I updated my kernel. After that I rebooted my system. now stuck on Loading initial ramdisk at boot.
Used chroot on live iso to install lts kernel it worked but every 5.16 kernel just stuck on there.
I also tried a fresh install still same results.Dont Know Why.
5.16 is still pretty new, so there might be problems with it. I would use LTS for now.
Unless you have a really good reason to use the latest mainline kernel (for example, having new hardware), generally, it’s a good idea to use LTS. There is less stress that way.
Next time 5.16 gets an update, after updating, try to boot into it to see if they fixed it. If not, stick to LTS.
In fact, even when 5.16 works fine (which, eventually, it probably will), it’s still a good idea to stick to LTS, unless you have a good reason not to.
I wish this was better documented. I wouldn’t even know where to put it though.
The only people that should not use the LTS in my opinion - anyone with extremely new hardware, or anyone who knows they want something specific and why (zen or hardened for instance).
Do you think LTS Headers should be installed by default during the installation process and users being told to switch to latest kernel only if required?
