On other distributions i could use my Kingston Datatraveler vault privacy without a problem. In Endeavour OS this was not the case. I got the error “Can not detect DTVP device!!”. I found the solution with google. I needed to run the command “modprobe sg”. After running that command i could use the secure usb drive. But now i need to run this command every time i want to use the drive. Is there a way to run this command automatically at startup?
See Automatic module loading with systemd in the ArchWiki.
I have made a config file “modprobe.conf” and put the line “modprobe sg” in it. This file i placed in “/etc/modules-load.d/” but this did not work.
Make a file called sg.conf.
sudo nano /etc/modules-load.d/sg.conf
This file should contain the module you wish to load; here simply enter …
sg
Thanks, that was it. ![]()
