I am trying to create an ISO using the archiso
tool, but it keeps failing. I have previously done the same thing in 2018 and 2019 without problems. Is it a bug? Since I couldn’t figure out how to post on their forums despite logging in (no button
), I created a bug report at https://bugs.archlinux.org/task/66835. Just wanted to know if any of the developers of EndeavourOS is facing a similar problem while creating an ISO for release.
Thank you in advance!
Well, try creating target repository in your own space. I think it will help a lot.
Something like:
$ cp -r /usr/share/archiso/configs/releng ~/archlive
$ ~ cd archlive/
$ ~/archlive ls
airootfs efiboot mkinitcpio.conf pacman.conf
build.sh isolinux packages.x86_64 syslinux
$ ~/archlive sudo ./build.sh -v
Remember that ~ is a shortcut for /home/YourUsername/
Here is a screenshot with zsh-powerlevel-10k.
And it works:
Drive current: -outdev 'stdio:out/archlinux-2020.05.30-x86_64.iso'
Media current: stdio file, overwriteable
Media status : is blank
Media summary: 0 sessions, 0 data blocks, 0 data, 1475g free
Added to ISO image: directory '/'='/home/fred/archlive/work/iso'
xorriso : UPDATE : 108 files added in 1 seconds
xorriso : NOTE : Copying to System Area: 432 bytes from file '/home/fred/archlive/work/iso/isolinux/isohdpfx.bin'
xorriso : WARNING : Boot image load size exceeds 65535 blocks of 512 bytes. Will record 0 in El Torito to extend ESP to end-of-medium.
libisofs: NOTE : Aligned image size to cylinder size by 259 blocks
xorriso : UPDATE : 14.54% done
ISO image produced: 338944 sectors
Written to medium : 338944 sectors at LBA 0
Writing to 'stdio:out/archlinux-2020.05.30-x86_64.iso' completed successfully.
[mkarchiso] INFO: Done! | 662M out/archlinux-2020.05.30-x86_64.iso
sudo ./build.sh -v 432,01s user 32,35s system 115% cpu 6:40,60 total
Screenshot?
The directory names that archiso
generates (through other tools like mkarchiso
, pacstrap
, pacman
, etc.) are incompatible with NTFS. A user on reddit helped figure this out: https://www.reddit.com/r/archlinux/comments/gt9gjo/archiso_is_nonfunctional/
Why NTFS? It will never be 100% supported by linux kernel…
Well, anyway…
Have a good day
My HDD is shared with Windows. Only the OS partitions are separate.
You’ll run into troubles, sooner or later. NTFS is not meant to host linux files.
Can somebody port this over to the WIKI?
Like a complete step by step guide?
Would highly appreciate that!
