Kernel / sound issue: HP ENVY x360
Share the output of the following.
ls -l /var/lib/aurbuild/x86_64
You can probably just do the following.
sudo rm -rf /var/lib/aurbuild/x86_64/root
aur sync -c linux-mainline
This worked perfectly, thanks. It’s downloading now.
Is it necessary to uninstall linux-next after the installation of linux-mainline or is it enough just to generate the grub config again, after installing the new kernel?
Sorry, I didn’t see this one. The installation is running now. Should I abort the download?
You can just ignore that if the other thing I said worked.
This builds the kernel and will create a package of it and add it to your localrepo, the build/compiling will take about 3 hours or so.
Then you will have to run the following to install it.
sudo pacman -Syu linux-mainline
Alright. So just installing linux-mainline with this command and generating the grub config again afterwards should do it, right? So it’s not necessary to uninstall linux-next.
Correct
Unfortunately, the installation failed and the linux-next kernel is still running. This probably has to do with all the dracut messages at the end of the installation: dracut module ‘
’ will not be installed, because command ‘
’ could not be found!
:: Post-transaction-Hooks werden gestartet
( 1/14) Creating system user accounts...
( 2/14) Reloading system manager configuration...
( 3/14) Creating temporary files...
( 4/14) Arming ConditionNeedsUpdate...
( 5/14) Updating the MIME type database...
( 6/14) Rebuilding certificate stores...
( 7/14) Updating module dependencies...
( 8/14) Updating initramfs...
:: Building initramfs for linux-lts (6.6.17-1-lts)
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux-lts.img 6.6.17-1-lts
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'systemd-pcrphase' will not be installed, because command '/usr/lib/systemd/systemd-pcrphase' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'tpm2- INSTALL /build/linux-mainline/pkg/linux-mainline/usr/lib/modules/6.8.0-rc5-1-mainline/kernel/virt/lib/irqbypass.ko
 STRIP   /build/linux-mainline/pkg/linux-mainline/usr/lib/modules/6.8.0-rc5-1-mainline/kernel/virt/lib/irqbypass.ko
 SIGN    /build/linux-mainline/pkg/linux-mainline/usr/lib/modules/6.8.0-rc5-1-mainline/kernel/virt/lib/irqbypass.ko
 ZSTD    /build/linux-mainline/pkg/linux-mainline/usr/lib/modules/6.8.0-rc5-1-mainline/kernel/virt/lib/irqbypass.ko.zst
 DEPMOD  /build/linux-mainline/pkg/linux-mainline/usr/lib/modules/6.8.0-rc5-1-mainline
Warning: 'make modules_install' requires /doesnt/exist. Please install it.
This is probably in the kmod package.
==> Tidying install...
 -> Removing libtool files...
 -> Purging unwanted files...
 -> Removing static library files...
 -> Compressing man and inftss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: btrfs-snapshot-overlay ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    803
dracut: Linked:                   1 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 42 files
dracut: Saved:                    690 B
dracut: Duration:                 0.023531 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/boot/initramfs-linux-lts.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-lts.img' done ***
:: Building fallback initramfs for linux-lts (6.6.17-1-lts)
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-lts-fallback.img 6.6.17-1-lts
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: *** Including module: modsign ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: virtiofs ***
dracut: Mode:                     real
dracut: Files:                    2010
dracut: Linked:                   8 files
dracut: Compared:                 458 files
dracut: Saved:                    1.42 MiB
dracut: Duration:                 0.019273 seconds
dracut: *** Creating image file '/boot/initramfs-linux-lts-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-lts-fallback.img' done ***
:: Building initramfs for linux-mainline (6.8.0-rc5-1-mainline)
dracut: Executing: /usr/bin/dracut --force --hostonly --no-hostonly-cmdline /boot/initramfs-linux-mainline.img 6.8.0-rc5-1-mainline
dracut: Mode:                     real
dracut: Files:                    802
dracut: Compared:                 43 files
dracut: Duration:                 0.005253 seconds
dracut: *** Creating image file '/boot/initramfs-linux-mainline.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-mainline.img' done ***
:: Building fallback initramfs for linux-mainline (6.8.0-rc5-1-mainline)
dracut: Executing: /usr/bin/dracut --force --no-hostonly /boot/initramfs-linux-mainline-fallback.img 6.8.0-rc5-1-mainline
dracut: Mode:                     real
dracut: Files:                    2006
dracut: Compared:                 453 files
dracut: Duration:                 0.019707 seconds
dracut: *** Creating image file '/boot/initramfs-linux-mainline-fallback.img' ***
dracut: *** Creating initramfs image file '/boot/initramfs-linux-mainline-fallback.img' done ***
( 9/14) Check if user should be informed about rebooting after certain system package upgrades.
(10/14) Compiling GSettings XML schema files...
(11/14) Updating icon theme caches...
(12/14) Checking which packages need to be rebuilt
(13/14) Updating the info directory file...
(14/14) Updating the desktop file MIME type cache...
[atman@kali ~]$ pacman -Qme
aurutils 18.5-1
brave-bin 1:1.62.165-1
linux-next-git 20240216.r0.gd37e1e4c52bc-1
linux-next-git-headers 20240216.r0.gd37e1e4c52bc-1
mailspring-bin 1.13.3-2
pamac-aur 11.7.1-2
[atman@kali ~]$ grub-mkconfig -o /boot/grub/grub.cfg
grub-mkconfig: Sie mĂŒssen dies als als root ausfĂŒhren
[atman@kali ~]$ sudo grub-mkconfig -o /boot/grub/grub.cfg
GRUB-Konfigurationsdatei wird erstellt
Hintergrund gefunden: /usr/share/endeavouros/splash.png
Linux-Abbild gefunden: /boot/vmlinuz-linux-next-git
Initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux-next-git.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-next-git-fallback.img
Linux-Abbild gefunden: /boot/vmlinuz-linux-mainline
Initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux-mainline.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-mainline-fallback.img
Linux-Abbild gefunden: /boot/vmlinuz-linux-lts
Initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-lts-fallback.img
Initrd-Abbild gefunden: /boot/amd-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-fallback.img
Warnung: Zur Erkennung anderer bootfĂ€higer Partitionen wird os-prober nicht ausgefĂŒhrt.
Die darauf befindlichen Systeme werden nicht zur GRUB-Bootkonfiguration hinzugefĂŒgt.
Schauen Sie in den Dokumentationseintrag GRUB_DISABLE_OS_PROBER.
BootmenĂŒ-Eintrag fĂŒr UEFI-Firmware-Einstellungen wird hinzugefĂŒgt
Detecting snapshots ...
Found snapshot: 2024-02-17 21:48:11 | timeshift-btrfs/snapshots/2024-02-17_21-48-10/@ | ondemand | N/A |
Found 1 snapshot(s)
WARNING: 'grub-mkconfig' needs to run at least once to generate the snapshots (sub)menu entry in grub the main menu. After that this script can run alone to generate the snapshot entries.
Unmount /tmp/grub-btrfs.IqYF17RU0D .. Success
abgeschlossen
[atman@kali ~]$
The output for
yay -S linux-mainline linux-mainline-headers
looks very similar:
aurutils 18.5-1
pamac-aur 11.7.1-2
[atman@kali ~]$ yay -S linux-mainline linux-mainline-headers
Sync Explicit (2): linux-mainline-6.8rc5-1, linux-mainline-headers-6.8rc5-1
[sudo] Passwort fĂŒr atman:
Warnung: linux-mainline-6.8rc5-1 ist aktuell -- Reinstalliere
AbhĂ€ngigkeiten werden aufgelöst
Nach in Konflikt stehenden Paketen wird gesucht
Paket (2)                   Alte Version  Neue Version  Netto-VerÀnderung
aur/linux-mainline          6.8rc5-1      6.8rc5-1               0,00 MiB
aur/linux-mainline-headers                6.8rc5-1             125,25 MiB
GesamtgrĂ¶ĂŸe der installierten Pakete:  255,82 MiB
GrĂ¶ĂŸendifferenz der Aktualisierung:    125,25 MiB
:: Installation fortsetzen? [J/n] j
(2/2) SchlĂŒssel im SchlĂŒsselbund werden geprĂŒft        [---------------------------------------------------------------------------------------] 100%
(2/2) Paket-IntegritĂ€t wird ĂŒberprĂŒft        [---------------------------------------------------------------------------------------] 100%
(2/2) Paket-Dateien werden geladen        [---------------------------------------------------------------------------------------] 100%
(2/2) Auf Dateikonflikte wird geprĂŒft        [---------------------------------------------------------------------------------------] 100%
(2/2) VerfĂŒgbarer Festplattenspeicher wird ermittelt        [---------------------------------------------------------------------------------------] 100%
:: PaketÀnderungen werden verarbeitet
(1/2) Reinstalliert wird linux-mainline        [---------------------------------------------------------------------------------------] 100%
(2/2) Installiert wird linux-mainline-headers        [---------------------------------------------------------------------------------------] 100%
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating initramfs...
dracut: Mode:                     real
dracut: Files:                    802
dracut: Duration:                 0.013533 seconds
dracut: Mode:                     real
dracut: Files:                    2006
dracut: Duration:                 0.014863 seconds
(4/4) Checking which packages need to be rebuilt
[atman@kali ~]$
If you mean those types of messages, that’s just standard output of dracut.
It looks like you installed an update for the lts kernel there.
If it’s still running, that means compiling is still going.
Interesting. How could this happen?
No, compiling is finished. I meant that the linux-next-kernel is still the active one used by the OS.
Basically linux-next is running fine, so there is no real issue. However, linux-mainline was updated two days before and is already 6.8rc5, while linux-next is still rc4. And linux-mainline should, in priciple, be be the safer pick as well.
I’m not sure I’m following, but if you were running mainline and the built linux-next-git and the installed it using this.
sudo pacman -Syu linux-next
Then it will install that kernel and also update any packages, so if at that time there was an update for the lts kernel it will install that as well. I would just use linux-mainline if I were you and check every now and then if you audio devices work in the lts or default kernel, if it at one point works you will know when you can switch over to a kernel already in in the repos.
Alright, thanks. Using linux-mainline was the intension, but the installation didn’t work with
Would
or
yay -Syu linux-mainline
be better or could it be worth a try from your point of view?
ls -l /var/cache/pacman/aurpkg
[atman@kali ~]$ ls -l /var/cache/pacman/aurpkg
insgesamt 185352
lrwxrwxrwx 1 atman atman        13 feb 19 18:55 aur.db -> aur.db.tar.gz
-rw-r--r-- 1 atman atman      1037 feb 19 18:55 aur.db.tar.gz
-rw-r--r-- 1 atman atman        45 feb 19 10:48 aur.db.tar.gz.old
lrwxrwxrwx 1 atman atman        16 feb 19 18:55 aur.files -> aur.files.tar.gz
-rw-r--r-- 1 atman atman    280840 feb 19 18:55 aur.files.tar.gz
-rw-r--r-- 1 atman atman        45 feb 19 10:48 aur.files.tar.gz.old
-rw-r--r-- 1 atman atman 136806189 feb 19 18:52 linux-mainline-6.8rc5-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 atman atman  26315056 feb 19 18:55 linux-mainline-docs-6.8rc5-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 atman atman  26371823 feb 19 18:53 linux-mainline-headers-6.8rc5-1-x86_64.pkg.tar.zst
[atman@kali ~]$
What’s the output of the following?
pacman -Ss linux-mainline
[atman@kali ~]$ pacman -Ss linux-mainline
aur/linux-mainline 6.8rc5-1 [Installiert]
    The Linux Mainline kernel and modules
aur/linux-mainline-docs 6.8rc5-1
    Documentation for the Linux Mainline kernel
aur/linux-mainline-headers 6.8rc5-1 [Installiert]
    Headers and scripts for building modules for the Linux Mainline kernel
[atman@kali ~]$ aur sync -c linux-mainline
==> Using [aur] repository
dependency KSMBD-MODULE satisfied by aur/linux-mainline
dependency VIRTUALBOX-GUEST-MODULES satisfied by aur/linux-mainline
dependency WIREGUARD-MODULE satisfied by aur/linux-mainline
sync: there is nothing to do
[atman@kali ~]$
It looks like linux-mainline is already installed. Does it show up in your Grub menu when you reboot?
Yes it is. It shows up in the Grub menu and starts without any issues as well. How can this be set as default?
6.8.0-rc5-1-mainline (64-bit)
Edit: Nevermind! Sound isn’t working with it. So linux-next is currently the way to go.
I don’t use grub, but there is a setting for it in /etc/default/grub but I can’t remember the name of the setting.
