I make repository of mine on GitHub to install calamares (I named it hel-calamares)on the iso of the distro that I will create and I added the repository in mirrorlist which in ect/pacman.d like that
[helwan-linux]
Server = https://github.com/helwan-linux/hel-repos
I gave this command it gave Error:
sudo pacman-conf -f /etc/pacman.d/mirrorlist
I added it in pacman.conf manualy
[helwan-linux]
I gave this command : sudo pacman -S hel-calamares
warning: database file for ‘helwan-linux’ does not exist (use ‘-Sy’ to download)
error: could not register ‘helwan-linux’ database (database already registered)
error: target not found: hel-calamares
then this command : sudo pacman -Sy helwan-linux
:: Synchronizing package databases…
endeavouros is up to date
core is up to date
helwan-linux.db failed to download
extra is up to date
multilib is up to date
error: failed retrieving file ‘helwan-linux.db’ from github.com : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
I put hel-calamares out of hel-repo to be https://github.com/helwan-linux/
then : sudo pacman -S pacman then ex-commands to install and add to mirror
warning: pacman-6.0.2-8 is up to date – reinstalling
error: failed to prepare transaction (could not find database)
help please
