Just updated linux kernel to 5.9 as I’m using the testing repo.
In this machine there is Intel and Radeon graphics. The radeon kernel module didn’t cause problems with kernel 5.8 series. But with kernel 5.9 the picture is very distorted at boot.
Blacklisting the radeon kernel module “fixed” it, and now I’m on Intel graphics.
So, I again recommend having also the LTS kernel (or another officially supported kernel), just in case.
I also had amdgpu driver package installed, but uninstalling that didn’t help.
So I just blacklisted the radeon kernel module.
This machine is actually not “very” old, only about 2 years. But admittedly this was a cheap model…
If you uninstalled the amdgpu driver then I guess the kernel would fall back to radeon; there were quite a few updates to amdgpu in 5.9 so it might take a couple of point-releases to smooth things out (but that’s pretty normal).
