KDE power profiles not changing
On a fresh KDE install, the power profile slider is in the middle in Balanced position, whenever I try to change it to something else, it jumps back to the middle and a message: “Failed to activate Performance mode” is displayed.
Device info: https://clbin.com/mb8WV
Thanks!
Perhaps check if the daemon is running:
systemctl status power-profiles-daemon
Also try the options from the command line:
 powerprofilesctl --help
Usage:
  powerprofilesctl COMMAND [ARGS…]
Commands:
  help       Print help
  version    Print version
  get        Print the currently active power profile
  set        Set the currently active power profile
  list       List available power profiles
  list-holds List current power profile holds
  launch     Launch a command while holding a power profile
For example:
powerprofilesctl list
● power-profiles-daemon.service - Power Profiles daemon
     Loaded: loaded (/usr/lib/systemd/system/power-profiles-daemon.service; enabled; vendor preset: disabled)
     Active: active (running) since Tue 2022-07-12 11:18:10 IST; 6h ago
   Main PID: 527 (power-profiles-)
      Tasks: 3 (limit: 9280)
     Memory: 5.4M
        CPU: 139ms
     CGroup: /system.slice/power-profiles-daemon.service
             └─527 /usr/lib/power-profiles-daemon
Jul 12 16:59:43 Omen power-profiles-[527]: Failed to activate driver 'platform_profile': Error writing '/sys/firmware/acpi/platform_profile': Operation not supported
Jul 12 16:59:44 Omen power-profiles-[527]: Failed to activate driver 'platform_profile': Error writing '/sys/firmware/acpi/platform_profile': Operation not supported
Jul 12 17:07:48 Omen power-profiles-[527]: Failed to activate driver 'platform_profile': Error writing '/sys/firmware/acpi/platform_profile': Operation not supported
Jul 12 17:07:49 Omen power-profiles-[527]: Failed to activate driver 'platform_profile': Error writing '/sys/firmware/acpi/platform_profile': Operation not supported
Also,
powerprofilesctl set power-saver Failed to communicate with power-profiles-daemon: g-io-error-quark: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dio_2derror_2dquark.Code15: Error writing '/sys/fi rmware/acpi/platform_profile': Operation not supported (15)
What says:
powerprofilectl list
Also do you have some settings in your BIOS/UEFI firmware settings in respect to your CPU performance?
:thinking:
sudo inxi -azC
  Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check
    bits: 64 type: MT MCP arch: Coffee Lake gen: core 9 built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF0
  Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 high: 801 min/max: 800/4500 base/boost: 2574/8300
    scaling: driver: intel_pstate governor: powersave volts: 0.9 V
    ext-clock: 100 MHz cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
    7: 800 8: 800 9: 801 10: 800 11: 800 12: 800 bogomips: 62431
  Vulnerabilities:
  Type: itlb_multihit status: KVM: VMX disabled
  Type: l1tf
    mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: spec_store_bypass
    mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v1
    STIBP: conditional, RSB filling
  performance:
    Driver:     platform_profile
    Degraded:   no
* balanced:
  power-saver:
No, don’t think so.
It’s not obvious to me what the cause of the failure is:
Perhaps more experienced forum members can take it from here and assist you.
Also, not sure if the following would reveal more info about this issue but it won’t hurt:
journalctl -b -0 | eos-sendlog
At the end, if all attempts to get power-profiles-daemon working would fail, you could use other alternatives like cpupower to set the CPU frequency scaling.
:eye: https://wiki.archlinux.org/title/CPU_Frequency_Scaling
Sure, whatever to help you diagonose this.
https://clbin.com/S8imy
Mobo: HP model: 8575 v: 21.17 serial: <superuser required> UEFI: AMI
    v: F.23 date: 07/06/2021
Check if there is a BIOS/UEFI firmware update for your system.
Also, here is the power-profiles-daemon Gitlab’s page:
Have a look for similar issues.
I am also an HP OMEN user and have the same problem as you. When I just installed the ISO image of the previous version of garuda Linux, the power-profiles-daemon can be used normally. When I upgraded the system, the stable kernel was also upgraded, and I encountered the same error as you. I didn’t know the reason at the time, I tried to use the latest ISO image file and still reported the same error in live mode. When I switched to the LTS kernel it worked fine. I tried it under stable kernel, system76-power works fine, you can try to downgrade the kernel version or change to use system76-power.
