Issue installing EOS on Virtualbox [solved]
Hi guys
I’ve some Linux OS in virtualbox, even manjaro that use Calamares as well, but now installing EOS i cant and recive in offline install:
" failed to unpack image “xyz” details: rsync failed with error code 11"
as in image I attatch:
in online install something similar
everytime,
iso is not corrupted…
whatsup?
thanks for your time
Some common reasons for this error code are file corruption or the target is full and rsync cannot proceed because it ran out of space to copy files. Either reason could be your issue.
Posting the install log could help in diagnosing the problem.
iso is not corrupted and space on virtualbox cant be a prolbem… retry and paste the log :slight_smile:
“space on virtualbox cant be a prolbem” :joy:
retried with expanded virtual disk from default 8G to 16G and it works
not ubuntu nor manjaro or others need a disk bigger than default bytheway
thank you
