I ran the beta (which was fine), but I’d rather wait now for the release.
Should be good! Made the switch to Wayland when RustDesk started supporting it. No need for Xorg any more.
Even I did not know about telemetry. When I looked closely at the System settings > User Feedback, it was disabled. I played with the slider and the only issue were three points.
Firstly about Usage time
Secondly about the difference between “Detailed system information and basic usage statistics” and “Detailed system information and usage statistics”
Thirdly was the info about OpenGL and screen parameters
For the first, I am a bit concerned that KDE developers would need this metric.
For the second it is not clear what is the difference between these two. What extra information is specified.
For the third one, it might be easy to zoom in and identify a host using OpenGL and screen parameters in conjunction with all the ad metrics collected by various games and websites. Thus this information cannot be said to be anonymous. It can be used to target and isolate a particular host, with some effort.
Btw: Treat Williams - Great actor who died to soon … ![]()
Plasma 6.4 has been rolled out for Fedora 42 ![]()
Don’t worry, I’m sure it will be available for Arch Linux soon
Maybe even later this year ![]()
But but…Arch is suppossed to be first.
Fedora has really got on the ball with KDE releases now - hence it becoming an Edition alongside Gnome (Workstation) rather than just a Spin.
Yeah, but I’d rather them take their time and get it right. Maybe that’s a sign of getting old ![]()
I’ve always wondered, because I didn’t think it was Arch policy to hold back and evaluate, but to simply roll. However, the last couple of years observing the KDE rollouts, it seems they are holding out on us ![]()
Check your kernel… ![]()
I might just switch one of my laptops to Fedora Kde.
It’s worth trying it out. I suggest using the Network Installer (the Everything ISO) as this allows you to make the packages installed more minimal, and also up to date as it downloads the latest versions from the repos.
Thanks, but I’ll wait another day or two for Arch/EndeavourOS to release it (honestly, I already have it now, since I temporarily enabled testing to get the update)! I’ve been testing different Fedora/Fedora-based builds (KDE Workstation, GNOME Workstation, Nobara (KDE), and Bazzite (KDE)). It’s a good distribution, but it requires a little too much work to get things the way I like them. While I love and appreciate FOSS, I don’t want to be forced to use FOSS as the default, and then have to jump through some extra hoops to install non-FOSS software. Arch/EndeavourOS lets me do what I want..
Yes, setting up RPM Fusion is a bit of a pain. Also, you sometimes have to wait for the updates in RPM Fusion to catch up (an example from today). Although there’s sometimes a similar problem with some AUR packages.
Hopped over to Fedora KDE about a week ago on my laptop. Wasn’t expecting to get 6.4 on here before my Endeavour installation! Learned something new.
Favorite 6.4 update is Spectacle. Feels a lot smoother.
Hurry hurry, update your system ![]()
╰─❯ pacman -Qs plasma
local/angelfish 25.04.2-1 (kde-applications kde-network)
Web browser for Plasma Mobile
local/aurorae 6.4.0-1 (plasma)
A themeable window decoration for KWin
local/bluedevil 1:6.4.0-1 (plasma)
Integrate the Bluetooth technology within KDE workspace and applications
local/breeze 6.4.0-1 (plasma)
Artwork, styles and assets for the Breeze visual style for the Plasma Desktop
local/breeze-gtk 6.4.0-1 (plasma)
Breeze widget theme for GTK 2 and 3
local/breeze-plymouth 6.4.0-1 (plasma)
Plymouth theme for the Breeze visual style for the Plasma Desktop
local/drkonqi 6.4.0-1 (plasma)
The KDE crash handler
local/eos-breeze-sddm 25.02.1.1-1
EndeavourOS SDDM theme for KDE plasma based on breeze.
local/eos-settings-plasma 1.9-2
Plasma settings and theme for EndeavourOS
local/kaccounts-integration 25.04.2-1
Online account management system and its Plasma integration components
local/kactivitymanagerd 6.4.0-1 (plasma)
System service to manage user activities and track the usage patterns
local/kclock 25.04.2-1 (kde-applications kde-utilities)
Clock app for Plasma Mobile
local/kde-cli-tools 6.4.0-1 (plasma)
Tools based on KDE Frameworks to better interact with the system
local/kde-gtk-config 6.4.0-1 (plasma)
Syncs KDE settings to GTK applications
local/kde-material-you-colors 1.10.1-1
Automatic Material You Colors Generator from your wallpaper for the Plasma Desktop
local/kdecoration 6.4.0-1 (plasma)
Plugin based library to create window decorations
local/kdeplasma-addons 6.4.0-1 (plasma)
All kind of addons to improve your Plasma experience
local/keysmith 25.04.2-1 (kde-applications kde-utilities)
OTP client for Plasma Mobile and Desktop
local/kgamma 6.4.0-1 (plasma)
Adjust your monitor gamma settings
local/kglobalacceld 6.4.0-1 (plasma)
Daemon providing Global Keyboard Shortcut (Accelerator) functionality
local/kinfocenter 6.4.0-1 (plasma)
A utility that provides information about a computer system
local/klassy-bin 6.3.breeze6.3.5-1
Highly customizable binary Window Decoration, Application Style and Global Theme plugin for recent versions of the KDE Plasma desktop.
local/kmenuedit 6.4.0-1 (plasma)
KDE menu editor
local/konsave 2.2.0-5
Save and apply your KDE Plasma customizations with just one command!
local/kpipewire 6.4.0-1 (plasma)
Components relating to pipewire use in Plasma
local/krdp 6.4.0-1 (plasma)
Library and examples for creating an RDP server
local/krecorder 25.04.2-1 (kde-applications kde-utilities)
Audio recorder for Plasma Mobile and other platforms
local/kscreen 6.4.0-1 (plasma)
KDE screen management software
local/kscreenlocker 6.4.0-1 (plasma)
Library and components for secure lock screen architecture
local/ksshaskpass 6.4.0-1 (plasma)
ssh-add helper that uses kwallet and kpassworddialog
local/ksystemstats 6.4.0-1 (plasma)
A plugin based system monitoring daemon
local/kwallet-pam 6.4.0-1 (plasma)
KWallet PAM integration
local/kwayland 6.4.0-1 (plasma)
Qt-style Client and Server library wrapper for the Wayland libraries
local/kweather 25.04.2-1 (kde-applications kde-utilities)
Weather application for Plasma Mobile
local/kwin 6.4.0-1 (plasma)
An easy to use, but flexible, Wayland compositor
local/kwrited 6.4.0-1 (plasma)
KDE daemon listening for wall and write messages
local/layer-shell-qt 6.4.0-1 (plasma)
Qt component to allow applications to make use of the Wayland wl-layer-shell protocol
local/libkscreen 6.4.0-1 (plasma)
local/libksysguard 6.4.0-1 (plasma)
Library to retrieve information on the current status of computer hardware
local/libplasma 6.4.0-1 (plasma)
Plasma library and runtime components
local/milou 6.4.0-1 (plasma)
A dedicated search application built on top of Baloo
local/ocean-sound-theme 6.4.0-1 (plasma)
Ocean Sound Theme for Plasma
local/oxygen 6.4.0-1 (plasma)
KDE Oxygen style
local/oxygen-sounds 6.4.0-1 (plasma)
The Oxygen Sound Theme
local/plasma-activities 6.4.0-1 (plasma)
Core components for KDE Activities
local/plasma-activities-stats 6.4.0-1 (plasma)
A library for accessing the usage data collected by the activities system
local/plasma-browser-integration 6.4.0-1 (plasma)
Components necessary to integrate browsers into the Plasma Desktop
local/plasma-desktop 6.4.0-1 (plasma)
KDE Plasma Desktop
local/plasma-disks 6.4.0-1 (plasma)
Monitors S.M.A.R.T. capable devices for imminent failure
local/plasma-firewall 6.4.0-1 (plasma)
Control Panel for your system firewall
local/plasma-integration 6.4.0-1 (plasma)
Qt Platform Theme integration plugins for the Plasma workspaces
local/plasma-nm 6.4.0-1 (plasma)
Plasma applet written in QML for managing network connections
local/plasma-pa 6.4.0-1 (plasma)
Plasma applet for audio volume management using PulseAudio
local/plasma-sdk 6.4.0-1 (plasma)
Applications useful for Plasma development
local/plasma-systemmonitor 6.4.0-1 (plasma)
An interface for monitoring system sensors, process information and other system resources
local/plasma-vault 6.4.0-2 (plasma)
Plasma applet and services for creating encrypted vaults
local/plasma-welcome 6.4.0-1 (plasma)
A friendly onboarding wizard for Plasma
local/plasma-workspace 6.4.0-3 (plasma)
KDE Plasma Workspace
local/plasma-workspace-wallpapers 6.4.0-1 (plasma)
Additional wallpapers for the Plasma Workspace
local/plasma5support 6.4.0-1 (plasma)
Support components for porting from KF5/Qt5 to KF6/Qt6
local/plasma6-applets-panel-colorizer 4.3.1-1
Latte-Dock and WM status bar customization features for the default Plasma panels
local/plasma6-applets-wallpaper-effects 0.6.0-1
Plasma Widget to enable Active Blur and other cool effects for all wallpaper plugins
local/plasma6-applets-weather-widget-3-git r392.e92c287-1
Weather Widget 3 for KDE Plasma 6
local/plasmatube 25.04.2-1 (kde-applications kde-multimedia)
Kirigami YouTube video player based on QtMultimedia and youtube-dl
local/plymouth-kcm 6.4.0-1 (plasma)
KCM to manage the Plymouth (Boot) theme
local/polkit-kde-agent 6.4.0-1 (plasma)
Daemon providing a polkit authentication UI for KDE
local/powerdevil 6.4.0-1 (plasma)
Manages the power consumption settings of a Plasma Shell
local/print-manager 1:6.4.0-1 (plasma)
A tool for managing print jobs and printers
local/qqc2-breeze-style 6.4.0-1 (plasma)
local/sddm-kcm 6.4.0-1 (plasma)
KDE Config Module for SDDM
local/spectacle 1:6.4.0-1 (plasma)
KDE screenshot capture utility
local/systemsettings 6.4.0-1 (plasma)
KDE system manager for hardware, software, and workspaces
local/tokodon 25.04.2-1 (kde-applications kde-network)
A Mastodon client for Plasma
local/wacomtablet 6.4.0-1 (plasma)
GUI for Wacom Linux drivers that supports different button/pen layout profiles
local/xdg-desktop-portal-kde 6.4.0-1 (plasma)
A backend implementation for xdg-desktop-portal using Qt/KF5
Screenshots with spectacle still take some getting used to.
This 6.4 is really very well done. I have the whole morning to take care of it ![]()
Updated, - and as flawless as ever!
Edit: Holy crap, - did they fix sRGB? My screen is actually black now, and colours are balanced. I’ve been fighting contrast and brightness issues forever on Wayland, but it looks like icm colour profiles apply properly now and screens calibrate properly. Amazing!
