I’ve been struggling with fan control on my system and wanted to share my experience, hoping for advice or confirmation if anyone else is encountering the same issue. Here’s the situation:
I recently tried using fan-control. I followed all the instructions, installed the necessary udev rules, and lm-sensors. However, just like with CoolerControl, no fans are available for configuration. It seems like the same issue persists across tools.
I suspect there’s a deeper issue here since I can’t access fan control via the motherboard. Below is a summary of what I’ve tried so far:
Fan Control: Installed and set up everything as instructed, but no fans are detected.
CoreCtrl: Installed and tested, but again, no access to system fans.
CoolerControl: Reinstalled it, this time using the AUR package (surprisingly easy!). Still, no fans were listed for control.
Here are some screenshots showing the tools and their outputs:
After running sensors-detect, I discovered my motherboard contains an unknown Super-I/O chip with ID 0x8689. Unfortunately, this chip is not currently recognized or supported by the lm_sensors or nct6775 modules. This seems to be a common issue with motherboards like the Gigabyte B650E AORUS ELITE X AX, as confirmed by GitHub discussions and Reddit posts:
Maybe, maybe it does, there is something seemingly very sensible in the last posting “it means you have Secure Boot activated. You need to deactivate it in the BIOS” - this might be the issue why the Board is protecting acpi. Gonna install Endeavour again tomorrow and give it a shot!
yep, already tried with “acpi_enforce_resources=lax” added to grub cfg and running sensors-detect but to no avail. Guess I’m gonna stay on Win for now.
Ok, I’ve tried to disable Secure Boot but also to no avail. Also the IT87 Project didn’t help, seems like the mainboard doesn’t come with an IT87 chip after all.
