KDE panel missing after install and reboot
Hi
I just installed eOS KDE plasma but I have a strange problem. After the installation everything seemed to be ok but then i upgraded the system and enabled my KDE theme (ant-dracula) and rebooted.
After the login i don’t have a panel in Plasma anymore and nothgin happens when I try to add it again.
Open a terminal (alt+f2 konsole enter), type plasmashell --replace and post any errors.
:edit:
You can also try to reset plasma back to defaults, this is my method:
lookandfeeltool -a org.kde.breeze.desktop
#log out/in
If that doesn’t work:
cd /home/<your-username>/.config
mkdir plasma-old
mv *rc plasma-old/
mv kdeglobals plasma-old/
reboot
plasmashell --replace works but if i logout and login the panel is again missing.
Same happens if I try to do the other two commands.
Maybe try this:
https://forum.kde.org/viewtopic.php?f=289&t=164286
Same stuff here (usually indeed after post-big-update reboots ). The “regular” Plasma panel doesn’t appear, Latte dock crashes.
Perhaps because
This was a major bugfix week
:wink:
