few days ago maybe 2, so i did my system update, i got grep update too, after after whatever i type in terminal i got this kind of error- same thing all the time,
egrep: warning: egrep is obsolescent; using grep -E
Both egrep and fgrep have been deprecated since 2007. GNU Grep 3.8 makes that deprecation visible with the hope that it will induce people to use the standard methods.
If the problem is solved, go to the post that helped you the most in solving the problem, in this case @adjagu . Then click on the three horizontal dots, the click on “Solution”. This will trigger the forum software to take appropriate actions.
i think sometimes leave post as not solved, WHY? = because others can write their opinion or questions, but not all the time, sorry btw for leaving this post as not solved !
