I am issuing noise with my JPL headphones the sound is good for amount of time and then it becomes noisy and unclear, I was using pulseaudio and it works fine but again the noise her is the output of pacmd list-cards
index: 3
driver: <module-bluez5-device.c>
owner module: 27
properties:
device.description = "JBL LIVE200BT"
device.string = "E8:07:BF:6E:E4:0B"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_E8_07_BF_6E_E4_0B"
bluez.class = "0x240404"
bluez.alias = "JBL LIVE200BT"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
bluetooth.codec = "sbc"
bluetooth.battery = "90%"
profiles:
a2dp_sink: High Fidelity Playback (A2DP Sink) (priority 40, available: unknown)
handsfree_head_unit: Handsfree Head Unit (HFP) (priority 30, available: unknown)
off: Off (priority 0, available: yes)
active profile: <a2dp_sink>
sinks:
bluez_sink.E8_07_BF_6E_E4_0B.a2dp_sink/#2: JBL LIVE200BT
sources:
bluez_sink.E8_07_BF_6E_E4_0B.a2dp_sink.monitor/#3: Monitor of JBL LIVE200BT
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
I thought the problem may reside in pulseaudio, so I switched to pipewire but the problem is that my headphones is connected but there is not sound. thanks in advance.
