Hello,
Currently I am using Endeavour OS with KDE for a few months and so far I am really happy about it. However, I would like to ask some help because I run into a few issues I was not able to solve with the help of google alone.
I am using a HP-laptop which is currently about 2-3 years old. I am using a external monitor, mouse and keyboard which are connected to the laptop by a usb-c hub. The problem arises in most cases when I disconnect the laptop from the USB hub. The system will start to freeze completely after a few seconds and I need to hard-reboot in order to be able to make use of the laptop again. In some occasions, the hard-reboot doesn’t even work as the system keeps freezing during the KDE display manager or a few seconds after I’d entered my password. So the only way is to hard-reboot a couple of times until the system is behaving normally. After this stage is entered, the system is running smooth as like everything is stable without any instability whatsoever.
I followed this tutorial regarding the ACPI logs I saw in the journalctl command changing acpi_osi to Windows 2017. This did help a little for a few weeks but right now, the old problems are showing up more frequently that it became really annoying. As I do not have much knowledge from Linux and the underlying software, I am hoping some of you can help my out. I’ve created a logfile using the eos-log-tool and you can review it here:
If anybody can help me out, i’d really appreciate it. If there are more logfiles needed, please let me know. Thank you in advance.
