Jami-qt hasen’t worked for me in awhile now . It installs normal from Community repo ,but all I get is icon on system tray . There I’m not able to do anything . Right clicking on icon gives selection of show jami and quit , but neither work . I have to use ksysguard to force close .
I did a fresh install yesterday (KDE) , but still same results . Is there a fix ?
Bleachbit installs and works , only issue is it closes immediatly after running scan . Removed checkmark in preferences ( exit after cleaning ), no change . Not a deal breaker but is annoying .
Really hoping to get Jami working again ! Thanks …
“Using locale: en_CA”
11:33:23.304 os_core_unix.c !pjlib 2.11 for POSIX initialized
Daemon is running
No accounts to migrate
Screen saver dbus interface: “org.freedesktop.ScreenSaver”
Can’t update current account info data for “”
QQmlApplicationEngine failed to load component
qrc:/src/app/MainApplicationWindow.qml:108:5: Type DaemonReconnectPopup unavailable
qrc:/src/app/commoncomponents/DaemonReconnectPopup.qml:26:1: Type BaseModalDialog unavailable
qrc:/src/app/commoncomponents/BaseModalDialog.qml:109:5: Type DropShadow unavailable
qrc:/qt-project.org/imports/Qt5Compat/GraphicalEffects/DropShadow.qml:6:1: Cannot load library /usr/lib/qt6/qml/Qt5Compat/GraphicalEffects/private/libqtgraphicaleffectsprivateplugin.so: (libQt6ShaderTools.so.6: cannot open shared object file: No such file or directory)
Main window loaded using OpenGLRhi
NetworkManager client initialized, version: 1.40.8 , daemon running: yes , networking enabled: yes
primary network connection: ca1e2a82-2b4c-30cf-9f7d-1b750a0a0321 default: yes
Still lost on solution to fix . I’m i the only one having this problem?
Hi , anthony93 . Thank you , working now !
I ran this command (pacman -Qi qt6-shadertools ) and recieved error (error: package ‘qt6-shadertools’ was not found ) . Ran this command ( yay -s qt6-shadertools ) found and installed . Now all working !
Not sure why it wasen’t installed while installing Jami-qt + deamon . .
Anyway all working now and thank you for help . HAPPY HOLIDAY’S
If qt6-shadertools isn’t installed, then that’s exactly what you need to do to fix it.
Since jami-qt needs the package and it wasn’t included in its dependency list (that’s why it wasn’t installed when you installed jami), you need to notify the developer of jami-qt to include that dependency.
Also, please “mark as solution” to make it easier for other users to refer to this post.
qt6-shadertools is referenced in a jami-qt bug report from October. It is currently an optional dependency, and as no one else has commented, it is still considered optional.
