As you can see the cursor in konsole is out of place, this is a new install.
How can i change it?
This looks exact similar to your issue :
And also use of Monospace font is recommended according to other web results.
Changing to Monospace font solved it but why it is not working good with Noto font?
A terminal needs to use some kind of monospace/fixed width font or nothing will line up properly.
I believe there is a noto monospace version of you prefer noto.
That being said, you don’t have to use a monospace font for the entire UI like that. Only inside the terminal
Just wanted to follow-up now that I am in front of my machine.
Plasma lets you set a fixed width font in System Settings that is used whenever a monospace font is needed. Like this:
You can also override that in konsole itself in the profile:
