Hello,
I am having issues logging into my Plasma installation. When I try to login after a recent reboot, it just says “Login Failed.” I was messing around with my shell earlier today, as I changed it to fish, but I believe I set everything up correctly. I have tried to login via TTY as root and as my usual login, but it always says password incorrect. Is there anyway to save my installation? I really need this system to be back online tomorrow, so any help is greatly appreciated!
Thanks,
Steam
EDIT: I am sure that my password is correct, as I had it written down, and have used it so many times that I know it by heart and muscle memory.
Maybe the keyboard layout isn’t correct? Maybe ‘y’ and ‘z’ are swapped etc. Try to write your password inside the user name input fields, so you can see if somehow it got messed up.
With a chroot and a password reset, it won’t matter if the keyboard is correct or not. It should be the same incorrect sequence after, and then they can look into a possible keyboard issue. Although, it will probably need another password reset again after hahaha.
I have had something break my password a couple if times in the past. It’s not normal, but it’s not impossible.
Alright, so I was able to chroot in and change my password, however I still am unable to login both via GUI and TTY. I changed the password to an easily typed one to avoid the keyboard layout playing a factor in it. Any ideas as to what to try next? (Also I was chrooted in correctly as my folders showed up when I ran ls)
Thanks,
Steam
