On my laptop I have installed EOS Atlantis in the Openbox version. Everything is up to date. Today I installed kvantum because I wanted to try something with the qt5 configuration. As a dependency kwindowsystem was installed.
After a logout and login my complete configuration of openbox was reset. All settings gone. My menu gone. I also used the xfce-panel for example. Also here, the whole configuration gone and everything on default settings.
Can anyone tell me what caused this? Was it kwindowsystem?
EDIT: Other tools are also effected. For example keypassxc now has no clue about my auto-type key.
EDIT 2: Hmm… it’s really very very strange.
I was about to backup some folders and files for reinstall of EOS tomorrow. In the process I had a look in the download folder. There is a folder .config. Created yesterday at 21:22. At that time the laptop was in standby and I sat at another computer for gaming. I would never ever copy this folder in the Download folder.
Now I copied this .config folder over the current one in the home directory and did a reboot. Now everything is back as before the above installation of kvantum. I am a bit confused.
