I would like to know if the discard=async option is now the default mount option for BTRFS, as mentioned in a Phonorix article.
I suppose a mount | grep btrfs would show if it is active or not.
If so, what should we do with fstrim.timer ? Should we disabled it once we start to use 6.2 ?
I installed the the 6.2 kernel a while back from testing on btrfs and didn’t know anything regarding this?
[ricklinux@eos-plasma ~]$ mount | grep btrfs
/dev/nvme1n1p2 on / type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=443,subvol=/@)
/dev/nvme1n1p2 on /home type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=257,subvol=/@home)
/dev/nvme1n1p2 on /swap type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=260,subvol=/@swap)
/dev/nvme1n1p2 on /var/cache type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=258,subvol=/@cache)
/dev/nvme1n1p2 on /var/log type btrfs (rw,noatime,compress=zstd:3,ssd,discard=async,space_cache=v2,subvolid=259,subvol=/@log)
Let me know on this? I don’t know either? I’m just not very familiar with all btrfs!
[ricklinux@eos-plasma ~]$ cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=7DD4-731C /boot/efi vfat defaults,noatime 0 2
UUID=d2451021-8cca-4935-b73b-ba725647fcdd / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=d2451021-8cca-4935-b73b-ba725647fcdd /home btrfs subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=d2451021-8cca-4935-b73b-ba725647fcdd /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=d2451021-8cca-4935-b73b-ba725647fcdd /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=d2451021-8cca-4935-b73b-ba725647fcdd /swap btrfs subvol=/@swap,defaults,noatime 0 0
/swap/swapfile swap swap defaults 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
Edit: I never changed anything. I just installed the 6.2 kernel from the testing repo. Been running it for a while.
hm, so that article was correct, this means that TRIM/discard is running by default now.
To disabled it, according to that article, you would need to use async=nodiscard mount option in /etc/fstab.
Not sure if we can run fstrim.timer along with that option. Perhaps no harm done or should we disable fstrim.service ?
Or maybe disable discard=async with the option async=nodiscard and keep fstrim.timer running ?
I think so, I’m not sure if the Kernel checks if the drive supports TRIM and enable that option, or if its something that it’s done without checking compatibility of the drive.
Btw, I believe that most SSD drives support it.
Edit: I’m using discard=async since last year, with fstrim.disabled, it is safe or at least safe for my use case.
So, when people get Kernel 6.2, they would need to choose if they want systemd timer for fstrim or disable it and use the asynchronous mode which will be the default for that Kernel.
I don’t think that you should use both at the same.
The difference for me now is that I don’t need that option in my fstab anymore since will be the default.
Thanks ricklinux for showing your /etc/fstab and clarifying that the defaults really changed for this matter.
I have a NTFS mount in which I almost don’t use in Linux, its mounted but usually Windows take care of it during system maintenance.
Sometimes I copy a file to it so I can access in both systems, but it’s not that usual for me to do it.
