Is it safe to delete /var/lib/dkms/vboxhost after unistallation of vbox?
So a while ago I switched from virtualbox to libvirt.
Now I have leftovers in my system which dracut is mentioning in every update. I want to get rid of it an after reading this topic:
and then this one:
I thought to myself “just purge the directories and be happy” - but better safe then sorry, hence the question…
my dkms status:
dkms status
vboxhost/7.0.10_OSE: broken
Error! vboxhost/7.0.10_OSE: Missing the module source directory or the symbolic link pointing to it.
Manual intervention is required!
vboxhost/7.0.12_OSE: broken
Error! vboxhost/7.0.12_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.0.14_OSE: broken
Error! vboxhost/7.0.14_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.0.16_OSE: broken
Error! vboxhost/7.0.16_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.0.18_OSE: broken
Error! vboxhost/7.0.18_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.0.20_OSE: broken
Error! vboxhost/7.0.20_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.1.2_OSE: broken
Error! vboxhost/7.1.2_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.1.4_OSE: broken
Error! vboxhost/7.1.4_OSE: Missing the module source directory or the symbolic link pointing to it.
vboxhost/7.2.0_OSE, 6.12.45-1-lts, x86_64: installed
vboxhost/7.2.0_OSE, 6.16.5-arch1-1, x86_64: installed
zenpower3/0.2.0, 6.12.45-1-lts, x86_64: installed
zenpower3/0.2.0, 6.16.5-arch1-1, x86_64: installed
zfs/2.2.6: broken
Error! zfs/2.2.6: Missing the module source directory or the symbolic link pointing to it.
And I have neither vbox or zfs installed.
try to move it, maybe to home dir, then do an update. Hopefully someone will pop in with a more useful answer if that fails.
Take a look in /var/lib/dkms and see if you have some leftover stuff in there. If you find anything, check which package owns it, if no package owns it, delete it.
Well. there is some stuff in it:
ll /var/lib/dkms
total 8,0K
-rw------- 1 root root 1,7K 10. Sep 2023  mok.key
-rw-r--r-- 1 root root  811 10. Sep 2023  mok.pub
drwxr-xr-x 1 root root 6,6K  6. Sep 11:19 vboxhost/
drwxr-xr-x 1 root root  120  6. Sep 11:19 zenpower3/
drwxr-xr-x 1 root root  114 13. Dez 2024  zfs/
And here starts the real problem:
ll /var/lib/dkms/vboxhost/
total 492K
drwxr-xr-x 1 root root 142 17. Okt 2023  7.0.10_OSE/
drwxr-xr-x 1 root root 448 17. Jan 2024  7.0.12_OSE/
drwxr-xr-x 1 root root 474 17. Apr 2024  7.0.14_OSE/
drwxr-xr-x 1 root root 212  2. Mai 2024  7.0.16_OSE/
drwxr-xr-x 1 root root 562 17. Jul 2024  7.0.18_OSE/
drwxr-xr-x 1 root root 714 12. Sep 2024  7.0.20_OSE/
drwxr-xr-x 1 root root 146 16. Okt 2024  7.1.2_OSE/
drwxr-xr-x 1 root root 472 25. Jan 2025  7.1.4_OSE/
drwxr-xr-x 1 root root  66  6. Sep 11:19 7.2.0_OSE/
lrwxrwxrwx 1 root root  32 24. Jul 2024  kernel-6.10.0-arch1-2-x86_64 -> 7.0.20_OSE/6.10.0-arch1-2/x86_64/
lrwxrwxrwx 1 root root  32 28. Sep 2024  kernel-6.10.10-arch1-1-x86_64 -> 7.1.2_OSE/6.10.10-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32 27. Jul 2024  kernel-6.10.1-arch1-1-x86_64 -> 7.0.20_OSE/6.10.1-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32  2. Aug 2024  kernel-6.10.2-arch1-1-x86_64 -> 7.0.20_OSE/6.10.2-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32  4. Aug 2024  kernel-6.10.2-arch1-2-x86_64 -> 7.0.20_OSE/6.10.2-arch1-2/x86_64/
lrwxrwxrwx 1 root root  32  8. Aug 2024  kernel-6.10.3-arch1-2-x86_64 -> 7.0.20_OSE/6.10.3-arch1-2/x86_64/
lrwxrwxrwx 1 root root  32 14. Aug 2024  kernel-6.10.4-arch2-1-x86_64 -> 7.0.20_OSE/6.10.4-arch2-1/x86_64/
lrwxrwxrwx 1 root root  32 19. Aug 2024  kernel-6.10.5-arch1-1-x86_64 -> 7.0.20_OSE/6.10.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32 21. Aug 2024  kernel-6.10.6-arch1-1-x86_64 -> 7.0.20_OSE/6.10.6-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32  2. Sep 2024  kernel-6.10.7-arch1-1-x86_64 -> 7.0.20_OSE/6.10.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32  5. Sep 2024  kernel-6.10.8-arch1-1-x86_64 -> 7.0.20_OSE/6.10.8-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32 10. Sep 2024  kernel-6.10.9-arch1-1-x86_64 -> 7.0.20_OSE/6.10.9-arch1-1/x86_64/
lrwxrwxrwx 1 root root  32 12. Sep 2024  kernel-6.10.9-arch1-2-x86_64 -> 7.0.20_OSE/6.10.9-arch1-2/x86_64/
lrwxrwxrwx 1 root root  31  1. Okt 2024  kernel-6.11.1-arch1-1-x86_64 -> 7.1.2_OSE/6.11.1-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  6. Okt 2024  kernel-6.11.2-arch1-1-x86_64 -> 7.1.2_OSE/6.11.2-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 16. Okt 2024  kernel-6.11.3-arch1-1-x86_64 -> 7.1.4_OSE/6.11.3-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 21. Okt 2024  kernel-6.11.4-arch1-1-x86_64 -> 7.1.4_OSE/6.11.4-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 23. Okt 2024  kernel-6.11.5-arch1-1-x86_64 -> 7.1.4_OSE/6.11.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  9. Nov 2024  kernel-6.11.6-arch1-1-x86_64 -> 7.1.4_OSE/6.11.6-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 14. Nov 2024  kernel-6.11.7-arch1-1-x86_64 -> 7.1.4_OSE/6.11.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 17. Nov 2024  kernel-6.11.8-arch1-2-x86_64 -> 7.1.4_OSE/6.11.8-arch1-2/x86_64/
lrwxrwxrwx 1 root root  31 19. Nov 2024  kernel-6.11.9-arch1-1-x86_64 -> 7.1.4_OSE/6.11.9-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30  5. Sep 14:30 kernel-6.12.45-1-lts-x86_64 -> 7.2.0_OSE/6.12.45-1-lts/x86_64/
lrwxrwxrwx 1 root root  31  6. Sep 11:19 kernel-6.16.5-arch1-1-x86_64 -> 7.2.0_OSE/6.16.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30  9. Jan 2024  kernel-6.1.71-1-lts-x86_64 -> 7.0.12_OSE/6.1.71-1-lts/x86_64/
lrwxrwxrwx 1 root root  31 10. Sep 2023  kernel-6.5.2-arch1-1-x86_64 -> 7.0.10_OSE/6.5.2-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 13. Sep 2023  kernel-6.5.3-arch1-1-x86_64 -> 7.0.10_OSE/6.5.3-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 22. Sep 2023  kernel-6.5.4-arch2-1-x86_64 -> 7.0.10_OSE/6.5.4-arch2-1/x86_64/
lrwxrwxrwx 1 root root  31 27. Sep 2023  kernel-6.5.5-arch1-1-x86_64 -> 7.0.10_OSE/6.5.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  8. Okt 2023  kernel-6.5.6-arch2-1-x86_64 -> 7.0.10_OSE/6.5.6-arch2-1/x86_64/
lrwxrwxrwx 1 root root  31 17. Okt 2023  kernel-6.5.7-arch1-1-x86_64 -> 7.0.12_OSE/6.5.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 22. Okt 2023  kernel-6.5.8-arch1-1-x86_64 -> 7.0.12_OSE/6.5.8-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 27. Okt 2023  kernel-6.5.9-arch2-1-x86_64 -> 7.0.12_OSE/6.5.9-arch2-1/x86_64/
lrwxrwxrwx 1 root root  30  9. Jan 2024  kernel-6.6.10-1-lts-x86_64 -> 7.0.12_OSE/6.6.10-1-lts/x86_64/
lrwxrwxrwx 1 root root  32  7. Jan 2024  kernel-6.6.10-arch1-1-x86_64 -> 7.0.12_OSE/6.6.10-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30 11. Jan 2024  kernel-6.6.11-1-lts-x86_64 -> 7.0.12_OSE/6.6.11-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 16. Jan 2024  kernel-6.6.11-2-lts-x86_64 -> 7.0.12_OSE/6.6.11-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 17. Jan 2024  kernel-6.6.12-1-lts-x86_64 -> 7.0.14_OSE/6.6.12-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 25. Jan 2024  kernel-6.6.13-1-lts-x86_64 -> 7.0.14_OSE/6.6.13-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 27. Jan 2024  kernel-6.6.14-1-lts-x86_64 -> 7.0.14_OSE/6.6.14-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  2. Feb 2024  kernel-6.6.15-1-lts-x86_64 -> 7.0.14_OSE/6.6.15-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  4. Feb 2024  kernel-6.6.15-2-lts-x86_64 -> 7.0.14_OSE/6.6.15-2-lts/x86_64/
lrwxrwxrwx 1 root root  30  6. Feb 2024  kernel-6.6.16-1-lts-x86_64 -> 7.0.14_OSE/6.6.16-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 19. Feb 2024  kernel-6.6.17-1-lts-x86_64 -> 7.0.14_OSE/6.6.17-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 23. Feb 2024  kernel-6.6.18-1-lts-x86_64 -> 7.0.14_OSE/6.6.18-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  2. Mär 2024  kernel-6.6.19-1-lts-x86_64 -> 7.0.14_OSE/6.6.19-1-lts/x86_64/
lrwxrwxrwx 1 root root  31  9. Nov 2023  kernel-6.6.1-arch1-1-x86_64 -> 7.0.12_OSE/6.6.1-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30  3. Mär 2024  kernel-6.6.20-1-lts-x86_64 -> 7.0.14_OSE/6.6.20-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 10. Mär 2024  kernel-6.6.21-1-lts-x86_64 -> 7.0.14_OSE/6.6.21-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 16. Mär 2024  kernel-6.6.22-1-lts-x86_64 -> 7.0.14_OSE/6.6.22-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 28. Mär 2024  kernel-6.6.23-1-lts-x86_64 -> 7.0.14_OSE/6.6.23-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  5. Apr 2024  kernel-6.6.24-1-lts-x86_64 -> 7.0.14_OSE/6.6.24-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  6. Apr 2024  kernel-6.6.25-1-lts-x86_64 -> 7.0.14_OSE/6.6.25-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 12. Apr 2024  kernel-6.6.26-1-lts-x86_64 -> 7.0.14_OSE/6.6.26-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 17. Apr 2024  kernel-6.6.27-1-lts-x86_64 -> 7.0.16_OSE/6.6.27-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 19. Apr 2024  kernel-6.6.28-1-lts-x86_64 -> 7.0.16_OSE/6.6.28-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 27. Apr 2024  kernel-6.6.28-2-lts-x86_64 -> 7.0.16_OSE/6.6.28-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 28. Apr 2024  kernel-6.6.29-1-lts-x86_64 -> 7.0.16_OSE/6.6.29-1-lts/x86_64/
lrwxrwxrwx 1 root root  31 21. Nov 2023  kernel-6.6.2-arch1-1-x86_64 -> 7.0.12_OSE/6.6.2-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30  5. Mai 2024  kernel-6.6.30-1-lts-x86_64 -> 7.0.18_OSE/6.6.30-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 10. Mai 2024  kernel-6.6.30-2-lts-x86_64 -> 7.0.18_OSE/6.6.30-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 20. Mai 2024  kernel-6.6.31-1-lts-x86_64 -> 7.0.18_OSE/6.6.31-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 23. Mai 2024  kernel-6.6.31-2-lts-x86_64 -> 7.0.18_OSE/6.6.31-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 27. Mai 2024  kernel-6.6.32-1-lts-x86_64 -> 7.0.18_OSE/6.6.32-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 18. Jun 2024  kernel-6.6.34-1-lts-x86_64 -> 7.0.18_OSE/6.6.34-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 24. Jun 2024  kernel-6.6.35-2-lts-x86_64 -> 7.0.18_OSE/6.6.35-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 29. Jun 2024  kernel-6.6.36-1-lts-x86_64 -> 7.0.18_OSE/6.6.36-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  7. Jul 2024  kernel-6.6.37-1-lts-x86_64 -> 7.0.18_OSE/6.6.37-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 10. Jul 2024  kernel-6.6.38-1-lts-x86_64 -> 7.0.18_OSE/6.6.38-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 14. Jul 2024  kernel-6.6.39-1-lts-x86_64 -> 7.0.18_OSE/6.6.39-1-lts/x86_64/
lrwxrwxrwx 1 root root  31 30. Nov 2023  kernel-6.6.3-arch1-1-x86_64 -> 7.0.12_OSE/6.6.3-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30 17. Jul 2024  kernel-6.6.40-1-lts-x86_64 -> 7.0.20_OSE/6.6.40-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 24. Jul 2024  kernel-6.6.40-2-lts-x86_64 -> 7.0.20_OSE/6.6.40-2-lts/x86_64/
lrwxrwxrwx 1 root root  30 25. Jul 2024  kernel-6.6.41-1-lts-x86_64 -> 7.0.20_OSE/6.6.41-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 27. Jul 2024  kernel-6.6.42-1-lts-x86_64 -> 7.0.20_OSE/6.6.42-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  4. Aug 2024  kernel-6.6.44-2-lts-x86_64 -> 7.0.20_OSE/6.6.44-2-lts/x86_64/
lrwxrwxrwx 1 root root  30  8. Aug 2024  kernel-6.6.44-3-lts-x86_64 -> 7.0.20_OSE/6.6.44-3-lts/x86_64/
lrwxrwxrwx 1 root root  30 14. Aug 2024  kernel-6.6.45-1-lts-x86_64 -> 7.0.20_OSE/6.6.45-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 15. Aug 2024  kernel-6.6.46-1-lts-x86_64 -> 7.0.20_OSE/6.6.46-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 21. Aug 2024  kernel-6.6.47-1-lts-x86_64 -> 7.0.20_OSE/6.6.47-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  2. Sep 2024  kernel-6.6.48-1-lts-x86_64 -> 7.0.20_OSE/6.6.48-1-lts/x86_64/
lrwxrwxrwx 1 root root  30  5. Sep 2024  kernel-6.6.49-1-lts-x86_64 -> 7.0.20_OSE/6.6.49-1-lts/x86_64/
lrwxrwxrwx 1 root root  31  6. Dez 2023  kernel-6.6.4-arch1-1-x86_64 -> 7.0.12_OSE/6.6.4-arch1-1/x86_64/
lrwxrwxrwx 1 root root  30 10. Sep 2024  kernel-6.6.50-1-lts-x86_64 -> 7.0.20_OSE/6.6.50-1-lts/x86_64/
lrwxrwxrwx 1 root root  30 12. Sep 2024  kernel-6.6.50-2-lts-x86_64 -> 7.0.20_OSE/6.6.50-2-lts/x86_64/
lrwxrwxrwx 1 root root  29 28. Sep 2024  kernel-6.6.52-1-lts-x86_64 -> 7.1.2_OSE/6.6.52-1-lts/x86_64/
lrwxrwxrwx 1 root root  29  7. Okt 2024  kernel-6.6.54-1-lts-x86_64 -> 7.1.2_OSE/6.6.54-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 16. Okt 2024  kernel-6.6.56-1-lts-x86_64 -> 7.1.4_OSE/6.6.56-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 21. Okt 2024  kernel-6.6.57-1-lts-x86_64 -> 7.1.4_OSE/6.6.57-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 24. Okt 2024  kernel-6.6.58-1-lts-x86_64 -> 7.1.4_OSE/6.6.58-1-lts/x86_64/
lrwxrwxrwx 1 root root  29  3. Nov 2024  kernel-6.6.59-1-lts-x86_64 -> 7.1.4_OSE/6.6.59-1-lts/x86_64/
lrwxrwxrwx 1 root root  31 10. Dez 2023  kernel-6.6.5-arch1-1-x86_64 -> 7.0.12_OSE/6.6.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  29  9. Nov 2024  kernel-6.6.60-1-lts-x86_64 -> 7.1.4_OSE/6.6.60-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 15. Nov 2024  kernel-6.6.61-1-lts-x86_64 -> 7.1.4_OSE/6.6.61-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 19. Nov 2024  kernel-6.6.62-1-lts-x86_64 -> 7.1.4_OSE/6.6.62-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 25. Nov 2024  kernel-6.6.63-1-lts-x86_64 -> 7.1.4_OSE/6.6.63-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 12. Dez 2024  kernel-6.6.65-1-lts-x86_64 -> 7.1.4_OSE/6.6.65-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 25. Dez 2024  kernel-6.6.67-1-lts-x86_64 -> 7.1.4_OSE/6.6.67-1-lts/x86_64/
lrwxrwxrwx 1 root root  29 30. Dez 2024  kernel-6.6.68-1-lts-x86_64 -> 7.1.4_OSE/6.6.68-1-lts/x86_64/
lrwxrwxrwx 1 root root  31 13. Dez 2023  kernel-6.6.6-arch1-1-x86_64 -> 7.0.12_OSE/6.6.6-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 15. Dez 2023  kernel-6.6.7-arch1-1-x86_64 -> 7.0.12_OSE/6.6.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 25. Dez 2023  kernel-6.6.8-arch1-1-x86_64 -> 7.0.12_OSE/6.6.8-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  3. Jan 2024  kernel-6.6.9-arch1-1-x86_64 -> 7.0.12_OSE/6.6.9-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 29. Mär 2024  kernel-6.8.2-arch2-1-x86_64 -> 7.0.14_OSE/6.8.2-arch2-1/x86_64/
lrwxrwxrwx 1 root root  31  9. Apr 2024  kernel-6.8.4-arch1-1-x86_64 -> 7.0.14_OSE/6.8.4-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 12. Apr 2024  kernel-6.8.5-arch1-1-x86_64 -> 7.0.14_OSE/6.8.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 17. Apr 2024  kernel-6.8.6-arch1-1-x86_64 -> 7.0.16_OSE/6.8.6-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 19. Apr 2024  kernel-6.8.7-arch1-1-x86_64 -> 7.0.16_OSE/6.8.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 27. Apr 2024  kernel-6.8.7-arch1-2-x86_64 -> 7.0.16_OSE/6.8.7-arch1-2/x86_64/
lrwxrwxrwx 1 root root  31  2. Mai 2024  kernel-6.8.8-arch1-1-x86_64 -> 7.0.16_OSE/6.8.8-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  5. Mai 2024  kernel-6.8.9-arch1-1-x86_64 -> 7.0.18_OSE/6.8.9-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 10. Mai 2024  kernel-6.8.9-arch1-2-x86_64 -> 7.0.18_OSE/6.8.9-arch1-2/x86_64/
lrwxrwxrwx 1 root root  32 20. Jul 2024  kernel-6.9.10-arch1-1-x86_64 -> 7.0.20_OSE/6.9.10-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 20. Mai 2024  kernel-6.9.1-arch1-1-x86_64 -> 7.0.18_OSE/6.9.1-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 23. Mai 2024  kernel-6.9.1-arch1-2-x86_64 -> 7.0.18_OSE/6.9.1-arch1-2/x86_64/
lrwxrwxrwx 1 root root  31 26. Mai 2024  kernel-6.9.2-arch1-1-x86_64 -> 7.0.18_OSE/6.9.2-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  2. Jun 2024  kernel-6.9.3-arch1-1-x86_64 -> 7.0.18_OSE/6.9.3-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 13. Jun 2024  kernel-6.9.4-arch1-1-x86_64 -> 7.0.18_OSE/6.9.4-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 18. Jun 2024  kernel-6.9.5-arch1-1-x86_64 -> 7.0.18_OSE/6.9.5-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 23. Jun 2024  kernel-6.9.6-arch1-1-x86_64 -> 7.0.18_OSE/6.9.6-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 29. Jun 2024  kernel-6.9.7-arch1-1-x86_64 -> 7.0.18_OSE/6.9.7-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31  8. Jul 2024  kernel-6.9.8-arch1-1-x86_64 -> 7.0.18_OSE/6.9.8-arch1-1/x86_64/
lrwxrwxrwx 1 root root  31 17. Jul 2024  kernel-6.9.9-arch1-1-x86_64 -> 7.0.20_OSE/6.9.9-arch1-1/x86_64/
And continues here:
ll /var/lib/dkms/zfs
total 8,0K
drwxr-xr-x 1 root root 60 13. Dez 2024  2.2.6/
lrwxrwxrwx 1 root root 25 23. Nov 2024  kernel-6.6.62-1-lts-x86_64 -> 2.2.6/6.6.62-1-lts/x86_64/
lrwxrwxrwx 1 root root 25 25. Nov 2024  kernel-6.6.63-1-lts-x86_64 -> 2.2.6/6.6.63-1-lts/x86_64/
And these are just the tips of the iceberg, I came down to this:
pacman -Qo /var/lib/dkms/vboxhost/7.0.10_OSE/6.5.2-arch1-1/x86_64/module/vboxdrv.ko.zst
error: No package owns /var/lib/dkms/vboxhost/7.0.10_OSE/6.5.2-arch1-1/x86_64/module/vboxdrv.ko.zst
Do I really have to do this by hand for every folder, subfolder, link and so on? This really is a choire…
You could use find -exec but, honestly, if you don’t have virtualbox or zfs installed anymore, there should be no harm in removing the entire directories.
Just because I am a coward:
You are speaking of
rm -rF /var/lib/dkms/zfs/ & rm -rF /var/lib/dkms/vboxhost/
