Newcomer to EndeavourOS and very impressed, I do have question if I may.
I have three monitors and although I can adjust the RGB settings on the monitors themselves for a reasonable match I would like to know if there is way to do this on a per monitor basis from within the OS?
Someway to make adjustments, gamma and RGB, see the effect in real time and save them?
I have a fairly old Radeon card HD 6950 at the moment but could use an Nvidia card, GTX 1070Ti if it would be more useful, and Intel integrated gpu. I can’t really afford a newer gpu with the current prices. I don’t need gaming graphics abilities, but do some video editing and photography.
Looking below do I have the most useful gpu drivers?
inxi -Fxz
System: Kernel: 5.15.4-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: Xfce 4.16.0 Distro: EndeavourOS
base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: P8Z77-V PRO v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 2104
date: 08/13/2013
CPU: Info: Quad Core model: Intel Core i7-2600K bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 cache: L2: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 54705
Speed: 4322 MHz min/max: 1600/6300 MHz Core speeds (MHz): 1: 4322 2: 4322 3: 4322 4: 4322 5: 4322 6: 4322 7: 4322
8: 4319
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: Advanced Micro Devices [AMD/ATI] Cayman PRO [Radeon HD 6950] vendor: Hightech Information System
driver: radeon v: kernel bus-ID: 01:00.0
Display: x11 server: X.Org 1.21.1.1 driver: loaded: intel,modesetting unloaded: fbdev,vesa resolution:
1: 1920x1080~60Hz 2: 1920x1200~60Hz 3: 2560x1440~60Hz
OpenGL: renderer: AMD CAYMAN (DRM 2.50.0 / 5.15.4-arch1-1 LLVM 13.0.0) v: 4.3 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0
Device-2: AMD Cayman/Antilles HDMI Audio [Radeon HD 6930/6950/6970/6990] vendor: Hightech Information System
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.15.4-arch1-1 running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 15.0 running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Network: Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe driver: e1000e v: kernel port: f080
bus-ID: 00:19.0
IF: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 19.11 TiB used: 12.69 TiB (66.4%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDA240G size: 223.57 GiB
ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
ID-3: /dev/sdc vendor: Western Digital model: WD40EZRZ-00GXCB0 size: 3.64 TiB
ID-4: /dev/sdd vendor: Western Digital model: WD30EFRX-68EUZN0 size: 2.73 TiB
ID-5: /dev/sde vendor: Western Digital model: WD40EFRX-68N32N0 size: 3.64 TiB
ID-6: /dev/sdf vendor: Western Digital model: WD80EDAZ-11TA3A0 size: 7.28 TiB
ID-7: /dev/sdg vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
ID-8: /dev/sdh vendor: Crucial model: M4-CT128M4SSD2 size: 119.24 GiB
ID-9: /dev/sdi type: USB vendor: Crucial model: M4-CT128 M4SSD2 size: 119.24 GiB
ID-10: /dev/sdj type: USB vendor: Crucial model: C300-CTFDDAC256MAG size: 238.47 GiB
Partition: ID-1: / size: 60.26 GiB used: 10.23 GiB (17.0%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 499 MiB used: 316 KiB (0.1%) fs: vfat dev: /dev/sdb1
ID-3: /home size: 60.26 GiB used: 8.7 GiB (14.4%) fs: ext4 dev: /dev/sdb2
Swap: ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 53.0 C
Fan Speeds (RPM): N/A
Info: Processes: 424 Uptime: 21h 11m Memory: 15.5 GiB used: 9.38 GiB (60.5%) Init: systemd Compilers: gcc: 11.1.0
Packages: 1001 Shell: Bash v: 5.1.12 inxi: 3.3.07```
