Konsole Always Opens Maximized
Are you opening the terminal with a shortcut? If yes, maybe check if there is some weird starting parameter for the shortcut (or the icon).
@ricklinux OK I just got done trying to fix Gary’s Dolphin checking everything I could think of, using some of the above suggestions here and I’m honestly at a lost. Sorry I could not help. Looks like in my case I’ll have to post on the KDE forums and create a bug report for him. I’ll keep an eye on this thread just in case someone comes up with some thing I didn’t think of.
@otherbarry it’s Konsole so just rightclick the titlebar, More Actions, Configure Special Window Settings.
Nothing works for me. It opens maximized. I don’t know when it started.
I noticed Gary’s Dolphin issue the day before yesterday, if that helps at all.
Same here i think.
https://bugs.kde.org/show_bug.cgi?id=426813
Hey Thanks but, i fixed mine. I rolled back my updates because i am running Btrfs without encryption using timeshift and snapshots thanks to @2000! Now it is working properly. I went back about a week just because and there were about 180 updates. I tried it first and it opened maximized so i changed it and closed and tried and it opened windowed so i updated and it works now.
OK good, glad. I’m going to leave that thread as it is and still make the bug report as if Gary and you both are still having the issue, simply because if it’'s happening to you two it’s happening to others. That way maybe they can figure out which update might of went sideways in the first place. I can roll him back even though he’s ext4, but would rather wait and see what the KDE forums come up with.
Never really noticed it, until I saw this post…
Having the same problem over here
Ya it was odd. It just started happening. I rolled back with my snapshots and it is okay now but I had to reinstall a couple things.
Hey guys already received a couple of replies in the bug report. Haven’t checked the KDE forums to see if anything posted there.
