t it?
When did you try this and did you also
sudo reinstall-kernels
kernels?
Wiki
Did you ever care to read this?
anon11595408:
Yes I did it, it didn’t succeed.
Also I tried editing load parameters while loading (‘e’ key, then append this parameter), same result.
Thank you all for helping with my problem.
After browsing the internet, I found several threads about audio on Asus Laptops. It seems that currently there is no sound in Linux when using Asus Zenbook laptops (links 1 2 ). Possibly, Asus can fix it via a new BIOS update link . This problem can be fixed on some models via different hacks (for example this Reddit thread ). Some users succeeded when using custom kernels and quirks (although there already are some audio quirks in the kernel for different Asus laptops). Unfortunately, there is no quirk for my model, UX582HS.
There was an article about word sniffing from windows to get the correct parameters for the audio card via hda-verb link . If I understood the forums correctly, performing all the manipulations and getting the correct hex-values for hda-verb may help. But I think that it is too complex.
Also, there is an article on asus-linux.org . I tried all the recomendations, but they didn’t work (although I can hear some strange noise in headphones at max volume after all this manipulations). https://asus-linux.org/blog/sound-2021-01-11/ . There is a discord link on this website with many other ideas about sound, but they also didn’t work for me…
