Hey I am trying to get Japanese keyboard working on my laptop, and all the keyboard on gnome don’t work, so I am trying to get Japanese Anthy working but it doesn’t exist. How do I download Japanese Anthy Keyboard. I am running Gnome version 44.5
https://wiki.archlinux.org/title/Input_Japanese_using_uim
Edit: Maybe this also helps
https://www.reddit.com/r/gnome/comments/zn1ns1/japanese_keyboard/
For what it’s worth, I use Mozc on GNOME and haven’t had issues.
Whoops meant to reply to OP
yay -Ss anthy
shows some alternatives. But I don’t know which of them is useful, if any.
Ok I got it working ありがと
Great!
For the record, what did you eventually do?
I installed the Japanese Anthy Package
sudo pacman -Sy ibus-anthy
then I rebooted my system, went to the keyboard settings and it was there, with the gear Icon
You really should have marked the post that gave you the solution which is post #4
I’ve been using fcitx-mozc
for many years and it’s been great apart from not working on the steam linux app, but works in every game. I used to use ibus-anthy
and switched forgot why, but you can always look into it and compare them.
