KDE Plasma 6(Wayland) - Touchpad Gestures (Proper Ones)
I know, i know…i had my fare share of corporate work too…They all suck.
They don’t - it’s just a fact.
It’s for project managers or something…how else can you possibly make them seem useful? :rofl:
Look mr. CEO - i monitor productivity of every worker. i’m so useful!!11
While in reality they’re just the most annoying obstacles on people who do the work.
Illusion of control :trade_mark:
Oh, I see. I have installed fusuma from the AUR, which has made a global install, whereas the install using gem install would be in ~/.local. I’ve just found the config file here:
/usr/lib/ruby/gems/3.0.0/gems/fusuma-3.3.0/lib/fusuma/config.yml
Situations like that is the reason why I’m trying to avoid AUR when it’s possible and not causing too much butt-pain.
I see, I will reinstall, the AUR version requires to run sudo fusuma… (it works though)
My problem is rather ydotool, I do not understand how to start the deamon. I have tried to follow diverse comments on github, but I always get an error like this one from fusuma:
failed to connect socket `/tmp/.ydotool_socket': No such file or directory
Please check if ydotoold is running.
Have you tried -
systemctl --user enable  ydotool.service
systemctl --user start  ydotool.service
I was missing the --user option. Thanks!
But ydotool is still throwing the same error.
$ systemctl --user status ydotool.service
× ydotool.service - Starts ydotoold service
     Loaded: loaded (/usr/lib/systemd/user/ydotool.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Sun 2024-03-10 15:53:03 CET; 11min ago
   Duration: 5ms
    Process: 746 ExecStart=/usr/bin/ydotoold (code=exited, status=2)
   Main PID: 746 (code=exited, status=2)
        CPU: 5ms
So far, I could not get ydotool to work, but dotool works and seems easier / more intuitive.
OK, I could finally put everything together and get the pinch to close working in a Wayland session, even for KDE windows (using dotool) :smile:
Unfortunately, the KDE default gestures (especially the redundant 3-finger swipes left and right) are not overridden, they are clashing with custom gestures.
About this:
the explanation is certainly that you are using a single worspace, hence the inactive swipes left and right and limited usefulness of 4-finger swipes up and down.
Correct?
Yep, single workspace.
Mystery solved, I guess.
I’ve realised how fucked up this topic in Wayland when I continued to encounter posts of yours, Kresimir, at the other forums.
I had wasted several hours trying to find how KDE in the end implemented global shortcuts, at least a few examples of code.
Will try later to ask them directly in their Matrix server or email this italian KDE-guy from YouTube.
At this point, seems that the hack like ydotool did with a virtual input device as a daemon, is a clever idea when everything else is so obscure.
Another observation: fusuma is not required, touchegg+touché works as well when we issue a dotool or ydotool command.
Even in non XWayland apps?
Yes (I assume that Dolphin, KDE settings, Konsole, etc are native Wayland).
Well… touchegg crashes after 1 hour or 2, fusuma is certainly a cleaner option as touchegg is not supposed to work in a Wayland session.
Talked to Nico a bit, well, it’s hardcoded in the KWin and there’s currently no way to interact with this functionality outside of it.
