Hi there. I’m thinking about to install new Mercury. Is there option to just upgrade to the new version? If not, what is the best (fastest way) to create a backup list of my apps, that I can after easily put back to the Mercury?
I’m not a pro, maybe a pro noob instead in the world of Linux.
the new Release is only effecting new installs … we do only release a new installer fixing things and may adding options and stuff. Installed System is updated as usual on a rolling release and will be the same.
That`s also always mentioned in the release note:
The changes described over here are affecting new installs, our Calamares installer, and the Live environment on the ISO only. Running systems don’t have to “upgrade” to Mercury, if you update regularly your system is fine.
It’s a rolling release distro so if you open a terminal and run a regular package update using Pacman you should be at the same level as everyone else.
I have a honest question to ask, and I mean that question completely without offense: How come that you install an Arch based Linux Distribution without knowing how this Distribution does updates?
Again: This is not against you, this question gets asked seveal times a year and I just don’t get it.
Hi. It’s ok. I understand You. I’m doing updates reguraly. I just have a doubt with the funcionality of the “low” system parts of EOS. Or on the simple way, my answer is: “I like to ask, and be sure about my little doubts”.
for a full list of the packages that are on your system you can run this command pacman -Qq
saving this to a package list can help you reinstall later pacman -Qq > Packages.txt
Note when reinstalling from this list you will either need to use yay(or aur helper of choice) if you have AUR packages as pacman wont install those and will exit with error.
You can read more about pacman man pacman or the arch wiki https://wiki.archlinux.org/title/Pacman
I’d recommend preferring native (=official) packages over AUR packages when possible.
AUR packages have no official support. Anyone can create them, so you use them at your own risk.
Having said that, most AUR packages are still safe to use. But it is a good idea to make sure the AUR package you install is safe. If you are not sure, come to this forum and ask.
Not exactly sure what you are asking, but if you want to look for AUR packages, use e.g. yay -Ss <words-that-describe-the-package>
To install something you found, do yay -S <package-name>
