Recently I discovered thanks to a miss click that there is Meta + T to edit a window mosaic distribution but I didn’t knew how to use that feature.
After searching for some time I found some guy on Reddit explaining that moving a window with Shift pressed will allow you to use those mosaic areas and OMG IT’S AMAZING.
I don’t know why this is not documented, why there is no tab on the KDE Plasma settings with a ? button with some explanation on how to use it but this created a new discussion topic:
How do we save/manage new mosaic presets? There is a button to load a preset but I found no button to save or delete a new one.
Which other cool “hidden” features Plasma has but not well documented or not even mentioned anywhere?
Is there any website/forum/youtube channel with tips and updates about Plasma and so on?
Sorry if this is not the correct category for this topic but I didn’t knew where to post it
I have a little function for the wayland-compatible window/process killer that mimics the classic xkill…
Whether it should be pkill, wkill, or kkill I suppose is best as its really a kwin feature;
kkill() {
qdbus6 org.kde.KWin /KWin killWindow
To test it out you can just execute the bit between the curly brackets. It should produce a ‘killer’ icon over the cursor - anything you click will be killed. Esc can be used to cancel the invocation.
Not that I can recall using it really. But its there.
Maybe there was a misinterpretation of the 6.4 This Week In Plasma blog post? Nate says that in addition to the new Plasma 6.4 release, they have completed the new day/night wallpaper feature for the next release too - which might mean “not this release.”
I’m not sure that it is a clarification, though. I certainly don’t have the day/night settings available, but I just saw that I do seem to have some default day/night dynamic wallpapers installed (they are represented in the settings by having the thumbnail image half darkened). So I dunno. Maybe the feature has been shipped, and there’s some hidden setting somewhere that needs to be activated.
Ive seen the delineation since at least Plasma 6.0 (though appearing slightly different than in the release note scrots) .. I was sorta under the impression it was already working.
So still not crystal-clear I suppose, but its at least less mysterious that those particular checkboxes may be missing at the moment.
If I select one of the dynamic wallpapers (Kay, for example), it’s showing the dark version, so it appears to be working as it’s nighttime here. But the controls shown in the blog post don’t exist for me.
