Journalctl does not find journal files
The code block?
With markdown:
some code
thanks you so much :+1:
Have you already tried to both remove files and restart service, and then reboot?
Yes. But it doesn’t help.
I’m out of ideas for now :sweat_smile:
Let’s see:
sudo dmesg --level=err,warn
$ sudo dmesg --level=err,warn
[    0.204986]   #2
[    0.206011]   #3
[    0.207013]   #4
[    0.208010]   #5
[    0.210000]   #6
[    0.211035]   #7
[    0.212013]   #8
[    0.213010]   #9
[    0.215009]  #10
[    0.216013]  #11
[    0.534843]  PPR X2APIC NX GT IA GA PC GA_vAPIC
[    1.401728] ata2.00: NCQ Send/Recv Log not supported
[    1.485078] ata2.00: NCQ Send/Recv Log not supported
[    2.268905] ata4.00: supports DRM functions and may not be fully accessible
[    2.269471] ata4.00: NCQ Send/Recv Log not supported
[    2.270763] ata4.00: supports DRM functions and may not be fully accessible
[    2.271093] ata4.00: NCQ Send/Recv Log not supported
[    3.051699] ata6.00: supports DRM functions and may not be fully accessible
[    3.055037] ata6.00: supports DRM functions and may not be fully accessible
[    4.133244] sp5100-tco sp5100-tco: Watchdog hardware is disabled
[    4.137746] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[    5.370008] amdgpu 0000:2d:00.0: amdgpu: SMU driver if version not matched
[    5.430123] usb 3-1: 3:1: cannot get freq at ep 0x86
[    5.502914] usb 3-1: 3:2: cannot get freq at ep 0x86
[    5.582657] usb 3-1: 3:3: cannot get freq at ep 0x86
[    6.091512] usb 3-1: Warning! Unlikely big volume range (=3896), cval->res is probably wrong.
[    6.091516] usb 3-1: [7] FU [Mic Capture Volume] ch = 1, val = 200/4096/1
[    6.734045] kauditd_printk_skb: 226 callbacks suppressed
[   12.944355] kauditd_printk_skb: 13 callbacks suppressed
[   20.484823] kauditd_printk_skb: 16 callbacks suppressed
[   26.216765] kauditd_printk_skb: 1 callbacks suppressed
Is there something you are leaving out like a power loss while system was running, a power loss while system was updating?
Radiation interference during alien invasion? :flying_saucer:
:upside_down_face:
P.S. Wouldn’t hurt to try full update again, just in case
sudo pacman -Syu
I do have some other problems - I was hoping to be able to fix them by being able to access the journal…
For example, I have problems with bluetooth audio and my shutdown sometimes takes ages while displaying No irq handler for vector. I once did a reset while this message was showing, because I was in a bit of a hurry. After restarting the journal, I noticed, that I sometimes get the message, that /tmp can’t be unmounted.
I tried deleting the logs, then restart the service, and then do the update. No changes.
I had the same problem, trying to remember what I did to fix, the journals are not persisting, if I remember I will post back…
OK think it was… Edit /etc/systemd/journald.conf
Change (it may be hashed out) or add:
[Journal]
Storage=persistent
Around line 14 for me.
This also gives the same result, still no journal files found.
Did you restart the service or reboot?
Multiple times in multiple combinations.
If I set Storage to volatile, the log works after a reboot. However, this is not a real solution for me, since I don’t want the log to be volatile.
What filesystem are you using?
ext4
sudo mv /var/log/journal /var/log/journal-old
sudo systemd-tmpfiles --create --prefix /var/log/journal
Change back to persistent. Reboot and see if that does it.
This was a while ago for me so the above is from my history file :smiley:
No, doesn’t work.
