After upgrading from linux 6.11.2.arch1-1 to 6.11.3.arch1-1 there have been issues with dgpu consuming max power after resuming system from suspend.
Prior to upgrading kernel as the dgpu is disabled, max power consumption would be below 20 watts, after upgrading kernel, after normal boot, max power consumption would still be below 20 watts, but after resuming system from sleep, max power consumption increases to over 50 watts.
lspci -k shows that nvidia driver is active when resuming system. After reboot it is disabled again.
I use supergfxctl to disable the dgpu, I am pretty sure it is an issue with the kernel as linux-lts does not have the issues.
Also, issue is present on linux 6.11.4.arch1-1.
