Which I find weird that it works given that it’s not supposed to be supported. I don’t recall ever installing it, but I recall installing intel_gpu_tools which requires xorg-xrandr to work.
When I try to uninstall it, it breaks the dependecy of several packages including eos-bash-shared, so I’m confused because that package is from EndevourOS. Is it safe to uninstall xorg-xrandr?
I just changed eos-bash-shared 1.36-1 not to have xorg-xrandr as a direct dependency, but an optional dependency. Two apps from eos-bash-shared need xrandr: ChangeDisplayResolution and eos-wallpaper-set.
Anyway, you probably are using xwayland which helps X apps run under wayland.
