KDE System Tray Does Not Work After Wakeup
Hello,
So this has been driving me crazy.
A lot of the time when I wake up my machine from sleep, the system tray will start acting weirdly.
The clock will freeze to the time the pc was put to sleep mode.
When clicking on Bluetooth, sound etc… icons, sometimes it just does not respond or it opens up something different from what I clicked on (for example I click on sound icon and I get power management settings beside it instead).
Same thing with application icons and the start menu, sometimes they respond to being clicked on or do not respond at all. Sometimes they only respond when clicking on them the first time to launch the applications and then stop responding afterwards.
I have searched online and found a fair share of system tray issues after wakeup but not necessarily similar to what I am facing.
This issue persisted for a long time through multiple updates.
I use Wayland (not sure if X11 is even supported anymore).
Would appreciate it if someone could point me to the right direction.
Thank you.
