I am having this issue since I installed EndeavourOS yesterday.
I have two monitors, when I select a primary monitor in the system settings GUI, the task bar goes to the opposite monitor.
When I unplug one monitor the taskbar doesn’t move to the connected monitor.
This seems like a very obscure issue.
@Peter25 In case of KDE: https://forum.endeavouros.com/t/dock-on-wrong-display/73314/2
Should it be MATE:
mate-display-properties and Set as primary for your primary monitor. Or (add a New panel, add items to it,) uncheck Expand, Right click select Move and picking at the right border you can drag it to the nth monitor. Easy peasy
Thanks for your reply, I’m using KDE I just didn’t know where to post.
I fixed it by right clicking the desktop and selecting ‘Enter edit mode’ to move the bar. No idea how it moved in the first place lol.
