Laptop 2nd monitor not recognized
I’ve had good luck with Nvidia cards on both my laptop and my son’s laptop (mine is a 960 and his a 1660 which use the same driver) until now. Both run Cinnamon EndeavorOS and were installed a few years ago with Windows dual boot as well. I have always used 3 external monitors plus the laptop monitor. They recognized immediately using the proprietary Nvidia install. He has never wanted to use an external until now and it worked perfectly with proprietary install. He asked if he could use a spare monitor of mine yesterday that I used perfectly on a non-Nvidia laptop running Endevour Budgie. I first installed the new monitor in Windows and everything was fine, so I know the connection and cable (HDMI) are fine. I booted into Linux, and I can’t even recognize the external monitor. The laptop monitor is still OK, so luckily there is time. Any advice would be great.
Optimus laptops often have similar issues, depending on Vendor and Model, because external ports are usually connected to the dGPU.
So, HW/SW info is important to start an assessment.
Read this and send at least the inxi part and Xorg.0.log.
Also check if there is more than one Xorg log in /var/log/, excluding .old ones for now.
[adrian@adrian-xenia159geni71660ti ~]$ inxi -Fxxc0z --no-host | eos-sendlog
% Total % Received % Xferd Average Speed Time Time Time Current
100 4264 0 24 100 4240 57 10195 --:–:-- --:–:-- --:–:-- 10274
https://clbin.com/Tj2mA
Only Xorg.0.log and Xorg.0.log.old in var/log.
Can you edit your post by putting the text within code blocks by clicking
or enclosing like this
text
It makes the logs readable for people who want to help.
[     4.487]
X.Org X Server 1.21.1.3
X Protocol Version 11, Revision 0
[     4.487] Current Operating System: Linux adrian-xenia159geni71660ti 5.17.5-arch1-1 #1 SMP PREEMPT Wed, 27 Apr 2022 20:56:11 +0000 x86_64
[     4.487] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=e856e9b5-2f31-47e5-b310-caac9b4d2c2a rw rootflags=subvol=@ quiet loglevel=3 nowatchdog
[     4.487]
[     4.487] Current version of pixman: 0.40.0
[     4.487] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     4.487] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     4.487] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May  1 10:14:47 2022
[     4.488] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.488] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.488] (==) No Layout section.  Using the first Screen section.
[     4.488] (==) No screen section available. Using defaults.
[     4.488] (**) |-->Screen "Default Screen Section" (0)
[     4.488] (**) |   |-->Monitor "<default monitor>"
[     4.488] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[     4.488] (==) Automatically adding devices
[     4.488] (==) Automatically enabling devices
[     4.488] (==) Automatically adding GPU devices
[     4.488] (==) Automatically binding GPU devices
[     4.488] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.488] (WW) The directory "/usr/share/fonts/misc" does not exist.
[     4.488] 	Entry deleted from font path.
[     4.489] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[     4.489] 	Entry deleted from font path.
[     4.489] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[     4.489] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.489] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.489] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     4.489] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     4.489] (==) FontPath set to:
[     4.489] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.489] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     4.489] (II) Module ABI versions:
[     4.489] 	X.Org ANSI C Emulation: 0.4
[     4.489] 	X.Org Video Driver: 25.2
[     4.489] 	X.Org XInput driver : 24.4
[     4.489] 	X.Org Server Extension : 10.0
[     4.489] (++) using VT number 7
[     4.489] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.489] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.489] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     4.489] (II) xfree86: Adding drm device (/dev/dri/card1)
[     4.490] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
[     4.493] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     4.494] (--) PCI:*(0@0:2:0) 8086:3e9b:8086:2086 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00007000/64, BIOS @ 0x????????/131072
[     4.494] (--) PCI: (1@0:0:0) 10de:2191:8086:2086 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/524288
[     4.494] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.494] (II) LoadModule: "glx"
[     4.495] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.500] (II) Module glx: vendor="X.Org Foundation"
[     4.500] 	compiled for 1.21.1.3, module version = 1.0.0
[     4.500] 	ABI class: X.Org Server Extension, version 10.0
[     4.500] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[     4.500] 	loading driver: nvidia
[     4.500] (==) Matched intel as autoconfigured driver 0
[     4.500] (==) Matched nvidia as autoconfigured driver 1
[     4.500] (==) Matched nouveau as autoconfigured driver 2
[     4.500] (==) Matched nv as autoconfigured driver 3
[     4.500] (==) Matched modesetting as autoconfigured driver 4
[     4.500] (==) Matched fbdev as autoconfigured driver 5
[     4.500] (==) Matched vesa as autoconfigured driver 6
[     4.500] (==) Assigned the driver to the xf86ConfigLayout
[     4.500] (II) LoadModule: "intel"
[     4.501] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     4.503] (II) Module intel: vendor="X.Org Foundation"
[     4.503] 	compiled for 1.21.1.1, module version = 2.99.917
[     4.503] 	Module class: X.Org Video Driver
[     4.503] 	ABI class: X.Org Video Driver, version 25.2
[     4.503] (II) LoadModule: "nvidia"
[     4.503] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     4.503] (EE) Failed to load /usr/lib/xorg/modules/drivers/nvidia_drv.so: /usr/lib/xorg/modules/drivers/nvidia_drv.so: invalid ELF header
[     4.503] (EE) Failed to load module "nvidia" (loader failed, 0)
[     4.503] (II) LoadModule: "nouveau"
[     4.504] (WW) Warning, couldn't open module nouveau
[     4.504] (EE) Failed to load module "nouveau" (module does not exist, 0)
[     4.504] (II) LoadModule: "nv"
[     4.504] (WW) Warning, couldn't open module nv
[     4.504] (EE) Failed to load module "nv" (module does not exist, 0)
[     4.504] (II) LoadModule: "modesetting"
[     4.504] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     4.506] (II) Module modesetting: vendor="X.Org Foundation"
[     4.506] 	compiled for 1.21.1.3, module version = 1.21.1
[     4.506] 	Module class: X.Org Video Driver
[     4.506] 	ABI class: X.Org Video Driver, version 25.2
[     4.506] (II) LoadModule: "fbdev"
[     4.506] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     4.506] (II) Module fbdev: vendor="X.Org Foundation"
[     4.506] 	compiled for 1.21.1.1, module version = 0.5.0
[     4.506] (II) LoadModule: "vesa"
[     4.506] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     4.507] (II) Module vesa: vendor="X.Org Foundation"
[     4.507] 	compiled for 1.21.1.1, module version = 2.5.0
[     4.507] 	Module class: X.Org Video Driver
[     4.507] 	ABI class: X.Org Video Driver, version 25.2
[     4.507] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
	i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
	915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
	Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
	GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     4.507] (II) intel: Driver for Intel(R) HD Graphics
[     4.507] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     4.507] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     4.508] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     4.508] (II) FBDEV: driver for framebuffer: fbdev
[     4.508] (II) VESA: driver for VESA chipsets: vesa
[     4.516] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[     4.516] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[     4.516] (WW) Falling back to old probe method for modesetting
[     4.516] (WW) Falling back to old probe method for fbdev
[     4.516] (II) Loading sub module "fbdevhw"
[     4.516] (II) LoadModule: "fbdevhw"
[     4.516] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     4.517] (II) Module fbdevhw: vendor="X.Org Foundation"
[     4.517] 	compiled for 1.21.1.3, module version = 0.0.2
[     4.517] 	ABI class: X.Org Video Driver, version 25.2
[     4.517] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[     4.517] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 6 threads
[     4.517] (II) intel(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     4.517] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     4.517] (==) intel(0): RGB weight 888
[     4.517] (==) intel(0): Default visual is TrueColor
[     4.517] (II) intel(0): Output eDP1 has no monitor section
[     4.518] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[     4.518] (II) intel(0): Enabled output eDP1
[     4.518] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     4.518] (II) intel(0): Output VIRTUAL1 has no monitor section
[     4.518] (II) intel(0): Enabled output VIRTUAL1
[     4.518] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[     4.518] (==) intel(0): TearFree enabled
[     4.518] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.518] (==) intel(0): DPI set to (96, 96)
[     4.518] (II) Loading sub module "dri3"
[     4.518] (II) LoadModule: "dri3"
[     4.518] (II) Module "dri3" already built-in
[     4.518] (II) Loading sub module "dri2"
[     4.518] (II) LoadModule: "dri2"
[     4.518] (II) Module "dri2" already built-in
[     4.518] (II) Loading sub module "present"
[     4.518] (II) LoadModule: "present"
[     4.518] (II) Module "present" already built-in
[     4.518] (II) UnloadModule: "fbdev"
[     4.518] (II) Unloading fbdev
[     4.518] (II) UnloadSubModule: "fbdevhw"
[     4.518] (II) Unloading fbdevhw
[     4.518] (II) UnloadModule: "vesa"
[     4.518] (II) Unloading vesa
[     4.518] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[     4.518] (==) intel(0): Backing store enabled
[     4.518] (==) intel(0): Silken mouse enabled
[     4.518] (II) intel(0): HW Cursor enabled
[     4.518] (==) intel(0): DPMS enabled
[     4.518] (==) intel(0): Display hotplug detection enabled
[     4.518] (II) intel(0): [DRI2] Setup complete
[     4.518] (II) intel(0): [DRI2]   DRI driver: i965
[     4.518] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     4.518] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     4.518] (II) intel(0): hardware support for Present enabled
[     4.518] (II) Initializing extension Generic Event Extension
[     4.519] (II) Initializing extension SHAPE
[     4.519] (II) Initializing extension MIT-SHM
[     4.519] (II) Initializing extension XInputExtension
[     4.519] (II) Initializing extension XTEST
[     4.519] (II) Initializing extension BIG-REQUESTS
[     4.519] (II) Initializing extension SYNC
[     4.519] (II) Initializing extension XKEYBOARD
[     4.519] (II) Initializing extension XC-MISC
[     4.519] (II) Initializing extension SECURITY
[     4.519] (II) Initializing extension XFIXES
[     4.519] (II) Initializing extension RENDER
[     4.519] (II) Initializing extension RANDR
[     4.520] (II) Initializing extension COMPOSITE
[     4.520] (II) Initializing extension DAMAGE
[     4.520] (II) Initializing extension MIT-SCREEN-SAVER
[     4.520] (II) Initializing extension DOUBLE-BUFFER
[     4.520] (II) Initializing extension RECORD
[     4.520] (II) Initializing extension DPMS
[     4.520] (II) Initializing extension Present
[     4.520] (II) Initializing extension DRI3
[     4.520] (II) Initializing extension X-Resource
[     4.520] (II) Initializing extension XVideo
[     4.520] (II) Initializing extension XVideo-MotionCompensation
[     4.520] (II) Initializing extension GLX
[     4.521] (EE) AIGLX error: dlopen of /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: cannot open shared object file: No such file or directory)
[     4.521] (EE) AIGLX error: unable to load driver i965
[     4.672] (II) IGLX: Loaded and initialized swrast
[     4.672] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[     4.672] (II) Initializing extension XFree86-VidModeExtension
[     4.673] (II) Initializing extension XFree86-DGA
[     4.673] (II) Initializing extension XFree86-DRI
[     4.673] (II) Initializing extension DRI2
[     4.680] (II) intel(0): switch to mode 1920x1080@144.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     4.686] (II) intel(0): Setting screen physical size to 508 x 285
[     4.759] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     4.759] (**) Power Button: Applying InputClass "devname"
[     4.759] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.759] (**) Power Button: Applying InputClass "system-keyboard"
[     4.759] (II) LoadModule: "libinput"
[     4.759] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     4.763] (II) Module libinput: vendor="X.Org Foundation"
[     4.763] 	compiled for 1.21.1.3, module version = 1.2.1
[     4.763] 	Module class: X.Org XInput Driver
[     4.763] 	ABI class: X.Org XInput driver, version 24.4
[     4.763] (II) Using input driver 'libinput' for 'Power Button'
[     4.763] (**) Power Button: always reports core events
[     4.763] (**) Option "Device" "/dev/input/event3"
[     4.767] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     4.767] (II) event3  - Power Button: device is a keyboard
[     4.767] (II) event3  - Power Button: device removed
[     4.794] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[     4.794] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     4.794] (**) Option "xkb_layout" "us"
[     4.796] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     4.796] (II) event3  - Power Button: device is a keyboard
[     4.798] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[     4.798] (**) Video Bus: Applying InputClass "devname"
[     4.798] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     4.798] (**) Video Bus: Applying InputClass "system-keyboard"
[     4.798] (II) Using input driver 'libinput' for 'Video Bus'
[     4.798] (**) Video Bus: always reports core events
[     4.798] (**) Option "Device" "/dev/input/event8"
[     4.800] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[     4.801] (II) event8  - Video Bus: device is a keyboard
[     4.801] (II) event8  - Video Bus: device removed
[     4.887] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event8"
[     4.887] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     4.887] (**) Option "xkb_layout" "us"
[     4.889] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[     4.890] (II) event8  - Video Bus: device is a keyboard
[     4.892] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[     4.892] (**) Video Bus: Applying InputClass "devname"
[     4.892] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     4.892] (**) Video Bus: Applying InputClass "system-keyboard"
[     4.892] (II) Using input driver 'libinput' for 'Video Bus'
[     4.892] (**) Video Bus: always reports core events
[     4.892] (**) Option "Device" "/dev/input/event9"
[     4.895] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[     4.896] (II) event9  - Video Bus: device is a keyboard
[     4.896] (II) event9  - Video Bus: device removed
[     4.940] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input9/event9"
[     4.940] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     4.940] (**) Option "xkb_layout" "us"
[     4.943] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[     4.943] (II) event9  - Video Bus: device is a keyboard
[     4.945] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     4.945] (**) Power Button: Applying InputClass "devname"
[     4.945] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.945] (**) Power Button: Applying InputClass "system-keyboard"
[     4.945] (II) Using input driver 'libinput' for 'Power Button'
[     4.945] (**) Power Button: always reports core events
[     4.945] (**) Option "Device" "/dev/input/event1"
[     4.947] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.948] (II) event1  - Power Button: device is a keyboard
[     4.948] (II) event1  - Power Button: device removed
[     4.977] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     4.977] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     4.977] (**) Option "xkb_layout" "us"
[     4.979] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     4.980] (II) event1  - Power Button: device is a keyboard
[     4.981] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[     4.981] (**) Lid Switch: Applying InputClass "devname"
[     4.981] (II) Using input driver 'libinput' for 'Lid Switch'
[     4.981] (**) Lid Switch: always reports core events
[     4.981] (**) Option "Device" "/dev/input/event2"
[     4.983] (II) event2  - Lid Switch: is tagged by udev as: Switch
[     4.983] (II) event2  - Lid Switch: device is a switch device
[     4.984] (II) event2  - Lid Switch: device is a switch device
[     4.984] (II) event2  - Lid Switch: device removed
[     5.014] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2/event2"
[     5.014] (II) XINPUT: Adding extended input device "Lid Switch" (type: KEYBOARD, id 10)
[     5.016] (II) event2  - Lid Switch: is tagged by udev as: Switch
[     5.016] (II) event2  - Lid Switch: device is a switch device
[     5.018] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     5.018] (**) Sleep Button: Applying InputClass "devname"
[     5.018] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     5.018] (**) Sleep Button: Applying InputClass "system-keyboard"
[     5.018] (II) Using input driver 'libinput' for 'Sleep Button'
[     5.018] (**) Sleep Button: always reports core events
[     5.018] (**) Option "Device" "/dev/input/event0"
[     5.020] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     5.020] (II) event0  - Sleep Button: device is a keyboard
[     5.020] (II) event0  - Sleep Button: device removed
[     5.067] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     5.067] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
[     5.067] (**) Option "xkb_layout" "us"
[     5.070] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     5.070] (II) event0  - Sleep Button: device is a keyboard
[     5.072] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event5)
[     5.072] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[     5.072] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[     5.072] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[     5.072] (**) Option "Device" "/dev/input/event5"
[     5.075] (II) event5  - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[     5.137] (II) event5  - not using input device '/dev/input/event5'.
[     5.137] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event5
[     5.137] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[     5.137] (II) UnloadModule: "libinput"
[     5.138] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event6)
[     5.138] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[     5.138] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[     5.138] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[     5.138] (**) Option "Device" "/dev/input/event6"
[     5.141] (II) event6  - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[     5.193] (II) event6  - not using input device '/dev/input/event6'.
[     5.194] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event6
[     5.194] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[     5.194] (II) UnloadModule: "libinput"
[     5.196] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event10)
[     5.196] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[     5.196] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[     5.196] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[     5.196] (**) Option "Device" "/dev/input/event10"
[     5.198] (II) event10 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[     5.257] (II) event10 - not using input device '/dev/input/event10'.
[     5.257] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event10
[     5.257] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[     5.257] (II) UnloadModule: "libinput"
[     5.259] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event11)
[     5.259] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[     5.259] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[     5.259] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[     5.259] (**) Option "Device" "/dev/input/event11"
[     5.261] (II) event11 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[     5.314] (II) event11 - not using input device '/dev/input/event11'.
[     5.314] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event11
[     5.314] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[     5.314] (II) UnloadModule: "libinput"
[     5.314] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event12)
[     5.314] (**) HDA NVidia HDMI/DP,pcm=10: Applying InputClass "devname"
[     5.314] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=10'
[     5.314] (**) HDA NVidia HDMI/DP,pcm=10: always reports core events
[     5.314] (**) Option "Device" "/dev/input/event12"
[     5.315] (II) event12 - HDA NVidia HDMI/DP,pcm=10: is tagged by udev as: Switch
[     5.347] (II) event12 - not using input device '/dev/input/event12'.
[     5.347] (EE) libinput: HDA NVidia HDMI/DP,pcm=10: Failed to create a device for /dev/input/event12
[     5.347] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=10"
[     5.347] (II) UnloadModule: "libinput"
[     5.348] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event13)
[     5.348] (**) HDA NVidia HDMI/DP,pcm=11: Applying InputClass "devname"
[     5.348] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=11'
[     5.348] (**) HDA NVidia HDMI/DP,pcm=11: always reports core events
[     5.348] (**) Option "Device" "/dev/input/event13"
[     5.349] (II) event13 - HDA NVidia HDMI/DP,pcm=11: is tagged by udev as: Switch
[     5.384] (II) event13 - not using input device '/dev/input/event13'.
[     5.384] (EE) libinput: HDA NVidia HDMI/DP,pcm=11: Failed to create a device for /dev/input/event13
[     5.384] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=11"
[     5.384] (II) UnloadModule: "libinput"
[     5.386] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Mouse (/dev/input/event14)
[     5.386] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "devname"
[     5.387] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "libinput pointer catchall"
[     5.387] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Mouse'
[     5.387] (**) UNIW0001:00 093A:1336 Mouse: always reports core events
[     5.387] (**) Option "Device" "/dev/input/event14"
[     5.390] (II) event14 - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     5.391] (II) event14 - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     5.393] (II) event14 - UNIW0001:00 093A:1336 Mouse: device removed
[     5.431] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input16/event14"
[     5.431] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Mouse" (type: MOUSE, id 12)
[     5.431] (**) Option "AccelerationScheme" "none"
[     5.431] (**) UNIW0001:00 093A:1336 Mouse: (accel) selected scheme none/0
[     5.431] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration factor: 2.000
[     5.431] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration threshold: 4
[     5.435] (II) event14 - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     5.435] (II) event14 - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     5.436] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Mouse (/dev/input/mouse0)
[     5.436] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "devname"
[     5.436] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Mouse'
[     5.436] (**) UNIW0001:00 093A:1336 Mouse: always reports core events
[     5.436] (**) Option "Device" "/dev/input/mouse0"
[     5.484] (II) mouse0  - not using input device '/dev/input/mouse0'.
[     5.484] (EE) libinput: UNIW0001:00 093A:1336 Mouse: Failed to create a device for /dev/input/mouse0
[     5.484] (EE) PreInit returned 2 for "UNIW0001:00 093A:1336 Mouse"
[     5.484] (II) UnloadModule: "libinput"
[     5.485] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Touchpad (/dev/input/event15)
[     5.485] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "devname"
[     5.485] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "libinput touchpad catchall"
[     5.485] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Touchpad'
[     5.485] (**) UNIW0001:00 093A:1336 Touchpad: always reports core events
[     5.485] (**) Option "Device" "/dev/input/event15"
[     5.487] (II) event15 - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     5.491] (II) event15 - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     5.491] (II) event15 - UNIW0001:00 093A:1336 Touchpad: device removed
[     5.547] (**) Option "Tapping" "on"
[     5.547] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input17/event15"
[     5.547] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Touchpad" (type: TOUCHPAD, id 13)
[     5.549] (**) Option "AccelerationScheme" "none"
[     5.549] (**) UNIW0001:00 093A:1336 Touchpad: (accel) selected scheme none/0
[     5.549] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration factor: 2.000
[     5.549] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration threshold: 4
[     5.550] (II) event15 - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     5.552] (II) event15 - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     5.553] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Touchpad (/dev/input/mouse1)
[     5.553] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "devname"
[     5.553] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Touchpad'
[     5.553] (**) UNIW0001:00 093A:1336 Touchpad: always reports core events
[     5.553] (**) Option "Device" "/dev/input/mouse1"
[     5.627] (II) mouse1  - not using input device '/dev/input/mouse1'.
[     5.627] (EE) libinput: UNIW0001:00 093A:1336 Touchpad: Failed to create a device for /dev/input/mouse1
[     5.627] (EE) PreInit returned 2 for "UNIW0001:00 093A:1336 Touchpad"
[     5.627] (II) UnloadModule: "libinput"
[     5.629] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event16)
[     5.629] (**) HDA Intel PCH Mic: Applying InputClass "devname"
[     5.629] (II) Using input driver 'libinput' for 'HDA Intel PCH Mic'
[     5.629] (**) HDA Intel PCH Mic: always reports core events
[     5.629] (**) Option "Device" "/dev/input/event16"
[     5.631] (II) event16 - HDA Intel PCH Mic: is tagged by udev as: Switch
[     5.670] (II) event16 - not using input device '/dev/input/event16'.
[     5.670] (EE) libinput: HDA Intel PCH Mic: Failed to create a device for /dev/input/event16
[     5.670] (EE) PreInit returned 2 for "HDA Intel PCH Mic"
[     5.670] (II) UnloadModule: "libinput"
[     5.672] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event17)
[     5.672] (**) HDA Intel PCH Headphone: Applying InputClass "devname"
[     5.672] (II) Using input driver 'libinput' for 'HDA Intel PCH Headphone'
[     5.672] (**) HDA Intel PCH Headphone: always reports core events
[     5.672] (**) Option "Device" "/dev/input/event17"
[     5.674] (II) event17 - HDA Intel PCH Headphone: is tagged by udev as: Switch
[     5.717] (II) event17 - not using input device '/dev/input/event17'.
[     5.717] (EE) libinput: HDA Intel PCH Headphone: Failed to create a device for /dev/input/event17
[     5.717] (EE) PreInit returned 2 for "HDA Intel PCH Headphone"
[     5.717] (II) UnloadModule: "libinput"
[     5.719] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event18)
[     5.719] (**) HDA Intel PCH HDMI/DP,pcm=3: Applying InputClass "devname"
[     5.719] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=3'
[     5.719] (**) HDA Intel PCH HDMI/DP,pcm=3: always reports core events
[     5.719] (**) Option "Device" "/dev/input/event18"
[     5.721] (II) event18 - HDA Intel PCH HDMI/DP,pcm=3: is tagged by udev as: Switch
[     5.784] (II) event18 - not using input device '/dev/input/event18'.
[     5.784] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=3: Failed to create a device for /dev/input/event18
[     5.784] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=3"
[     5.784] (II) UnloadModule: "libinput"
[     5.785] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event19)
[     5.785] (**) HDA Intel PCH HDMI/DP,pcm=7: Applying InputClass "devname"
[     5.785] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=7'
[     5.785] (**) HDA Intel PCH HDMI/DP,pcm=7: always reports core events
[     5.785] (**) Option "Device" "/dev/input/event19"
[     5.788] (II) event19 - HDA Intel PCH HDMI/DP,pcm=7: is tagged by udev as: Switch
[     5.830] (II) event19 - not using input device '/dev/input/event19'.
[     5.830] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=7: Failed to create a device for /dev/input/event19
[     5.831] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=7"
[     5.831] (II) UnloadModule: "libinput"
[     5.832] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event20)
[     5.832] (**) HDA Intel PCH HDMI/DP,pcm=8: Applying InputClass "devname"
[     5.832] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=8'
[     5.832] (**) HDA Intel PCH HDMI/DP,pcm=8: always reports core events
[     5.832] (**) Option "Device" "/dev/input/event20"
[     5.834] (II) event20 - HDA Intel PCH HDMI/DP,pcm=8: is tagged by udev as: Switch
[     5.874] (II) event20 - not using input device '/dev/input/event20'.
[     5.874] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=8: Failed to create a device for /dev/input/event20
[     5.874] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=8"
[     5.874] (II) UnloadModule: "libinput"
[     5.875] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event21)
[     5.875] (**) HDA Intel PCH HDMI/DP,pcm=9: Applying InputClass "devname"
[     5.875] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=9'
[     5.875] (**) HDA Intel PCH HDMI/DP,pcm=9: always reports core events
[     5.875] (**) Option "Device" "/dev/input/event21"
[     5.878] (II) event21 - HDA Intel PCH HDMI/DP,pcm=9: is tagged by udev as: Switch
[     5.917] (II) event21 - not using input device '/dev/input/event21'.
[     5.917] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=9: Failed to create a device for /dev/input/event21
[     5.917] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=9"
[     5.917] (II) UnloadModule: "libinput"
[     5.918] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event22)
[     5.919] (**) HDA Intel PCH HDMI/DP,pcm=10: Applying InputClass "devname"
[     5.919] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=10'
[     5.919] (**) HDA Intel PCH HDMI/DP,pcm=10: always reports core events
[     5.919] (**) Option "Device" "/dev/input/event22"
[     5.921] (II) event22 - HDA Intel PCH HDMI/DP,pcm=10: is tagged by udev as: Switch
[     5.960] (II) event22 - not using input device '/dev/input/event22'.
[     5.960] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=10: Failed to create a device for /dev/input/event22
[     5.960] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=10"
[     5.960] (II) UnloadModule: "libinput"
[     5.962] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[     5.962] (**) AT Translated Set 2 keyboard: Applying InputClass "devname"
[     5.962] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     5.962] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     5.962] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     5.962] (**) AT Translated Set 2 keyboard: always reports core events
[     5.962] (**) Option "Device" "/dev/input/event4"
[     5.965] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     5.965] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     5.968] (II) event4  - AT Translated Set 2 keyboard: device removed
[     5.987] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[     5.987] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
[     5.987] (**) Option "xkb_layout" "us"
[     5.990] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     5.991] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     5.995] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     5.995] (**) PC Speaker: Applying InputClass "devname"
[     5.995] (II) Using input driver 'libinput' for 'PC Speaker'
[     5.995] (**) PC Speaker: always reports core events
[     5.995] (**) Option "Device" "/dev/input/event7"
[     5.997] (II) event7  - PC Speaker: not tagged as supported input device
[     6.040] (II) event7  - not using input device '/dev/input/event7'.
[     6.040] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event7
[     6.041] (EE) PreInit returned 2 for "PC Speaker"
[     6.041] (II) UnloadModule: "libinput"
[     6.519] (II) intel(0): EDID vendor "BOE", prod id 2125
[     6.519] (II) intel(0): Printing DDC gathered Modelines:
[     6.519] (II) intel(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[     6.699] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse (/dev/input/mouse3)
[     6.699] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[     6.699] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse'
[     6.699] (**) Logitech G203 LIGHTSYNC Gaming Mouse: always reports core events
[     6.699] (**) Option "Device" "/dev/input/mouse3"
[     6.827] (II) mouse3  - not using input device '/dev/input/mouse3'.
[     6.827] (EE) libinput: Logitech G203 LIGHTSYNC Gaming Mouse: Failed to create a device for /dev/input/mouse3
[     6.827] (EE) PreInit returned 2 for "Logitech G203 LIGHTSYNC Gaming Mouse"
[     6.827] (II) UnloadModule: "libinput"
[     6.827] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse Keyboard (/dev/input/event29)
[     6.827] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[     6.827] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.827] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     6.827] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse Keyboard'
[     6.827] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[     6.827] (**) Option "Device" "/dev/input/event29"
[     6.828] (II) event29 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     6.828] (II) event29 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[     6.829] (II) event29 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device removed
[     6.853] (II) libinput: Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: needs a virtual subdevice
[     6.854] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046D:C092.0006/input/input32/event29"
[     6.854] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse Keyboard" (type: MOUSE, id 15)
[     6.854] (**) Option "AccelerationScheme" "none"
[     6.854] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) selected scheme none/0
[     6.854] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[     6.854] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[     6.855] (II) event29 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     6.855] (II) event29 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[     6.856] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[     6.856] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     6.856] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     6.856] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse Keyboard'
[     6.856] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[     6.856] (**) Option "Device" "/dev/input/event29"
[     6.856] (II) libinput: Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is a virtual subdevice
[     6.856] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046D:C092.0006/input/input32/event29"
[     6.856] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse Keyboard" (type: KEYBOARD, id 16)
[     6.856] (**) Option "xkb_layout" "us"
[     6.857] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse (/dev/input/event28)
[     6.857] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[     6.857] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     6.857] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse'
[     6.857] (**) Logitech G203 LIGHTSYNC Gaming Mouse: always reports core events
[     6.857] (**) Option "Device" "/dev/input/event28"
[     6.914] (II) event28 - Logitech G203 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[     6.915] (II) event28 - Logitech G203 LIGHTSYNC Gaming Mouse: device is a pointer
[     6.915] (II) event28 - Logitech G203 LIGHTSYNC Gaming Mouse: device removed
[     6.984] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:046D:C092.0005/input/input31/event28"
[     6.984] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse" (type: MOUSE, id 17)
[     6.984] (**) Option "AccelerationScheme" "none"
[     6.985] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) selected scheme none/0
[     6.985] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) acceleration factor: 2.000
[     6.985] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) acceleration threshold: 4
[     7.047] (II) event28 - Logitech G203 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[     7.047] (II) event28 - Logitech G203 LIGHTSYNC Gaming Mouse: device is a pointer
[     7.051] (II) config/udev: Adding input device Cosair Corsair VOID Surround USB Sound Adapter Consumer Control (/dev/input/event30)
[     7.051] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "devname"
[     7.051] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "libinput keyboard catchall"
[     7.051] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "system-keyboard"
[     7.051] (II) Using input driver 'libinput' for 'Cosair Corsair VOID Surround USB Sound Adapter Consumer Control'
[     7.051] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: always reports core events
[     7.051] (**) Option "Device" "/dev/input/event30"
[     7.055] (II) event30 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: is tagged by udev as: Keyboard
[     7.055] (II) event30 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device is a keyboard
[     7.056] (II) event30 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device removed
[     7.150] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.3/0003:1B1C:0A30.0007/input/input35/event30"
[     7.150] (II) XINPUT: Adding extended input device "Cosair Corsair VOID Surround USB Sound Adapter Consumer Control" (type: KEYBOARD, id 18)
[     7.150] (**) Option "xkb_layout" "us"
[     7.155] (II) event30 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: is tagged by udev as: Keyboard
[     7.155] (II) event30 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device is a keyboard
[     7.158] (II) config/udev: Adding input device Cosair Corsair VOID Surround USB Sound Adapter (/dev/input/event31)
[     7.158] (**) Cosair Corsair VOID Surround USB Sound Adapter: Applying InputClass "devname"
[     7.158] (II) Using input driver 'libinput' for 'Cosair Corsair VOID Surround USB Sound Adapter'
[     7.158] (**) Cosair Corsair VOID Surround USB Sound Adapter: always reports core events
[     7.159] (**) Option "Device" "/dev/input/event31"
[     7.162] (II) event31 - Cosair Corsair VOID Surround USB Sound Adapter: not tagged as supported input device
[     7.217] (II) event31 - not using input device '/dev/input/event31'.
[     7.217] (EE) libinput: Cosair Corsair VOID Surround USB Sound Adapter: Failed to create a device for /dev/input/event31
[     7.217] (EE) PreInit returned 2 for "Cosair Corsair VOID Surround USB Sound Adapter"
[     7.217] (II) UnloadModule: "libinput"
[     7.218] (II) config/udev: Adding input device HD Webcam: IR Camera (/dev/input/event257)
[     7.218] (**) HD Webcam: IR Camera: Applying InputClass "devname"
[     7.218] (**) HD Webcam: IR Camera: Applying InputClass "libinput keyboard catchall"
[     7.219] (**) HD Webcam: IR Camera: Applying InputClass "system-keyboard"
[     7.219] (II) Using input driver 'libinput' for 'HD Webcam: IR Camera'
[     7.219] (**) HD Webcam: IR Camera: always reports core events
[     7.219] (**) Option "Device" "/dev/input/event257"
[     7.221] (II) event257 - HD Webcam: IR Camera: is tagged by udev as: Keyboard
[     7.221] (II) event257 - HD Webcam: IR Camera: device is a keyboard
[     7.222] (II) event257 - HD Webcam: IR Camera: device removed
[     7.317] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.2/input/input38/event257"
[     7.317] (II) XINPUT: Adding extended input device "HD Webcam: IR Camera" (type: KEYBOARD, id 19)
[     7.317] (**) Option "xkb_layout" "us"
[     7.318] (II) event257 - HD Webcam: IR Camera: is tagged by udev as: Keyboard
[     7.318] (II) event257 - HD Webcam: IR Camera: device is a keyboard
[     7.319] (II) config/udev: Adding input device HD Webcam: HD Webcam (/dev/input/event256)
[     7.319] (**) HD Webcam: HD Webcam: Applying InputClass "devname"
[     7.319] (**) HD Webcam: HD Webcam: Applying InputClass "libinput keyboard catchall"
[     7.319] (**) HD Webcam: HD Webcam: Applying InputClass "system-keyboard"
[     7.319] (II) Using input driver 'libinput' for 'HD Webcam: HD Webcam'
[     7.319] (**) HD Webcam: HD Webcam: always reports core events
[     7.319] (**) Option "Device" "/dev/input/event256"
[     7.320] (II) event256 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[     7.320] (II) event256 - HD Webcam: HD Webcam: device is a keyboard
[     7.321] (II) event256 - HD Webcam: HD Webcam: device removed
[     7.383] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.0/input/input37/event256"
[     7.383] (II) XINPUT: Adding extended input device "HD Webcam: HD Webcam" (type: KEYBOARD, id 20)
[     7.383] (**) Option "xkb_layout" "us"
[     7.385] (II) event256 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[     7.385] (II) event256 - HD Webcam: HD Webcam: device is a keyboard
[     7.386] (II) config/udev: Adding input device Compx 2.4G Receiver Mouse (/dev/input/mouse2)
[     7.386] (**) Compx 2.4G Receiver Mouse: Applying InputClass "devname"
[     7.386] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Mouse'
[     7.386] (**) Compx 2.4G Receiver Mouse: always reports core events
[     7.386] (**) Option "Device" "/dev/input/mouse2"
[     7.454] (II) mouse2  - not using input device '/dev/input/mouse2'.
[     7.454] (EE) libinput: Compx 2.4G Receiver Mouse: Failed to create a device for /dev/input/mouse2
[     7.454] (EE) PreInit returned 2 for "Compx 2.4G Receiver Mouse"
[     7.454] (II) UnloadModule: "libinput"
[     7.455] (II) config/udev: Adding input device Compx 2.4G Receiver (/dev/input/event25)
[     7.455] (**) Compx 2.4G Receiver: Applying InputClass "devname"
[     7.455] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver'
[     7.455] (**) Compx 2.4G Receiver: always reports core events
[     7.455] (**) Option "Device" "/dev/input/event25"
[     7.458] (II) event25 - Compx 2.4G Receiver: not tagged as supported input device
[     7.507] (II) event25 - not using input device '/dev/input/event25'.
[     7.507] (EE) libinput: Compx 2.4G Receiver: Failed to create a device for /dev/input/event25
[     7.507] (EE) PreInit returned 2 for "Compx 2.4G Receiver"
[     7.507] (II) UnloadModule: "libinput"
[     7.509] (II) config/udev: Adding input device Compx 2.4G Receiver System Control (/dev/input/event27)
[     7.509] (**) Compx 2.4G Receiver System Control: Applying InputClass "devname"
[     7.509] (**) Compx 2.4G Receiver System Control: Applying InputClass "libinput keyboard catchall"
[     7.509] (**) Compx 2.4G Receiver System Control: Applying InputClass "system-keyboard"
[     7.509] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver System Control'
[     7.509] (**) Compx 2.4G Receiver System Control: always reports core events
[     7.509] (**) Option "Device" "/dev/input/event27"
[     7.513] (II) event27 - Compx 2.4G Receiver System Control: is tagged by udev as: Keyboard
[     7.514] (II) event27 - Compx 2.4G Receiver System Control: device is a keyboard
[     7.515] (II) event27 - Compx 2.4G Receiver System Control: device removed
[     7.544] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input29/event27"
[     7.544] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver System Control" (type: KEYBOARD, id 21)
[     7.544] (**) Option "xkb_layout" "us"
[     7.549] (II) event27 - Compx 2.4G Receiver System Control: is tagged by udev as: Keyboard
[     7.549] (II) event27 - Compx 2.4G Receiver System Control: device is a keyboard
[     7.553] (II) config/udev: Adding input device Compx 2.4G Receiver Consumer Control (/dev/input/event26)
[     7.553] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "devname"
[     7.553] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     7.553] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[     7.553] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Consumer Control'
[     7.553] (**) Compx 2.4G Receiver Consumer Control: always reports core events
[     7.553] (**) Option "Device" "/dev/input/event26"
[     7.557] (II) event26 - Compx 2.4G Receiver Consumer Control: is tagged by udev as: Keyboard
[     7.557] (II) event26 - Compx 2.4G Receiver Consumer Control: device is a keyboard
[     7.559] (II) event26 - Compx 2.4G Receiver Consumer Control: device removed
[     7.580] (II) libinput: Compx 2.4G Receiver Consumer Control: needs a virtual subdevice
[     7.581] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input28/event26"
[     7.581] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Consumer Control" (type: MOUSE, id 22)
[     7.582] (**) Option "AccelerationScheme" "none"
[     7.583] (**) Compx 2.4G Receiver Consumer Control: (accel) selected scheme none/0
[     7.583] (**) Compx 2.4G Receiver Consumer Control: (accel) acceleration factor: 2.000
[     7.583] (**) Compx 2.4G Receiver Consumer Control: (accel) acceleration threshold: 4
[     7.587] (II) event26 - Compx 2.4G Receiver Consumer Control: is tagged by udev as: Keyboard
[     7.587] (II) event26 - Compx 2.4G Receiver Consumer Control: device is a keyboard
[     7.589] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "devname"
[     7.589] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     7.589] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[     7.589] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Consumer Control'
[     7.589] (**) Compx 2.4G Receiver Consumer Control: always reports core events
[     7.589] (**) Option "Device" "/dev/input/event26"
[     7.589] (II) libinput: Compx 2.4G Receiver Consumer Control: is a virtual subdevice
[     7.589] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input28/event26"
[     7.590] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Consumer Control" (type: KEYBOARD, id 23)
[     7.590] (**) Option "xkb_layout" "us"
[     7.593] (II) config/udev: Adding input device Compx 2.4G Receiver (/dev/input/event23)
[     7.593] (**) Compx 2.4G Receiver: Applying InputClass "devname"
[     7.593] (**) Compx 2.4G Receiver: Applying InputClass "libinput keyboard catchall"
[     7.593] (**) Compx 2.4G Receiver: Applying InputClass "system-keyboard"
[     7.593] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver'
[     7.593] (**) Compx 2.4G Receiver: always reports core events
[     7.593] (**) Option "Device" "/dev/input/event23"
[     7.597] (II) event23 - Compx 2.4G Receiver: is tagged by udev as: Keyboard
[     7.597] (II) event23 - Compx 2.4G Receiver: device is a keyboard
[     7.598] (II) event23 - Compx 2.4G Receiver: device removed
[     7.617] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.0/0003:25A7:FA61.0003/input/input25/event23"
[     7.617] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver" (type: KEYBOARD, id 24)
[     7.617] (**) Option "xkb_layout" "us"
[     7.621] (II) event23 - Compx 2.4G Receiver: is tagged by udev as: Keyboard
[     7.621] (II) event23 - Compx 2.4G Receiver: device is a keyboard
[     7.626] (II) config/udev: Adding input device Compx 2.4G Receiver Mouse (/dev/input/event24)
[     7.626] (**) Compx 2.4G Receiver Mouse: Applying InputClass "devname"
[     7.626] (**) Compx 2.4G Receiver Mouse: Applying InputClass "libinput pointer catchall"
[     7.626] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Mouse'
[     7.626] (**) Compx 2.4G Receiver Mouse: always reports core events
[     7.626] (**) Option "Device" "/dev/input/event24"
[     7.630] (II) event24 - Compx 2.4G Receiver Mouse: is tagged by udev as: Mouse
[     7.630] (II) event24 - Compx 2.4G Receiver Mouse: device is a pointer
[     7.631] (II) event24 - Compx 2.4G Receiver Mouse: device removed
[     7.684] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input26/event24"
[     7.684] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Mouse" (type: MOUSE, id 25)
[     7.685] (**) Option "AccelerationScheme" "none"
[     7.686] (**) Compx 2.4G Receiver Mouse: (accel) selected scheme none/0
[     7.686] (**) Compx 2.4G Receiver Mouse: (accel) acceleration factor: 2.000
[     7.686] (**) Compx 2.4G Receiver Mouse: (accel) acceleration threshold: 4
[     7.690] (II) event24 - Compx 2.4G Receiver Mouse: is tagged by udev as: Mouse
[     7.691] (II) event24 - Compx 2.4G Receiver Mouse: device is a pointer
[   670.455] (EE) event23 - Compx 2.4G Receiver: client bug: event processing lagging behind by 24ms, your system is too slow
[   843.205] (EE) event23 - Compx 2.4G Receiver: client bug: event processing lagging behind by 31ms, your system is too slow
[     5.839]
[     5.839] Current Operating System: Linux adrian-xenia159geni71660ti 5.17.5-arch1-1 #1 SMP PREEMPT Wed, 27 Apr 2022 20:56:11 +0000 x86_64
[     5.839] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=e856e9b5-2f31-47e5-b310-caac9b4d2c2a rw rootflags=subvol=@ quiet loglevel=3 nowatchdog
[     5.839]
[     5.839] Current version of pixman: 0.40.0
[     5.839] 	Before reporting problems, check http://wiki.x.org
[     5.839] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.839] (==) Log file: "/var/log/Xorg.0.log", Time: Sun May  1 10:11:27 2022
[     5.840] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.840] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.840] (==) No Layout section.  Using the first Screen section.
[     5.840] (==) No screen section available. Using defaults.
[     5.840] (**) |-->Screen "Default Screen Section" (0)
[     5.840] (**) |   |-->Monitor "<default monitor>"
[     5.840] (==) No monitor specified for screen "Default Screen Section".
[     5.840] (==) Automatically adding devices
[     5.840] (==) Automatically enabling devices
[     5.840] (==) Automatically adding GPU devices
[     5.840] (==) Automatically binding GPU devices
[     5.840] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.840] (WW) The directory "/usr/share/fonts/misc" does not exist.
[     5.840] 	Entry deleted from font path.
[     5.840] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[     5.841] 	Entry deleted from font path.
[     5.841] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[     5.841] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.841] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.841] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     5.841] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     5.841] (==) FontPath set to:
[     5.841] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.841] (II) The server relies on udev to provide the list of input devices.
[     5.841] (II) Module ABI versions:
[     5.841] 	X.Org ANSI C Emulation: 0.4
[     5.841] 	X.Org Video Driver: 25.2
[     5.841] 	X.Org XInput driver : 24.4
[     5.841] 	X.Org Server Extension : 10.0
[     5.842] (++) using VT number 7
[     5.842] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.842] (II) xfree86: Adding drm device (/dev/dri/card0)
[     5.842] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     5.842] (II) xfree86: Adding drm device (/dev/dri/card1)
[     5.842] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
[     5.846] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.848] (--) PCI:*(0@0:2:0) 8086:3e9b:8086:2086 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00007000/64, BIOS @ 0x????????/131072
[     5.848] (--) PCI: (1@0:0:0) 10de:2191:8086:2086 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/524288
[     5.848] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.848] (II) LoadModule: "glx"
[     5.848] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.854] (II) Module glx: vendor="X.Org Foundation"
[     5.854] 	compiled for 1.21.1.3, module version = 1.0.0
[     5.854] 	ABI class: X.Org Server Extension, version 10.0
[     5.854] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[     5.854] 	loading driver: nvidia
[     5.854] (==) Matched intel as autoconfigured driver 0
[     5.855] (==) Matched nvidia as autoconfigured driver 1
[     5.855] (==) Matched nouveau as autoconfigured driver 2
[     5.855] (==) Matched nv as autoconfigured driver 3
[     5.855] (==) Matched modesetting as autoconfigured driver 4
[     5.855] (==) Matched fbdev as autoconfigured driver 5
[     5.855] (==) Matched vesa as autoconfigured driver 6
[     5.855] (==) Assigned the driver to the xf86ConfigLayout
[     5.855] (II) LoadModule: "intel"
[     5.855] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     5.857] (II) Module intel: vendor="X.Org Foundation"
[     5.857] 	compiled for 1.21.1.1, module version = 2.99.917
[     5.857] 	Module class: X.Org Video Driver
[     5.857] 	ABI class: X.Org Video Driver, version 25.2
[     5.857] (II) LoadModule: "nvidia"
[     5.857] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     5.857] (EE) Failed to load /usr/lib/xorg/modules/drivers/nvidia_drv.so: /usr/lib/xorg/modules/drivers/nvidia_drv.so: invalid ELF header
[     5.857] (EE) Failed to load module "nvidia" (loader failed, 0)
[     5.857] (II) LoadModule: "nouveau"
[     5.858] (WW) Warning, couldn't open module nouveau
[     5.858] (EE) Failed to load module "nouveau" (module does not exist, 0)
[     5.858] (II) LoadModule: "nv"
[     5.858] (WW) Warning, couldn't open module nv
[     5.858] (EE) Failed to load module "nv" (module does not exist, 0)
[     5.858] (II) LoadModule: "modesetting"
[     5.858] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     5.860] (II) Module modesetting: vendor="X.Org Foundation"
[     5.860] 	compiled for 1.21.1.3, module version = 1.21.1
[     5.860] 	Module class: X.Org Video Driver
[     5.860] 	ABI class: X.Org Video Driver, version 25.2
[     5.860] (II) LoadModule: "fbdev"
[     5.860] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     5.860] (II) Module fbdev: vendor="X.Org Foundation"
[     5.860] 	compiled for 1.21.1.1, module version = 0.5.0
[     5.860] (II) LoadModule: "vesa"
[     5.860] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[     5.861] (II) Module vesa: vendor="X.Org Foundation"
[     5.861] 	compiled for 1.21.1.1, module version = 2.5.0
[     5.861] 	Module class: X.Org Video Driver
[     5.861] 	ABI class: X.Org Video Driver, version 25.2
[     5.861] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[     5.861] (II) intel: Driver for Intel(R) HD Graphics
[     5.861] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     5.861] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     5.861] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     5.861] (II) FBDEV: driver for framebuffer: fbdev
[     5.861] (II) VESA: driver for VESA chipsets: vesa
[     5.878] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[     5.878] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[     5.879] (WW) Falling back to old probe method for modesetting
[     5.879] (WW) Falling back to old probe method for fbdev
[     5.879] (II) Loading sub module "fbdevhw"
[     5.879] (II) LoadModule: "fbdevhw"
[     5.880] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     5.881] (II) Module fbdevhw: vendor="X.Org Foundation"
[     5.881] 	compiled for 1.21.1.3, module version = 0.0.2
[     5.881] 	ABI class: X.Org Video Driver, version 25.2
[     5.882] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[     5.882] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 6 threads
[     5.882] (II) intel(0): Creating default Display subsection in Screen section
[     5.882] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     5.882] (==) intel(0): RGB weight 888
[     5.882] (==) intel(0): Default visual is TrueColor
[     5.883] (II) intel(0): Output eDP1 has no monitor section
[     5.884] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[     5.884] (II) intel(0): Enabled output eDP1
[     5.884] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     5.884] (II) intel(0): Output VIRTUAL1 has no monitor section
[     5.884] (II) intel(0): Enabled output VIRTUAL1
[     5.884] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[     5.884] (==) intel(0): TearFree enabled
[     5.884] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.884] (==) intel(0): DPI set to (96, 96)
[     5.884] (II) Loading sub module "dri3"
[     5.884] (II) LoadModule: "dri3"
[     5.884] (II) Module "dri3" already built-in
[     5.884] (II) Loading sub module "dri2"
[     5.885] (II) LoadModule: "dri2"
[     5.885] (II) Module "dri2" already built-in
[     5.885] (II) Loading sub module "present"
[     5.885] (II) LoadModule: "present"
[     5.885] (II) Module "present" already built-in
[     5.885] (II) UnloadModule: "fbdev"
[     5.885] (II) Unloading fbdev
[     5.885] (II) UnloadSubModule: "fbdevhw"
[     5.885] (II) Unloading fbdevhw
[     5.885] (II) UnloadModule: "vesa"
[     5.885] (II) Unloading vesa
[     5.886] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[     5.886] (==) intel(0): Backing store enabled
[     5.886] (==) intel(0): Silken mouse enabled
[     5.886] (II) intel(0): HW Cursor enabled
[     5.886] (==) intel(0): DPMS enabled
[     5.887] (==) intel(0): Display hotplug detection enabled
[     5.887] (II) intel(0): [DRI2] Setup complete
[     5.887] (II) intel(0): [DRI2]   DRI driver: i965
[     5.887] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     5.887] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     5.887] (II) intel(0): hardware support for Present enabled
[     5.887] (II) Initializing extension Generic Event Extension
[     5.887] (II) Initializing extension SHAPE
[     5.888] (II) Initializing extension MIT-SHM
[     5.888] (II) Initializing extension XInputExtension
[     5.888] (II) Initializing extension XTEST
[     5.889] (II) Initializing extension BIG-REQUESTS
[     5.889] (II) Initializing extension SYNC
[     5.889] (II) Initializing extension XKEYBOARD
[     5.890] (II) Initializing extension XC-MISC
[     5.890] (II) Initializing extension SECURITY
[     5.890] (II) Initializing extension XFIXES
[     5.891] (II) Initializing extension RENDER
[     5.891] (II) Initializing extension RANDR
[     5.891] (II) Initializing extension COMPOSITE
[     5.892] (II) Initializing extension DAMAGE
[     5.892] (II) Initializing extension MIT-SCREEN-SAVER
[     5.892] (II) Initializing extension DOUBLE-BUFFER
[     5.893] (II) Initializing extension RECORD
[     5.893] (II) Initializing extension DPMS
[     5.893] (II) Initializing extension Present
[     5.894] (II) Initializing extension DRI3
[     5.894] (II) Initializing extension X-Resource
[     5.894] (II) Initializing extension XVideo
[     5.895] (II) Initializing extension XVideo-MotionCompensation
[     5.895] (II) Initializing extension GLX
[     5.895] (EE) AIGLX error: dlopen of /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: cannot open shared object file: No such file or directory)
[     5.895] (EE) AIGLX error: unable to load driver i965
[     6.124] (II) IGLX: Loaded and initialized swrast
[     6.124] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[     6.124] (II) Initializing extension XFree86-VidModeExtension
[     6.124] (II) Initializing extension XFree86-DGA
[     6.124] (II) Initializing extension XFree86-DRI
[     6.124] (II) Initializing extension DRI2
[     6.126] (II) intel(0): switch to mode 1920x1080@144.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     6.130] (II) intel(0): Setting screen physical size to 508 x 285
[     6.160] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     6.160] (**) Power Button: Applying InputClass "devname"
[     6.160] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.160] (**) Power Button: Applying InputClass "system-keyboard"
[     6.160] (II) LoadModule: "libinput"
[     6.160] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     6.164] (II) Module libinput: vendor="X.Org Foundation"
[     6.164] 	compiled for 1.21.1.3, module version = 1.2.1
[     6.164] 	Module class: X.Org XInput Driver
[     6.164] 	ABI class: X.Org XInput driver, version 24.4
[     6.164] (II) Using input driver 'libinput' for 'Power Button'
[     6.164] (**) Power Button: always reports core events
[     6.164] (**) Option "Device" "/dev/input/event3"
[     6.167] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     6.167] (II) event3  - Power Button: device is a keyboard
[     6.167] (II) event3  - Power Button: device removed
[     6.207] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[     6.207] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     6.207] (**) Option "xkb_layout" "us"
[     6.208] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     6.209] (II) event3  - Power Button: device is a keyboard
[     6.210] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[     6.210] (**) Video Bus: Applying InputClass "devname"
[     6.210] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     6.210] (**) Video Bus: Applying InputClass "system-keyboard"
[     6.210] (II) Using input driver 'libinput' for 'Video Bus'
[     6.210] (**) Video Bus: always reports core events
[     6.210] (**) Option "Device" "/dev/input/event8"
[     6.211] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[     6.211] (II) event8  - Video Bus: device is a keyboard
[     6.211] (II) event8  - Video Bus: device removed
[     6.310] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8/event8"
[     6.310] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     6.310] (**) Option "xkb_layout" "us"
[     6.313] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[     6.313] (II) event8  - Video Bus: device is a keyboard
[     6.315] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[     6.315] (**) Video Bus: Applying InputClass "devname"
[     6.315] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     6.315] (**) Video Bus: Applying InputClass "system-keyboard"
[     6.315] (II) Using input driver 'libinput' for 'Video Bus'
[     6.315] (**) Video Bus: always reports core events
[     6.315] (**) Option "Device" "/dev/input/event9"
[     6.320] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[     6.320] (II) event9  - Video Bus: device is a keyboard
[     6.321] (II) event9  - Video Bus: device removed
[     6.400] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input9/event9"
[     6.400] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     6.400] (**) Option "xkb_layout" "us"
[     6.404] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[     6.405] (II) event9  - Video Bus: device is a keyboard
[     6.407] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     6.408] (**) Power Button: Applying InputClass "devname"
[     6.408] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     6.408] (**) Power Button: Applying InputClass "system-keyboard"
[     6.408] (II) Using input driver 'libinput' for 'Power Button'
[     6.408] (**) Power Button: always reports core events
[     6.408] (**) Option "Device" "/dev/input/event1"
[     6.411] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.412] (II) event1  - Power Button: device is a keyboard
[     6.412] (II) event1  - Power Button: device removed
[     6.450] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     6.451] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     6.451] (**) Option "xkb_layout" "us"
[     6.456] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     6.456] (II) event1  - Power Button: device is a keyboard
[     6.460] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[     6.461] (**) Lid Switch: Applying InputClass "devname"
[     6.461] (II) Using input driver 'libinput' for 'Lid Switch'
[     6.461] (**) Lid Switch: always reports core events
[     6.461] (**) Option "Device" "/dev/input/event2"
[     6.466] (II) event2  - Lid Switch: is tagged by udev as: Switch
[     6.467] (II) event2  - Lid Switch: device is a switch device
[     6.468] (II) event2  - Lid Switch: device removed
[     6.497] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2/event2"
[     6.497] (II) XINPUT: Adding extended input device "Lid Switch" (type: KEYBOARD, id 10)
[     6.516] (II) event2  - Lid Switch: is tagged by udev as: Switch
[     6.516] (II) event2  - Lid Switch: device is a switch device
[     6.519] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[     6.519] (**) Sleep Button: Applying InputClass "devname"
[     6.519] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     6.519] (**) Sleep Button: Applying InputClass "system-keyboard"
[     6.519] (II) Using input driver 'libinput' for 'Sleep Button'
[     6.519] (**) Sleep Button: always reports core events
[     6.519] (**) Option "Device" "/dev/input/event0"
[     6.522] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     6.522] (II) event0  - Sleep Button: device is a keyboard
[     6.523] (II) event0  - Sleep Button: device removed
[     6.547] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[     6.547] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
[     6.547] (**) Option "xkb_layout" "us"
[     6.550] (II) event0  - Sleep Button: is tagged by udev as: Keyboard
[     6.550] (II) event0  - Sleep Button: device is a keyboard
[     6.552] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[     6.552] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[     6.552] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[     6.552] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[     6.552] (**) Option "Device" "/dev/input/event10"
[     6.555] (II) event10 - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[     6.640] (II) event10 - not using input device '/dev/input/event10'.
[     6.640] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event10
[     6.640] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[     6.640] (II) UnloadModule: "libinput"
[     6.642] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[     6.642] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[     6.642] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[     6.642] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[     6.642] (**) Option "Device" "/dev/input/event11"
[     6.644] (II) event11 - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[     6.720] (II) event11 - not using input device '/dev/input/event11'.
[     6.720] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event11
[     6.720] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[     6.720] (II) UnloadModule: "libinput"
[     6.721] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[     6.722] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[     6.722] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[     6.722] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[     6.722] (**) Option "Device" "/dev/input/event12"
[     6.724] (II) event12 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[     6.793] (II) event12 - not using input device '/dev/input/event12'.
[     6.794] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event12
[     6.794] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[     6.794] (II) UnloadModule: "libinput"
[     6.795] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[     6.795] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[     6.795] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[     6.795] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[     6.795] (**) Option "Device" "/dev/input/event13"
[     6.798] (II) event13 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[     6.850] (II) event13 - not using input device '/dev/input/event13'.
[     6.850] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event13
[     6.850] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[     6.850] (II) UnloadModule: "libinput"
[     6.851] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[     6.851] (**) HDA NVidia HDMI/DP,pcm=10: Applying InputClass "devname"
[     6.851] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=10'
[     6.851] (**) HDA NVidia HDMI/DP,pcm=10: always reports core events
[     6.851] (**) Option "Device" "/dev/input/event14"
[     6.852] (II) event14 - HDA NVidia HDMI/DP,pcm=10: is tagged by udev as: Switch
[     6.917] (II) event14 - not using input device '/dev/input/event14'.
[     6.917] (EE) libinput: HDA NVidia HDMI/DP,pcm=10: Failed to create a device for /dev/input/event14
[     6.917] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=10"
[     6.917] (II) UnloadModule: "libinput"
[     6.917] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[     6.917] (**) HDA NVidia HDMI/DP,pcm=11: Applying InputClass "devname"
[     6.917] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=11'
[     6.917] (**) HDA NVidia HDMI/DP,pcm=11: always reports core events
[     6.917] (**) Option "Device" "/dev/input/event15"
[     6.918] (II) event15 - HDA NVidia HDMI/DP,pcm=11: is tagged by udev as: Switch
[     6.987] (II) event15 - not using input device '/dev/input/event15'.
[     6.987] (EE) libinput: HDA NVidia HDMI/DP,pcm=11: Failed to create a device for /dev/input/event15
[     6.987] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=11"
[     6.987] (II) UnloadModule: "libinput"
[     6.989] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Mouse (/dev/input/event5)
[     6.989] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "devname"
[     6.989] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "libinput pointer catchall"
[     6.989] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Mouse'
[     6.989] (**) UNIW0001:00 093A:1336 Mouse: always reports core events
[     6.989] (**) Option "Device" "/dev/input/event5"
[     6.991] (II) event5  - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     6.991] (II) event5  - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     6.993] (II) event5  - UNIW0001:00 093A:1336 Mouse: device removed
[     7.084] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input16/event5"
[     7.084] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Mouse" (type: MOUSE, id 12)
[     7.084] (**) Option "AccelerationScheme" "none"
[     7.084] (**) UNIW0001:00 093A:1336 Mouse: (accel) selected scheme none/0
[     7.084] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration factor: 2.000
[     7.084] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration threshold: 4
[     7.088] (II) event5  - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     7.089] (II) event5  - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     7.093] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Touchpad (/dev/input/event6)
[     7.093] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "devname"
[     7.093] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "libinput touchpad catchall"
[     7.093] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Touchpad'
[     7.093] (**) UNIW0001:00 093A:1336 Touchpad: always reports core events
[     7.093] (**) Option "Device" "/dev/input/event6"
[     7.096] (II) event6  - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     7.101] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     7.102] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device removed
[     7.214] (**) Option "Tapping" "on"
[     7.215] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input17/event6"
[     7.215] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Touchpad" (type: TOUCHPAD, id 13)
[     7.220] (**) Option "AccelerationScheme" "none"
[     7.220] (**) UNIW0001:00 093A:1336 Touchpad: (accel) selected scheme none/0
[     7.220] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration factor: 2.000
[     7.220] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration threshold: 4
[     7.223] (II) event6  - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     7.228] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     7.231] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event18)
[     7.231] (**) HDA Intel PCH Mic: Applying InputClass "devname"
[     7.231] (II) Using input driver 'libinput' for 'HDA Intel PCH Mic'
[     7.231] (**) HDA Intel PCH Mic: always reports core events
[     7.231] (**) Option "Device" "/dev/input/event18"
[     7.233] (II) event18 - HDA Intel PCH Mic: is tagged by udev as: Switch
[     7.294] (II) event18 - not using input device '/dev/input/event18'.
[     7.294] (EE) libinput: HDA Intel PCH Mic: Failed to create a device for /dev/input/event18
[     7.294] (EE) PreInit returned 2 for "HDA Intel PCH Mic"
[     7.294] (II) UnloadModule: "libinput"
[     7.295] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event19)
[     7.295] (**) HDA Intel PCH Headphone: Applying InputClass "devname"
[     7.295] (II) Using input driver 'libinput' for 'HDA Intel PCH Headphone'
[     7.295] (**) HDA Intel PCH Headphone: always reports core events
[     7.295] (**) Option "Device" "/dev/input/event19"
[     7.298] (II) event19 - HDA Intel PCH Headphone: is tagged by udev as: Switch
[     7.360] (II) event19 - not using input device '/dev/input/event19'.
[     7.361] (EE) libinput: HDA Intel PCH Headphone: Failed to create a device for /dev/input/event19
[     7.361] (EE) PreInit returned 2 for "HDA Intel PCH Headphone"
[     7.361] (II) UnloadModule: "libinput"
[     7.362] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event20)
[     7.362] (**) HDA Intel PCH HDMI/DP,pcm=3: Applying InputClass "devname"
[     7.362] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=3'
[     7.362] (**) HDA Intel PCH HDMI/DP,pcm=3: always reports core events
[     7.362] (**) Option "Device" "/dev/input/event20"
[     7.365] (II) event20 - HDA Intel PCH HDMI/DP,pcm=3: is tagged by udev as: Switch
[     7.427] (II) event20 - not using input device '/dev/input/event20'.
[     7.427] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=3: Failed to create a device for /dev/input/event20
[     7.427] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=3"
[     7.427] (II) UnloadModule: "libinput"
[     7.428] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event21)
[     7.428] (**) HDA Intel PCH HDMI/DP,pcm=7: Applying InputClass "devname"
[     7.428] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=7'
[     7.428] (**) HDA Intel PCH HDMI/DP,pcm=7: always reports core events
[     7.428] (**) Option "Device" "/dev/input/event21"
[     7.431] (II) event21 - HDA Intel PCH HDMI/DP,pcm=7: is tagged by udev as: Switch
[     7.494] (II) event21 - not using input device '/dev/input/event21'.
[     7.494] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=7: Failed to create a device for /dev/input/event21
[     7.494] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=7"
[     7.494] (II) UnloadModule: "libinput"
[     7.495] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event22)
[     7.496] (**) HDA Intel PCH HDMI/DP,pcm=8: Applying InputClass "devname"
[     7.496] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=8'
[     7.496] (**) HDA Intel PCH HDMI/DP,pcm=8: always reports core events
[     7.496] (**) Option "Device" "/dev/input/event22"
[     7.499] (II) event22 - HDA Intel PCH HDMI/DP,pcm=8: is tagged by udev as: Switch
[     7.577] (II) event22 - not using input device '/dev/input/event22'.
[     7.577] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=8: Failed to create a device for /dev/input/event22
[     7.577] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=8"
[     7.577] (II) UnloadModule: "libinput"
[     7.578] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event23)
[     7.578] (**) HDA Intel PCH HDMI/DP,pcm=9: Applying InputClass "devname"
[     7.578] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=9'
[     7.578] (**) HDA Intel PCH HDMI/DP,pcm=9: always reports core events
[     7.578] (**) Option "Device" "/dev/input/event23"
[     7.578] (II) event23 - HDA Intel PCH HDMI/DP,pcm=9: is tagged by udev as: Switch
[     7.627] (II) event23 - not using input device '/dev/input/event23'.
[     7.627] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=9: Failed to create a device for /dev/input/event23
[     7.627] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=9"
[     7.627] (II) UnloadModule: "libinput"
[     7.628] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event24)
[     7.628] (**) HDA Intel PCH HDMI/DP,pcm=10: Applying InputClass "devname"
[     7.628] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=10'
[     7.628] (**) HDA Intel PCH HDMI/DP,pcm=10: always reports core events
[     7.628] (**) Option "Device" "/dev/input/event24"
[     7.630] (II) event24 - HDA Intel PCH HDMI/DP,pcm=10: is tagged by udev as: Switch
[     7.684] (II) event24 - not using input device '/dev/input/event24'.
[     7.684] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=10: Failed to create a device for /dev/input/event24
[     7.684] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=10"
[     7.684] (II) UnloadModule: "libinput"
[     7.685] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[     7.685] (**) AT Translated Set 2 keyboard: Applying InputClass "devname"
[     7.686] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     7.686] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     7.686] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     7.686] (**) AT Translated Set 2 keyboard: always reports core events
[     7.686] (**) Option "Device" "/dev/input/event4"
[     7.688] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.688] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     7.691] (II) event4  - AT Translated Set 2 keyboard: device removed
[     7.717] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[     7.717] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 14)
[     7.717] (**) Option "xkb_layout" "us"
[     7.720] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     7.720] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     7.724] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     7.724] (**) PC Speaker: Applying InputClass "devname"
[     7.724] (II) Using input driver 'libinput' for 'PC Speaker'
[     7.724] (**) PC Speaker: always reports core events
[     7.724] (**) Option "Device" "/dev/input/event7"
[     7.726] (II) event7  - PC Speaker: not tagged as supported input device
[     7.790] (II) event7  - not using input device '/dev/input/event7'.
[     7.791] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event7
[     7.791] (EE) PreInit returned 2 for "PC Speaker"
[     7.791] (II) UnloadModule: "libinput"
[     7.826] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=11 (/dev/input/event15)
[     7.826] (**) HDA NVidia HDMI/DP,pcm=11: Applying InputClass "devname"
[     7.826] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=11'
[     7.826] (**) HDA NVidia HDMI/DP,pcm=11: always reports core events
[     7.826] (**) Option "Device" "/dev/input/event15"
[     7.827] (II) event15 - HDA NVidia HDMI/DP,pcm=11: is tagged by udev as: Switch
[     7.884] (II) event15 - not using input device '/dev/input/event15'.
[     7.884] (EE) libinput: HDA NVidia HDMI/DP,pcm=11: Failed to create a device for /dev/input/event15
[     7.884] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=11"
[     7.884] (II) UnloadModule: "libinput"
[     7.887] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
[     7.887] (**) HDA NVidia HDMI/DP,pcm=9: Applying InputClass "devname"
[     7.887] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=9'
[     7.887] (**) HDA NVidia HDMI/DP,pcm=9: always reports core events
[     7.887] (**) Option "Device" "/dev/input/event13"
[     7.888] (II) event13 - HDA NVidia HDMI/DP,pcm=9: is tagged by udev as: Switch
[     7.947] (II) event13 - not using input device '/dev/input/event13'.
[     7.947] (EE) libinput: HDA NVidia HDMI/DP,pcm=9: Failed to create a device for /dev/input/event13
[     7.947] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=9"
[     7.947] (II) UnloadModule: "libinput"
[     7.948] (II) intel(0): EDID vendor "BOE", prod id 2125
[     7.948] (II) intel(0): Printing DDC gathered Modelines:
[     7.949] (II) intel(0): Modeline "1920x1080"x0.0  342.05  1920 2028 2076 2080  1080 1090 1100 1142 +hsync -vsync (164.4 kHz eP)
[     7.949] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event11)
[     7.949] (**) HDA NVidia HDMI/DP,pcm=7: Applying InputClass "devname"
[     7.949] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=7'
[     7.949] (**) HDA NVidia HDMI/DP,pcm=7: always reports core events
[     7.949] (**) Option "Device" "/dev/input/event11"
[     7.949] (II) event11 - HDA NVidia HDMI/DP,pcm=7: is tagged by udev as: Switch
[     8.007] (II) event11 - not using input device '/dev/input/event11'.
[     8.007] (EE) libinput: HDA NVidia HDMI/DP,pcm=7: Failed to create a device for /dev/input/event11
[     8.007] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=7"
[     8.007] (II) UnloadModule: "libinput"
[     8.007] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
[     8.007] (**) HDA NVidia HDMI/DP,pcm=8: Applying InputClass "devname"
[     8.007] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=8'
[     8.007] (**) HDA NVidia HDMI/DP,pcm=8: always reports core events
[     8.007] (**) Option "Device" "/dev/input/event12"
[     8.008] (II) event12 - HDA NVidia HDMI/DP,pcm=8: is tagged by udev as: Switch
[     8.087] (II) event12 - not using input device '/dev/input/event12'.
[     8.087] (EE) libinput: HDA NVidia HDMI/DP,pcm=8: Failed to create a device for /dev/input/event12
[     8.087] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=8"
[     8.087] (II) UnloadModule: "libinput"
[     8.087] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=10 (/dev/input/event14)
[     8.087] (**) HDA NVidia HDMI/DP,pcm=10: Applying InputClass "devname"
[     8.087] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=10'
[     8.087] (**) HDA NVidia HDMI/DP,pcm=10: always reports core events
[     8.087] (**) Option "Device" "/dev/input/event14"
[     8.088] (II) event14 - HDA NVidia HDMI/DP,pcm=10: is tagged by udev as: Switch
[     8.144] (II) event14 - not using input device '/dev/input/event14'.
[     8.144] (EE) libinput: HDA NVidia HDMI/DP,pcm=10: Failed to create a device for /dev/input/event14
[     8.144] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=10"
[     8.144] (II) UnloadModule: "libinput"
[     8.144] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event10)
[     8.144] (**) HDA NVidia HDMI/DP,pcm=3: Applying InputClass "devname"
[     8.144] (II) Using input driver 'libinput' for 'HDA NVidia HDMI/DP,pcm=3'
[     8.144] (**) HDA NVidia HDMI/DP,pcm=3: always reports core events
[     8.144] (**) Option "Device" "/dev/input/event10"
[     8.145] (II) event10 - HDA NVidia HDMI/DP,pcm=3: is tagged by udev as: Switch
[     8.207] (II) event10 - not using input device '/dev/input/event10'.
[     8.207] (EE) libinput: HDA NVidia HDMI/DP,pcm=3: Failed to create a device for /dev/input/event10
[     8.207] (EE) PreInit returned 2 for "HDA NVidia HDMI/DP,pcm=3"
[     8.207] (II) UnloadModule: "libinput"
[     8.207] (II) config/udev: removing device UNIW0001:00 093A:1336 Mouse
[     8.207] (II) event5  - UNIW0001:00 093A:1336 Mouse: device removed
[     8.243] (II) UnloadModule: "libinput"
[     8.244] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Mouse (/dev/input/event5)
[     8.244] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "devname"
[     8.244] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "libinput pointer catchall"
[     8.244] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Mouse'
[     8.244] (**) UNIW0001:00 093A:1336 Mouse: always reports core events
[     8.244] (**) Option "Device" "/dev/input/event5"
[     8.244] (II) event5  - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.245] (II) event5  - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     8.245] (II) event5  - UNIW0001:00 093A:1336 Mouse: device removed
[     8.277] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input16/event5"
[     8.277] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Mouse" (type: MOUSE, id 12)
[     8.277] (**) Option "AccelerationScheme" "none"
[     8.277] (**) UNIW0001:00 093A:1336 Mouse: (accel) selected scheme none/0
[     8.277] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration factor: 2.000
[     8.277] (**) UNIW0001:00 093A:1336 Mouse: (accel) acceleration threshold: 4
[     8.278] (II) event5  - UNIW0001:00 093A:1336 Mouse: is tagged by udev as: Mouse Pointingstick
[     8.278] (II) event5  - UNIW0001:00 093A:1336 Mouse: device is a pointer
[     8.278] (II) config/udev: removing device UNIW0001:00 093A:1336 Touchpad
[     8.279] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device removed
[     8.310] (II) UnloadModule: "libinput"
[     8.310] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Touchpad (/dev/input/event6)
[     8.310] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "devname"
[     8.310] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "libinput touchpad catchall"
[     8.311] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Touchpad'
[     8.311] (**) UNIW0001:00 093A:1336 Touchpad: always reports core events
[     8.311] (**) Option "Device" "/dev/input/event6"
[     8.311] (II) event6  - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     8.312] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     8.312] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device removed
[     8.343] (**) Option "Tapping" "on"
[     8.344] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-UNIW0001:00/0018:093A:1336.0001/input/input17/event6"
[     8.344] (II) XINPUT: Adding extended input device "UNIW0001:00 093A:1336 Touchpad" (type: TOUCHPAD, id 13)
[     8.345] (**) Option "AccelerationScheme" "none"
[     8.345] (**) UNIW0001:00 093A:1336 Touchpad: (accel) selected scheme none/0
[     8.345] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration factor: 2.000
[     8.346] (**) UNIW0001:00 093A:1336 Touchpad: (accel) acceleration threshold: 4
[     8.347] (II) event6  - UNIW0001:00 093A:1336 Touchpad: is tagged by udev as: Touchpad
[     8.348] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device is a touchpad
[     8.350] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Mouse (/dev/input/mouse0)
[     8.350] (**) UNIW0001:00 093A:1336 Mouse: Applying InputClass "devname"
[     8.350] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Mouse'
[     8.350] (**) UNIW0001:00 093A:1336 Mouse: always reports core events
[     8.350] (**) Option "Device" "/dev/input/mouse0"
[     8.390] (II) mouse0  - not using input device '/dev/input/mouse0'.
[     8.390] (EE) libinput: UNIW0001:00 093A:1336 Mouse: Failed to create a device for /dev/input/mouse0
[     8.390] (EE) PreInit returned 2 for "UNIW0001:00 093A:1336 Mouse"
[     8.390] (II) UnloadModule: "libinput"
[     8.392] (II) config/udev: Adding input device UNIW0001:00 093A:1336 Touchpad (/dev/input/mouse1)
[     8.392] (**) UNIW0001:00 093A:1336 Touchpad: Applying InputClass "devname"
[     8.392] (II) Using input driver 'libinput' for 'UNIW0001:00 093A:1336 Touchpad'
[     8.392] (**) UNIW0001:00 093A:1336 Touchpad: always reports core events
[     8.392] (**) Option "Device" "/dev/input/mouse1"
[     8.423] (II) mouse1  - not using input device '/dev/input/mouse1'.
[     8.424] (EE) libinput: UNIW0001:00 093A:1336 Touchpad: Failed to create a device for /dev/input/mouse1
[     8.424] (EE) PreInit returned 2 for "UNIW0001:00 093A:1336 Touchpad"
[     8.424] (II) UnloadModule: "libinput"
[     8.425] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event21)
[     8.425] (**) HDA Intel PCH HDMI/DP,pcm=7: Applying InputClass "devname"
[     8.425] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=7'
[     8.425] (**) HDA Intel PCH HDMI/DP,pcm=7: always reports core events
[     8.425] (**) Option "Device" "/dev/input/event21"
[     8.428] (II) event21 - HDA Intel PCH HDMI/DP,pcm=7: is tagged by udev as: Switch
[     8.487] (II) event21 - not using input device '/dev/input/event21'.
[     8.487] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=7: Failed to create a device for /dev/input/event21
[     8.487] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=7"
[     8.487] (II) UnloadModule: "libinput"
[     8.488] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event23)
[     8.488] (**) HDA Intel PCH HDMI/DP,pcm=9: Applying InputClass "devname"
[     8.488] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=9'
[     8.488] (**) HDA Intel PCH HDMI/DP,pcm=9: always reports core events
[     8.488] (**) Option "Device" "/dev/input/event23"
[     8.490] (II) event23 - HDA Intel PCH HDMI/DP,pcm=9: is tagged by udev as: Switch
[     8.530] (II) event23 - not using input device '/dev/input/event23'.
[     8.530] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=9: Failed to create a device for /dev/input/event23
[     8.530] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=9"
[     8.530] (II) UnloadModule: "libinput"
[     8.531] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event20)
[     8.532] (**) HDA Intel PCH HDMI/DP,pcm=3: Applying InputClass "devname"
[     8.532] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=3'
[     8.532] (**) HDA Intel PCH HDMI/DP,pcm=3: always reports core events
[     8.532] (**) Option "Device" "/dev/input/event20"
[     8.534] (II) event20 - HDA Intel PCH HDMI/DP,pcm=3: is tagged by udev as: Switch
[     8.600] (II) event20 - not using input device '/dev/input/event20'.
[     8.600] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=3: Failed to create a device for /dev/input/event20
[     8.600] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=3"
[     8.600] (II) UnloadModule: "libinput"
[     8.602] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event24)
[     8.602] (**) HDA Intel PCH HDMI/DP,pcm=10: Applying InputClass "devname"
[     8.602] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=10'
[     8.602] (**) HDA Intel PCH HDMI/DP,pcm=10: always reports core events
[     8.602] (**) Option "Device" "/dev/input/event24"
[     8.604] (II) event24 - HDA Intel PCH HDMI/DP,pcm=10: is tagged by udev as: Switch
[     8.667] (II) event24 - not using input device '/dev/input/event24'.
[     8.667] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=10: Failed to create a device for /dev/input/event24
[     8.667] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=10"
[     8.667] (II) UnloadModule: "libinput"
[     8.667] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event19)
[     8.667] (**) HDA Intel PCH Headphone: Applying InputClass "devname"
[     8.667] (II) Using input driver 'libinput' for 'HDA Intel PCH Headphone'
[     8.667] (**) HDA Intel PCH Headphone: always reports core events
[     8.667] (**) Option "Device" "/dev/input/event19"
[     8.668] (II) event19 - HDA Intel PCH Headphone: is tagged by udev as: Switch
[     8.720] (II) event19 - not using input device '/dev/input/event19'.
[     8.720] (EE) libinput: HDA Intel PCH Headphone: Failed to create a device for /dev/input/event19
[     8.720] (EE) PreInit returned 2 for "HDA Intel PCH Headphone"
[     8.720] (II) UnloadModule: "libinput"
[     8.721] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event22)
[     8.721] (**) HDA Intel PCH HDMI/DP,pcm=8: Applying InputClass "devname"
[     8.721] (II) Using input driver 'libinput' for 'HDA Intel PCH HDMI/DP,pcm=8'
[     8.722] (**) HDA Intel PCH HDMI/DP,pcm=8: always reports core events
[     8.722] (**) Option "Device" "/dev/input/event22"
[     8.724] (II) event22 - HDA Intel PCH HDMI/DP,pcm=8: is tagged by udev as: Switch
[     8.783] (II) event22 - not using input device '/dev/input/event22'.
[     8.784] (EE) libinput: HDA Intel PCH HDMI/DP,pcm=8: Failed to create a device for /dev/input/event22
[     8.784] (EE) PreInit returned 2 for "HDA Intel PCH HDMI/DP,pcm=8"
[     8.784] (II) UnloadModule: "libinput"
[     8.785] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event18)
[     8.785] (**) HDA Intel PCH Mic: Applying InputClass "devname"
[     8.785] (II) Using input driver 'libinput' for 'HDA Intel PCH Mic'
[     8.785] (**) HDA Intel PCH Mic: always reports core events
[     8.785] (**) Option "Device" "/dev/input/event18"
[     8.788] (II) event18 - HDA Intel PCH Mic: is tagged by udev as: Switch
[     8.827] (II) event18 - not using input device '/dev/input/event18'.
[     8.827] (EE) libinput: HDA Intel PCH Mic: Failed to create a device for /dev/input/event18
[     8.827] (EE) PreInit returned 2 for "HDA Intel PCH Mic"
[     8.827] (II) UnloadModule: "libinput"
[     8.829] (II) config/udev: Adding input device HD Webcam: HD Webcam (/dev/input/event16)
[     8.829] (**) HD Webcam: HD Webcam: Applying InputClass "devname"
[     8.829] (**) HD Webcam: HD Webcam: Applying InputClass "libinput keyboard catchall"
[     8.829] (**) HD Webcam: HD Webcam: Applying InputClass "system-keyboard"
[     8.829] (II) Using input driver 'libinput' for 'HD Webcam: HD Webcam'
[     8.829] (**) HD Webcam: HD Webcam: always reports core events
[     8.829] (**) Option "Device" "/dev/input/event16"
[     8.833] (II) event16 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[     8.833] (II) event16 - HD Webcam: HD Webcam: device is a keyboard
[     8.834] (II) event16 - HD Webcam: HD Webcam: device removed
[     8.880] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.0/input/input20/event16"
[     8.880] (II) XINPUT: Adding extended input device "HD Webcam: HD Webcam" (type: KEYBOARD, id 15)
[     8.880] (**) Option "xkb_layout" "us"
[     8.884] (II) event16 - HD Webcam: HD Webcam: is tagged by udev as: Keyboard
[     8.884] (II) event16 - HD Webcam: HD Webcam: device is a keyboard
[     8.887] (II) config/udev: Adding input device HD Webcam: IR Camera (/dev/input/event17)
[     8.887] (**) HD Webcam: IR Camera: Applying InputClass "devname"
[     8.887] (**) HD Webcam: IR Camera: Applying InputClass "libinput keyboard catchall"
[     8.887] (**) HD Webcam: IR Camera: Applying InputClass "system-keyboard"
[     8.887] (II) Using input driver 'libinput' for 'HD Webcam: IR Camera'
[     8.887] (**) HD Webcam: IR Camera: always reports core events
[     8.887] (**) Option "Device" "/dev/input/event17"
[     8.890] (II) event17 - HD Webcam: IR Camera: is tagged by udev as: Keyboard
[     8.891] (II) event17 - HD Webcam: IR Camera: device is a keyboard
[     8.892] (II) event17 - HD Webcam: IR Camera: device removed
[     8.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-13/1-13:1.2/input/input21/event17"
[     8.924] (II) XINPUT: Adding extended input device "HD Webcam: IR Camera" (type: KEYBOARD, id 16)
[     8.924] (**) Option "xkb_layout" "us"
[     8.927] (II) event17 - HD Webcam: IR Camera: is tagged by udev as: Keyboard
[     8.928] (II) event17 - HD Webcam: IR Camera: device is a keyboard
[     8.931] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse (/dev/input/mouse3)
[     8.931] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[     8.931] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse'
[     8.931] (**) Logitech G203 LIGHTSYNC Gaming Mouse: always reports core events
[     8.931] (**) Option "Device" "/dev/input/mouse3"
[     9.020] (II) mouse3  - not using input device '/dev/input/mouse3'.
[     9.020] (EE) libinput: Logitech G203 LIGHTSYNC Gaming Mouse: Failed to create a device for /dev/input/mouse3
[     9.020] (EE) PreInit returned 2 for "Logitech G203 LIGHTSYNC Gaming Mouse"
[     9.020] (II) UnloadModule: "libinput"
[     9.022] (II) config/udev: Adding input device Cosair Corsair VOID Surround USB Sound Adapter Consumer Control (/dev/input/event256)
[     9.022] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "devname"
[     9.022] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.022] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: Applying InputClass "system-keyboard"
[     9.022] (II) Using input driver 'libinput' for 'Cosair Corsair VOID Surround USB Sound Adapter Consumer Control'
[     9.022] (**) Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: always reports core events
[     9.022] (**) Option "Device" "/dev/input/event256"
[     9.026] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: is tagged by udev as: Keyboard
[     9.027] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device is a keyboard
[     9.028] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device removed
[     9.063] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.3/0003:1B1C:0A30.0007/input/input37/event256"
[     9.064] (II) XINPUT: Adding extended input device "Cosair Corsair VOID Surround USB Sound Adapter Consumer Control" (type: KEYBOARD, id 17)
[     9.064] (**) Option "xkb_layout" "us"
[     9.068] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: is tagged by udev as: Keyboard
[     9.068] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device is a keyboard
[     9.071] (II) config/udev: Adding input device Cosair Corsair VOID Surround USB Sound Adapter (/dev/input/event257)
[     9.071] (**) Cosair Corsair VOID Surround USB Sound Adapter: Applying InputClass "devname"
[     9.071] (II) Using input driver 'libinput' for 'Cosair Corsair VOID Surround USB Sound Adapter'
[     9.071] (**) Cosair Corsair VOID Surround USB Sound Adapter: always reports core events
[     9.071] (**) Option "Device" "/dev/input/event257"
[     9.075] (II) event257 - Cosair Corsair VOID Surround USB Sound Adapter: not tagged as supported input device
[     9.107] (II) event257 - not using input device '/dev/input/event257'.
[     9.107] (EE) libinput: Cosair Corsair VOID Surround USB Sound Adapter: Failed to create a device for /dev/input/event257
[     9.107] (EE) PreInit returned 2 for "Cosair Corsair VOID Surround USB Sound Adapter"
[     9.107] (II) UnloadModule: "libinput"
[     9.109] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse Keyboard (/dev/input/event31)
[     9.109] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[     9.109] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.109] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     9.109] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse Keyboard'
[     9.109] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[     9.109] (**) Option "Device" "/dev/input/event31"
[     9.113] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     9.114] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[     9.115] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device removed
[     9.134] (II) libinput: Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: needs a virtual subdevice
[     9.134] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046D:C092.0006/input/input34/event31"
[     9.134] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse Keyboard" (type: MOUSE, id 18)
[     9.134] (**) Option "AccelerationScheme" "none"
[     9.134] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) selected scheme none/0
[     9.134] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[     9.134] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[     9.138] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[     9.138] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device is a keyboard
[     9.140] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "devname"
[     9.140] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[     9.140] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[     9.140] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse Keyboard'
[     9.140] (**) Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: always reports core events
[     9.140] (**) Option "Device" "/dev/input/event31"
[     9.140] (II) libinput: Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: is a virtual subdevice
[     9.140] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.1/0003:046D:C092.0006/input/input34/event31"
[     9.141] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse Keyboard" (type: KEYBOARD, id 19)
[     9.141] (**) Option "xkb_layout" "us"
[     9.143] (II) config/udev: Adding input device Logitech G203 LIGHTSYNC Gaming Mouse (/dev/input/event30)
[     9.143] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "devname"
[     9.143] (**) Logitech G203 LIGHTSYNC Gaming Mouse: Applying InputClass "libinput pointer catchall"
[     9.143] (II) Using input driver 'libinput' for 'Logitech G203 LIGHTSYNC Gaming Mouse'
[     9.143] (**) Logitech G203 LIGHTSYNC Gaming Mouse: always reports core events
[     9.143] (**) Option "Device" "/dev/input/event30"
[     9.204] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[     9.204] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: device is a pointer
[     9.205] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: device removed
[     9.243] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-9/1-9:1.0/0003:046D:C092.0005/input/input33/event30"
[     9.244] (II) XINPUT: Adding extended input device "Logitech G203 LIGHTSYNC Gaming Mouse" (type: MOUSE, id 20)
[     9.244] (**) Option "AccelerationScheme" "none"
[     9.244] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) selected scheme none/0
[     9.244] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) acceleration factor: 2.000
[     9.244] (**) Logitech G203 LIGHTSYNC Gaming Mouse: (accel) acceleration threshold: 4
[     9.303] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: is tagged by udev as: Mouse
[     9.304] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: device is a pointer
[     9.308] (II) config/udev: Adding input device Compx 2.4G Receiver Mouse (/dev/input/mouse2)
[     9.308] (**) Compx 2.4G Receiver Mouse: Applying InputClass "devname"
[     9.308] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Mouse'
[     9.308] (**) Compx 2.4G Receiver Mouse: always reports core events
[     9.308] (**) Option "Device" "/dev/input/mouse2"
[     9.353] (II) mouse2  - not using input device '/dev/input/mouse2'.
[     9.354] (EE) libinput: Compx 2.4G Receiver Mouse: Failed to create a device for /dev/input/mouse2
[     9.354] (EE) PreInit returned 2 for "Compx 2.4G Receiver Mouse"
[     9.354] (II) UnloadModule: "libinput"
[     9.355] (II) config/udev: Adding input device Compx 2.4G Receiver System Control (/dev/input/event29)
[     9.356] (**) Compx 2.4G Receiver System Control: Applying InputClass "devname"
[     9.356] (**) Compx 2.4G Receiver System Control: Applying InputClass "libinput keyboard catchall"
[     9.356] (**) Compx 2.4G Receiver System Control: Applying InputClass "system-keyboard"
[     9.356] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver System Control'
[     9.356] (**) Compx 2.4G Receiver System Control: always reports core events
[     9.356] (**) Option "Device" "/dev/input/event29"
[     9.360] (II) event29 - Compx 2.4G Receiver System Control: is tagged by udev as: Keyboard
[     9.360] (II) event29 - Compx 2.4G Receiver System Control: device is a keyboard
[     9.361] (II) event29 - Compx 2.4G Receiver System Control: device removed
[     9.390] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input31/event29"
[     9.390] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver System Control" (type: KEYBOARD, id 21)
[     9.390] (**) Option "xkb_layout" "us"
[     9.395] (II) event29 - Compx 2.4G Receiver System Control: is tagged by udev as: Keyboard
[     9.396] (II) event29 - Compx 2.4G Receiver System Control: device is a keyboard
[     9.399] (II) config/udev: Adding input device Compx 2.4G Receiver (/dev/input/event25)
[     9.399] (**) Compx 2.4G Receiver: Applying InputClass "devname"
[     9.399] (**) Compx 2.4G Receiver: Applying InputClass "libinput keyboard catchall"
[     9.399] (**) Compx 2.4G Receiver: Applying InputClass "system-keyboard"
[     9.399] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver'
[     9.399] (**) Compx 2.4G Receiver: always reports core events
[     9.399] (**) Option "Device" "/dev/input/event25"
[     9.403] (II) event25 - Compx 2.4G Receiver: is tagged by udev as: Keyboard
[     9.404] (II) event25 - Compx 2.4G Receiver: device is a keyboard
[     9.405] (II) event25 - Compx 2.4G Receiver: device removed
[     9.427] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.0/0003:25A7:FA61.0003/input/input27/event25"
[     9.427] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver" (type: KEYBOARD, id 22)
[     9.427] (**) Option "xkb_layout" "us"
[     9.432] (II) event25 - Compx 2.4G Receiver: is tagged by udev as: Keyboard
[     9.432] (II) event25 - Compx 2.4G Receiver: device is a keyboard
[     9.435] (II) config/udev: Adding input device Compx 2.4G Receiver (/dev/input/event27)
[     9.436] (**) Compx 2.4G Receiver: Applying InputClass "devname"
[     9.436] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver'
[     9.436] (**) Compx 2.4G Receiver: always reports core events
[     9.436] (**) Option "Device" "/dev/input/event27"
[     9.440] (II) event27 - Compx 2.4G Receiver: not tagged as supported input device
[     9.490] (II) event27 - not using input device '/dev/input/event27'.
[     9.490] (EE) libinput: Compx 2.4G Receiver: Failed to create a device for /dev/input/event27
[     9.490] (EE) PreInit returned 2 for "Compx 2.4G Receiver"
[     9.490] (II) UnloadModule: "libinput"
[     9.492] (II) config/udev: Adding input device Compx 2.4G Receiver Consumer Control (/dev/input/event28)
[     9.492] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "devname"
[     9.493] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.493] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[     9.493] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Consumer Control'
[     9.493] (**) Compx 2.4G Receiver Consumer Control: always reports core events
[     9.493] (**) Option "Device" "/dev/input/event28"
[     9.497] (II) event28 - Compx 2.4G Receiver Consumer Control: is tagged by udev as: Keyboard
[     9.497] (II) event28 - Compx 2.4G Receiver Consumer Control: device is a keyboard
[     9.498] (II) event28 - Compx 2.4G Receiver Consumer Control: device removed
[     9.517] (II) libinput: Compx 2.4G Receiver Consumer Control: needs a virtual subdevice
[     9.517] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input30/event28"
[     9.517] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Consumer Control" (type: MOUSE, id 23)
[     9.517] (**) Option "AccelerationScheme" "none"
[     9.517] (**) Compx 2.4G Receiver Consumer Control: (accel) selected scheme none/0
[     9.517] (**) Compx 2.4G Receiver Consumer Control: (accel) acceleration factor: 2.000
[     9.517] (**) Compx 2.4G Receiver Consumer Control: (accel) acceleration threshold: 4
[     9.522] (II) event28 - Compx 2.4G Receiver Consumer Control: is tagged by udev as: Keyboard
[     9.522] (II) event28 - Compx 2.4G Receiver Consumer Control: device is a keyboard
[     9.524] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "devname"
[     9.524] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "libinput keyboard catchall"
[     9.524] (**) Compx 2.4G Receiver Consumer Control: Applying InputClass "system-keyboard"
[     9.524] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Consumer Control'
[     9.524] (**) Compx 2.4G Receiver Consumer Control: always reports core events
[     9.524] (**) Option "Device" "/dev/input/event28"
[     9.524] (II) libinput: Compx 2.4G Receiver Consumer Control: is a virtual subdevice
[     9.524] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input30/event28"
[     9.524] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Consumer Control" (type: KEYBOARD, id 24)
[     9.524] (**) Option "xkb_layout" "us"
[     9.526] (II) config/udev: Adding input device Compx 2.4G Receiver Mouse (/dev/input/event26)
[     9.526] (**) Compx 2.4G Receiver Mouse: Applying InputClass "devname"
[     9.526] (**) Compx 2.4G Receiver Mouse: Applying InputClass "libinput pointer catchall"
[     9.526] (II) Using input driver 'libinput' for 'Compx 2.4G Receiver Mouse'
[     9.526] (**) Compx 2.4G Receiver Mouse: always reports core events
[     9.526] (**) Option "Device" "/dev/input/event26"
[     9.531] (II) event26 - Compx 2.4G Receiver Mouse: is tagged by udev as: Mouse
[     9.531] (II) event26 - Compx 2.4G Receiver Mouse: device is a pointer
[     9.532] (II) event26 - Compx 2.4G Receiver Mouse: device removed
[     9.580] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4.4/1-4.4:1.1/0003:25A7:FA61.0004/input/input28/event26"
[     9.580] (II) XINPUT: Adding extended input device "Compx 2.4G Receiver Mouse" (type: MOUSE, id 25)
[     9.581] (**) Option "AccelerationScheme" "none"
[     9.581] (**) Compx 2.4G Receiver Mouse: (accel) selected scheme none/0
[     9.581] (**) Compx 2.4G Receiver Mouse: (accel) acceleration factor: 2.000
[     9.581] (**) Compx 2.4G Receiver Mouse: (accel) acceleration threshold: 4
[     9.585] (II) event26 - Compx 2.4G Receiver Mouse: is tagged by udev as: Mouse
[     9.586] (II) event26 - Compx 2.4G Receiver Mouse: device is a pointer
[   178.548] (II) event3  - Power Button: device removed
[   178.580] (II) event8  - Video Bus: device removed
[   178.674] (II) event9  - Video Bus: device removed
[   178.754] (II) event1  - Power Button: device removed
[   178.807] (II) event2  - Lid Switch: device removed
[   178.857] (II) event0  - Sleep Button: device removed
[   178.894] (II) event4  - AT Translated Set 2 keyboard: device removed
[   178.937] (II) event5  - UNIW0001:00 093A:1336 Mouse: device removed
[   178.971] (II) event6  - UNIW0001:00 093A:1336 Touchpad: device removed
[   179.004] (II) event16 - HD Webcam: HD Webcam: device removed
[   179.037] (II) event17 - HD Webcam: IR Camera: device removed
[   179.071] (II) event256 - Cosair Corsair VOID Surround USB Sound Adapter Consumer Control: device removed
[   179.104] (II) event31 - Logitech G203 LIGHTSYNC Gaming Mouse Keyboard: device removed
[   179.147] (II) event30 - Logitech G203 LIGHTSYNC Gaming Mouse: device removed
[   179.181] (II) event29 - Compx 2.4G Receiver System Control: device removed
[   179.214] (II) event25 - Compx 2.4G Receiver: device removed
[   179.247] (II) event28 - Compx 2.4G Receiver Consumer Control: device removed
[   179.281] (II) event26 - Compx 2.4G Receiver Mouse: device removed
[   179.315] (II) UnloadModule: "libinput"
[   179.316] (II) UnloadModule: "libinput"
[   179.317] (II) UnloadModule: "libinput"
[   179.319] (II) UnloadModule: "libinput"
[   179.350] (II) Server terminated successfully (0). Closing log file.
Code blocks fixed.
How did you install nvidia drivers?
It seems it is not compiled properly, or broken package/installation.
Re-install the nvidia driver and/or upgrade your systems’ packages.
Originally installed via EndeavorOS Nvidia proprietary install. Obviously, reinstalled many times (every time it updated in Pacman or reinstalled with kernel over 2 years). All packages are up to date, and I reinstalled Nvidia this morning. Still not recognizing. He is heading to school (needs laptop), so I will check back late this afternoon.
Not sure this will help as I’m a KDE user , but in KDE to get TV working through HDMI , I have to go into system settings , Display and Monitor . There I see the TV and need to enable it , for it to work . This may apply also with the Bugie Desktop , not sure though . Just a thought !
GOOD LUCK …
I understand, but the error messages show the driver modules fail to load and report about something not correct in driver version/compilation.
The quick fix for production is to uninstall nvidia proprietary and use nouveau instead.
As said, external monitor outputs are probably connected to nvidia, that’s why the result of not recognized monitors.
I hope someone else may know more about the invalid :elf: message and can help troubleshoot :person_shrugging:
@sliding_billy
https://wiki.archlinux.org/title/multihead
I think you misread the issue. The monitor was fine in Budgie, but that was with integrated graphics. I have done all of the settings stuff before in Cinnamon on my daily. The issue with the problematic machine is that the monitor is no detected to be configured.
I will give that a read, Thanks,
I thought about installing Nouveau instead of Nvidia, but like you said was hoping someone had a solution for the proprietary install.
Just don’t forget/misread…
Nvidia is the problem :wink:
Have you looked at the wiki page for nvidia ? Will explain how to install driver …
Reading it now. Will read again once the machine is in front of me.
By no reason at all, it is detecting the 2nd monitor and configuring fine. I had tried using nvidia dkms wtih it still not recognizing the monitor. When I got on the machine for the first time this afternoon, there was an update in pacman for nvidia dkms. Took the update, and after reboot checked the display setting and the 2nd monitor was recognized. Activated and configured perfectly. Happy accident is fine by me.
