BTW, you could also try and remove the Nvidia drivers, nvidia 470xx isn’t officially supported anymore and given the fact that the last update on that package was in April, I’m not so sure it will work with the current kernel version.
Also remove the utils package, after that, you can reboot the system. When the system is booted up, just toy around if you like the default video drivers.
I’m not completely sure, but if you don’t like it you could install Nouveau, but I’m not sure if it is installed by default. (It is a long time ago that I used a machine with a Nvidia GPU)
Thanks for saving my files.
Nvidia root cause of evetything.
Before I mess it up again, I’ll backup files & fresh install latest EOS iso. I’ll not use the nvidia, its more of pain than actual use to me.
