Lepux
September 13, 2023, 5:22am
1
Hello, I tried installing EndeavourOS but every time I boot into the installer it show me this error
kernel panic - not syncing: Attempted to kill init! exit code =0x00007e00
that’s an image for more info:
I only tried rebooting but nothing works, I tried searching for the
error code but I didn’t found anything at all
GjMan78
September 13, 2023, 7:03am
2
What do you use to create the live USB?
try using Ventoy and when booting choose “grub2 mode”
Lepux
September 13, 2023, 8:10am
3
I used Etcher.
I tried Ventoy and choosed grub2 mode, This time it showed a different error:
[ 77.185700] sd 9:0:0:0 [sdd] tag#0 device offline or changed
[ 77.185795] SQUASHFS error: Failed to real block 0x1855da0: -5
GjMan78
September 13, 2023, 8:41am
4
have you also tried in “normal mode”?
are you sure that the flash drive you are using is not faulty?
Lepux
September 13, 2023, 9:01am
5
Yes I’ve tried that
I’m not sure about the flash drive tho.
GjMan78
September 13, 2023, 9:04am
6
try using another flash drive if you can
Lepux
September 13, 2023, 9:13am
7
unfortunately I don’t have another one
GjMan78
September 13, 2023, 9:17am
8
ventoy can be installed on an external hard disk instead of a flash drive…
Lepux
September 13, 2023, 9:51am
9
i don’t have any external hard disk either xd
i’ll borrow or buy a flash drive later, i’ll tell you if the problem is solved or not when i do
pebcak
September 13, 2023, 10:15am
10
Just to discard a possible cause: did you check the integrity of the downloaded ISO to make sure if it is not damaged/corrupted?
Lepux
September 13, 2023, 10:27am
11
Yes, I tried it on a virtual machine and it worked just fine
Lepux
September 13, 2023, 12:46pm
12
I found an old flash drive, i tried it and it works
thank you so much for helping :D.
system
Closed
September 15, 2023, 12:46pm
13
