I have an EndeavourOS installation which is about 2 years old (I tinkered a lot with it but it works without issues).
I decided to install plasma-wayland-session and select the Wayland option via SDDM, after login in the following happens:
It takes about 10 seconds to load the desktop wallpaper
It takes additonall about 40 seconds to load the taskbar + desktop icons (I can’t click anything yet!)
It takes about 30 seconds more until I can click on anything.
Sometimes between step 2-3 the whole screen turns black/white-ish.
So overall it takes me about 80 seconds to load my desktop and to be able to interact with it.
Compared on X11 it takes about 3 seconds and everything is loaded.
I am using a full AMD system: Ryzen 3600 + RX 6700 XT + NVME SSD…
Where would I start troubleshooting this issue? Or is it normal to have ~27x longer loading times on Wayland?
I am now encountering this same issue/behavior on my EndeavourOS host, using SDDM and plasma-wayland. SDDM is a black screen with my mouse that takes a while to load, then after signing into EndeavourOS using a plasma-wayland session it’s just my wallpaper and my mouse for another couple of minutes before the desktop environment actually loads.
