Upon starting up Konsole the indicator that shows where you would start typing is over to the right. If any commands are ran the text is not aligned as you would expect. Images below might make more sense. Is this a settings issue? Bug?
My initial thought is that it looks related to the font you have set for your terminal - try a more standard monospace font and see if it persists.
You were absolutely right. My “Fixed Width” font was set to “Noto Sans”. I changed it to “Hack” and that fixed the issue. Thanks!
