Hi guys!
Got a little problem with eos installation recently. I want to install minimal DE with no unnecessary apps to customize it by myself later, but I don’t know which packages should I uncheck in KDE-Desktop section.
Hope you could help me!
Hi guys!
EOS is a minimal install so honestly I don’t believe you need to remove anything. Its already pretty basic. Other than personal preference for Apps there is no need.
Thanks for the answer! Then I’ll just install without unchecking anything
depends really how minimal you want to go.
This is the list of packages that gets installed when you choose KDE in EnOS installer.
Personally, if I were to go minimal, I could think of unchecking quite a few of them.
For example, Haruna. I don’t understand why that choice should be made on my behalf.
ark
bluedevil
breeze-gtk
dolphin
dolphin-plugins
ffmpegthumbs
fwupd
gwenview
haruna
kate
kcalc
kde-cli-tools
kde-gtk-config
kdeconnect
kdegraphics-thumbnailers
kdenetwork-filesharing
kdeplasma-addons
kgamma
kimageformats
kinfocenter
kio-admin
kio-extras
kio-fuse
konsole
kscreen
kwallet-pam
kwayland-integration
libappindicator-gtk3
maliit-keyboard
okular
plasma-browser-integration
plasma-desktop
plasma-disks
plasma-firewall
plasma-nm
plasma-pa
plasma-systemmonitor
plasma-workspace
powerdevil
print-manager
sddm-kcm
spectacle
xdg-desktop-portal-kde
xsettingsd
xwaylandvideobridge
eos-plasma-sddm-config
eos-settings-plasma
If you are really interested of having a minimal install, I would recommend installing Arch Linux and add whatever you decide yourself to your installation.
Yes it’s pretty minimal for a KDE environment and this way you will end up with a system that should work as expected.
I forgot about Haruna I would probably remove this for a minimal install as I think vlc is now called in as a dependency
Yes, I guess so. As a dependency of a dependency of some dependency of something
In my opinion, if you want to get a minimal kde install, you would just need plasma-desktop plus sddm on an Arch base install and build it up from there.
