Thanks for a great Distribution. I’ve been using Manjaro for over a year, but liking the slimmed down Arch feeling of EndeavourOS. I use Linux as primary for work, I work for an MSP/Security IT practice so I could be in multiple client environments all day. I specifically use IcedTea-Web for Connectwise Control which works great on Manjaro, but it freezes EndeavourOS, at least that’s when the freezing happens.
I have attempted picking my Kernel upon Reboot but I’m unable to get the option to select one.
I extracted the following errors right at the time of failure:
Summary
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: [gfxhub0] retry page fault (src_id:0 ring:0 vmid:4 pasid:32769, for process Xorg pid 7167 thread Xorg:cs0 pid 7168)
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: in page starting at address 0x800100c03000 from client 27
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: VM_L2_PROTECTION_FAULT_STATUS:0x00401031
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: Faulty UTCL2 client ID: TCP (0x8)
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: MORE_FAULTS: 0x1
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: WALKER_ERROR: 0x0
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: PERMISSION_FAULTS: 0x3
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: MAPPING_ERROR: 0x0
May 27 20:49:25 volz-lt01 kernel: amdgpu 0000:06:00.0: amdgpu: RW: 0x0
Also details of my Laptop:
inxi -Fxxxc0
System: Host: volz-lt01 Kernel: 5.10.39-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.21.5
tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: LightDM 1.30.0, SDDM Distro: EndeavourOS base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20NKS0U000 v: ThinkPad T495 serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 20NKS0U000 serial: <superuser required> UEFI: LENOVO v: R12ET57W(1.27 ) date: 11/24/2020
Battery: ID-1: BAT0 charge: 10.8 Wh (21.0%) condition: 51.5/50.5 Wh (101.9%) volts: 11.1 min: 11.6 model: LGC 02DL007
type: Li-poly serial: 1724 status: Discharging cycles: 80
CPU: Info: Quad Core model: AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
note: check rev: 1 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 33538
Speed: 1271 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1271 2: 1226 3: 1222 4: 1222 5: 1259
6: 1225 7: 1221 8: 1220
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Lenovo driver: amdgpu v: kernel bus-ID: 06:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 4-2.1:4 chip-ID: 13d3:56a6
class-ID: 0e02 serial: 0001
Display: x11 server: X.org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.39-1-lts running: yes
Sound Server-2: JACK v: 0.125.0 running: no
Sound Server-3: PulseAudio v: 14.2 running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 01:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlan0 state: up mac: 0c:dd:24:ed:16:15
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3400
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0f0 state: down mac: 98:fa:9b:d9:b8:bb
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: 98:fa:9b:d9:b8:ba
Drives: Local Storage: total: 238.47 GiB used: 11.62 GiB (4.9%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN720 SDAQNTW-256G-1001 size: 238.47 GiB speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: 19285E429493 rev: 10190101 temp: 33.9 C scheme: GPT
Partition: ID-1: / size: 224.51 GiB used: 11.62 GiB (5.2%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 43.5 C mobo: 0.0 C gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 0
Info: Processes: 231 Uptime: 10m wakeups: 1 Memory: 13.61 GiB used: 1.47 GiB (10.8%) Init: systemd v: 248 Compilers:
gcc: 11.1.0 Packages: pacman: 1155 Shell: fish v: 3.2.2 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.03
