I recently installed Hyprland but it doesn’t show up when I try to login. (You know, the place that says Plasma (Wayland) or something.)
Prove it.
pacman -Q | grep -A 0 -E "(hypr|wayland)"
and
pacman -Qi hyprland
Next time, copy the text from your terminal, and paste it here, like this:
egl-wayland 4:1.1.16-1
hyprcursor 0.1.10-1
hyprland 0.45.0-2
hyprlang 0.5.3-1
hyprutils 0.2.6-1
hyprwayland-scanner 0.4.2-1
lib32-wayland 1.23.1-1
qt5-wayland 5.15.15+kde+r60-1
qt6-wayland 6.8.0-1
wayland 1.23.1-1
wayland-protocols 1.38-1
xdg-desktop-portal-hyprland 1.3.8-1
xorg-xwayland 24.1.4-1
and
qi hyprland
Version : 0.45.0-2
Description : a highly customizable dynamic tiling Wayland compositor
Architecture : x86_64
URL : https://github.com/hyprwm/Hyprland
Licenses : BSD-3-Clause
Groups : None
Provides : wayland-compositor
Depends On : cairo aquamarine libaquamarine.so=4-64 gcc-libs glibc glib2 libgobject-2.0.so=0-64 glslang
hyprcursor libhyprcursor.so=0-64 hyprlang libhyprlang.so=2-64 hyprutils libhyprutils.so=1-64
libdisplay-info libdisplay-info.so libdrm libglvnd libEGL.so=1-64 libGLESv2.so=2-64
libOpenGL.so libinput libliftoff libliftoff.so libx11 libxcb libxcomposite libxcursor
libxfixes libxkbcommon libxkbcommon.so=0-64 libxrender mesa opengl-driver pango
libpango-1.0.so=0-64 libpangocairo-1.0.so=0-64 pixman libpixman-1.so=0-64 seatd libseat.so
systemd-libs libsystemd.so tomlplusplus libtomlplusplus.so libudev.so vulkan-icd-loader wayland
libwayland-client.so libwayland-server.so=0-64 wayland-protocols xcb-proto xcb-util
xcb-util-errors xcb-util-image xcb-util-keysyms xcb-util-renderutil xcb-util-wm xorg-xinput
xorg-xwayland
Optional Deps : cmake: to build and install plugins using hyprpm [installed]
cpio: to build and install plugins using hyprpm [installed]
meson: to build and install plugins using hyprpm [installed]
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 55.34 MiB
Packager : Caleb Maclennan <alerque@archlinux.org>
Build Date : Sat 16 Nov 2024 04:28:00 PM EST
Install Date : Mon 18 Nov 2024 12:06:29 AM EST
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
Now, the reason you don’t see Hyprland in the menu is because you didn’t install like you thought you did.
You can do it like this:
sudo pacman -S hyprland
I have a hypr config folder though.
That doesn’t matter if you don’t have the “hyprland
” package installed or at least one of its AUR variants.
Notice that my pacman Qi hyprland
shows a full output because I have it installed, and it shows up in my display manager (login menu).
Also I used an install script ()
Cool cool cool.
Start with that next time, please.
Don’t run scripts you don’t understand.
Which script did you run? Meaning from which website. Please don’t show me a screenshot with a downloaded file again.
Also, I feel like discriminating against you for using Google Chrome. But I won’t.
Here’s a recent comparison video, though it misses the mark on Brave: https://youtu.be/JaTRtAwL5e8
